Old 12th Jan 2007, 13:20   #1
lcdguy
Mod Master
lcdguy's Avatar
lcdguy has yet to learn the way of the Dremellcdguy has yet to learn the way of the Dremellcdguy has yet to learn the way of the Dremellcdguy has yet to learn the way of the Dremellcdguy has yet to learn the way of the Dremellcdguy has yet to learn the way of the Dremel
MCE 2005
OK so i finally got me a copy of MCE 2005 to try and i like it except for one thing. The only remote i have is the 45 button hauppage one that came with my tuner. I was wondering if there is a way to make it work with MCE or should i just get something like a MCE remote and one of those logitech harmony remotes.
Thanks,
Lcdguy
__________________
Asus P6X58-D | Intel Core I-7 930 | XFX 5770 CF | Intel SSD V-40GB x5 | 1TB WD Sata 3 x2
lcdguy is offline   Reply With Quote
Old 12th Jan 2007, 15:30   #2
herbs
Nobody but us chickens
herbs's Avatar
herbs has yet to learn the way of the Dremel
Yes there is, you need to modify the irremote.ini file. I vaguely remember seeing a script for this but I cannot remember where.
OK found it clicky here
__________________
A police recruit was asked during the exam, "What would you do if you had to arrest your own mother?" He said, "Call for backup."
"you could have it all, my empire of dirt, I will let you down, I will make you hurt"
herbs is offline   Reply With Quote
Old 12th Jan 2007, 15:32   #3
lcdguy
Mod Master
lcdguy's Avatar
i just got my vfd for my case and it came with a remote that says it is compatible with mce 2005. so we will see.
__________________
Old 12th Jan 2007, 15:59   #4
Ramble
Ginger Nut
Ramble's Avatar
Ramble has yet to learn the way of the DremelRamble has yet to learn the way of the Dremel
Spot on herbs.
In fact, if you're anything like me this is one of the first things you backup just in case you want to reinstall.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 14th Jan 2007, 04:12   #5
lcdguy
Mod Master
lcdguy's Avatar
well that did the trick except now i am using media portal instead of media center as MCE and my VFD's drivers don't play nice (computer BSOD's) but i use media portals VFD controller it works perfectly. for opensource
__________________
Reply
Tags
htpc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
