RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Jan 2007, 16:00   #1
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Mac Safari has critical vulnerability
http://www.bit-tech.net/news/2007/01...vulnerability/
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 12th Jan 2007, 17:10   #2
Austin Daemon
What's a Dremel?
Austin Daemon is on a distinguished road
Define "framework"...
Since Apple has never really concerned itself with patching the way that Microsoft has, there is no framework in place to easily correct the bugs, either.
It's called Software Update. Broadband-connected Macs can set it to check for and download patches weekly (they're released on Tuesdays). Been in place as long as OS X.
Austin Daemon is offline   Reply With Quote
Old 12th Jan 2007, 17:11   #3
yodasarmpit
The other Brett.
Moderator
yodasarmpit's Avatar
yodasarmpit is a jewel in the roughyodasarmpit is a jewel in the roughyodasarmpit is a jewel in the roughyodasarmpit is a jewel in the rough
If it can connect to the net there will always be some exploit.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
www.yodasarmpit.com
clickr my flickr
yodasarmpit is offline   Reply With Quote
Old 12th Jan 2007, 23:30   #4
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
after all... it is a computer..... it is man made....i will be always faulty.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is online now   Reply With Quote
Old 13th Jan 2007, 10:26   #5
zoot2boot
Multimodder
zoot2boot is on a distinguished road
haha. too true.
zoot2boot is offline   Reply With Quote
Old 13th Jan 2007, 11:57   #6
Nikumba
Supermodder
Nikumba is on a distinguished road
I thnk what they mean is Apple has no bug fixing/patch releaseing structure in place. All OS have an update service to some degree but they might not have a team of programmers/engineers who fix those bugs and release the patches.
Which is what Apple is lacking from the tune of the article, and they are probally right, Apple has been on its pedastool claiming to be prettiest/secure/everyone copies OS for a long time, but those times are chaging, Vista just round the corner is a pretty OS, I find it as stable ifnot more so than XP, and gives me better games performance due to the way DirectX works now.
Even when working in the publishing world for 3 years I grew to dislike the OS, and their hardware due to a certain degree. Took delivery of 10 brand new top range G5s had bits loose in the case, 3 had to go back for repair, its not somthing I would expect from the likes of Dell, HP but Apple seem to go for Form over Fucntion ethos, much like they have done with the iPhone. The other problem I dont like with teh OSX is when they went from 10.2 to 10.3 most of the scanners we used etc didnt work since the drivers werent 10.3 compatible. Granted I can understand them not working going from 9 - 10 or 10 - 11 but just form a point release isnt good.
Kimbie
Nikumba is offline   Reply With Quote
Old 15th Jan 2007, 09:33   #7
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
We reported a similar issue with Safari launching widgets that are downloaded over a year ago. I think Apple should turn off the auto lauching of downloads all together.
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
