Thread Tools |
#1 |
Brett Thomas
Philips makes wireless HDMI
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
I pwn all your storage
Does it require an extra power socket because if it does then I'm afraid that it's useless.
#3 |
Multimodder
Anyone know what technology this is based on?
#4 |
I fapped to your post!
i can bet Sony will start producing a copy of this item and call it its own and the whole world will prise it @ being so damn smart its allways been like this when Phillips invents the goods and Sony takes the credit.
__________________
Welcome to Thunderdome, B*tch XBL: atanum141 |
#5 | |
Officious Bystander
This is pretty amazing when you consider what it is doing - UNCOMPRESSED HD video, even at the lower end of the resolution scale (say 720p at 30fps) needs 720(lines)*1280(columns)*24(bits per pixel)*30(fps) bits / sec = 632Mb/sec (+sound +overheads) over a wireless link. Crank it up to 1080p at 60fps and you're staring down the barrel of 3Gb/sec. That is hardcore.
__________________
Demand Naked DSL in the UK! |
#6 | |
The other Brett.
Moderator
It will be sitting in the corner with your reciever,dvd etc away from the TV, thats sort of the point to remove all the cables away from the TV.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home" www.yodasarmpit.com clickr my flickr |
#7 |
If it needs an extra power supply, you'll be looking at one each end, so thats two plugs required, if like me, your room only has two sockets at each location and you are renting then the maximum number of sockets you can get out is limited.
#8 | ||
The other Brett.
Moderator
I suppose what it could mean is only 2 cables, 1 for the TV and 1 for the reciever, rather than TV,DVD,Satallite etc
__________________
#9 |
Madeira's banana is the best!!!
nice..... were do you plug your TV? plug the receiver there. were do you plug your HD-DVD/BRD reader? plug the transmitter there.
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#10 |
What's a Dremel?
Is there any latency?
Does the conversion / deconversion to and from a radio signal cause any delay in the video? Assuming they fix the current glitches, that would be the only other thing that could keep me from buying this when it is released.
| El_Shekador |
| View Public Profile |
| Find More Posts by El_Shekador |
| Thread Tools | |
