Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 13th Jan 2007, 03:17   #1
Sloth
#yolo #swag
Sloth's Avatar
Sloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming Saiyan
How many amps does an AA put out?
I had an idea for a future project (and hopefully the start of a company ) to have some LEDs run off a couple of AA batteries, but I need to know:
How many amps does a single AA battery put out?
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | SteelSeries Siberia V2 | Razer DeathAdder 2013 | Leopold FC200RR/AB | Leopold FC200RC/AB
Sloth is offline   Reply With Quote
Old 13th Jan 2007, 03:31   #2
Snafu-X-
Multimodder
Snafu-X-'s Avatar
Snafu-X- has yet to learn the way of the Dremel
I looked around, and the consensus seems to be 2400mA for most AA batteries. Energizer claims a peak of 2700 on theirs.
__________________
Careful. We don't want to learn anything from this.
Snafu-X- is offline   Reply With Quote
Old 13th Jan 2007, 03:40   #3
Sloth
#yolo #swag
Sloth's Avatar
Wow, thanks for the quick reply!
Once quick other question, how many amps is 2400mA?
__________________
Old 13th Jan 2007, 03:46   #4
Snafu-X-
Multimodder
Snafu-X-'s Avatar
2.4 amps, but good look getting that for long from a AA battery.
__________________
Old 13th Jan 2007, 03:57   #5
Sloth
#yolo #swag
Sloth's Avatar
That's what I feared.. well, the lovable molex will come into play then
__________________
Old 13th Jan 2007, 06:00   #6
Emon
Hypermodder
Emon has yet to learn the way of the Dremel
If it's 2400mAh, then you would get 2400 mA for one hour. I'm not sure if mAh ratings take into account the voltage drop of the battery over time, etc.
Emon is offline   Reply With Quote
Old 13th Jan 2007, 08:13   #7
jakenbake
full duplex
jakenbake's Avatar
jakenbake has yet to learn the way of the Dremel
theres no way you get 2.4 amps from a AA battery. you get less from a 9volt when you stick it across your tounge. maybe 2.4 for like milliseconds...
__________________
1 + 1 = 10
jakenbake is offline   Reply With Quote
Old 13th Jan 2007, 09:36   #8
SteveyG
Electromodder
SteveyG's Avatar
SteveyG has yet to learn the way of the DremelSteveyG has yet to learn the way of the Dremel
It's about 2400mAh for an AA, 1200mAh for a AAA and 550mAh for a PP3 battery.
2400mAh means you can draw 2.4A for one hour, 1.2A for two horus, 0.6A for four hours etc...
SteveyG is offline   Reply With Quote
Old 13th Jan 2007, 10:37   #9
Moriquendi
Bit Tech Biker
Moriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the Dremel
1C (that is: theoreticly discharging the battery in 1 hour) is not that high a discharge rate for a battery, even a consumer AA. But you wont get that long out of it, the capacity of a battery is measured at the 20 hour rate and the faster you discharge it the less energy you get out in total.
I have to wonder about your electrical knowledge if you cant convert between mA and A
Moriquendi
Moriquendi is offline   Reply With Quote
Old 13th Jan 2007, 18:18   #10
ConKbot of Doom
Mod Master
ConKbot of Doom's Avatar
ConKbot of Doom has yet to learn the way of the DremelConKbot of Doom has yet to learn the way of the DremelConKbot of Doom has yet to learn the way of the DremelConKbot of Doom has yet to learn the way of the DremelConKbot of Doom has yet to learn the way of the DremelConKbot of Doom has yet to learn the way of the Dremel
well for one, 9v batteries have a high internal resistance, and your saliva isnt that great of a conductor either, not compared to a copper wire. AA NiMH batteries can put out over 20A for short periods (seconds-a minute or two) Ive measured that myself...
__________________
I'm the Redneck Kbot, I leave my christmas lights up all year long.
ConKbot of Doom is offline   Reply With Quote
Old 13th Jan 2007, 18:24   #11
TTmodder
Hammertime
TTmodder's Avatar
TTmodder has yet to learn the way of the Dremel
it depends of battery types. alkaline is (if i remember right) 1.5 volts but not much amps (cant remeber how much), while ni-cd\ni-hm only are 1.2 volt but comes in all ranges like 1200 mili-A to energizers 2700 mili-A.
__________________
Originally Posted by Nexxo View Post
I've said it once and I'll say it again: screen estate is like money. You can never have too much.
TTmodder is offline   Reply With Quote
Old 13th Jan 2007, 19:07   #12
OtakuHawk
The Post of The Beast
OtakuHawk has yet to learn the way of the Dremel
anyone wanna link a chart giving max current drain for standard cells?
My google fails me.
__________________
Ultra-Lurker
OtakuHawk is offline   Reply With Quote
Old 13th Jan 2007, 20:44   #13
jakenbake
full duplex
jakenbake's Avatar
well, damn. you learn something new every day.
__________________
1 + 1 = 10
Old 29th May 2008, 23:00   #14
questioner
What's a Dremel?
questioner has yet to learn the way of the Dremel
HELP
battery info:
question:
The cam uses 9v at 300ma I believe (or so it says).
Which item will last the longest for the cam (generally)?
4 triple A
4 double A
1 9V
questioner is offline   Reply With Quote
Old 29th May 2008, 23:36   #15
Reverend_Jones
Morte Nunquam Reget
Reverend_Jones has yet to learn the way of the Dremel
My google fails me.
Battery Chart
Reverend_Jones is offline   Reply With Quote
Old 29th May 2008, 23:56   #16
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Originally Posted by questioner View Post
battery info:
question:
4 triple A
4 double A
1 9V
The mAh can be thought of as the rate of energy it can provide for you. In the same application, you can eliminate the time component of it, and look at the numbers as energy. 4*2400 >> 550.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 30th May 2008, 00:16   #17
modgodtanvir
Prepare - for Mortal Bumbat!
modgodtanvir's Avatar
modgodtanvir has yet to learn the way of the Dremel
I thought it was more a case of the amp hours. Could a battery rated 0.79Ah not put out a current of 7.9A for 1 hour?
__________________
Nexxo: Oh, and Relix is god, and ComputerKing is his prophet.
Mankz: Meh. So what am I?
dragon2309: Weak wristed...?
modgodtanvir is offline   Reply With Quote
Old 30th May 2008, 00:26   #18
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
Originally Posted by Krikkit View Post
4*2400 >> 550.
But 4*1.5V = 6V (or 4.8V with rechargeables) so 4 AA or AAA cells won't run the 9V cam at all.
No. The battery datasheet may show a family of curves for different discharge rates, at the low and high current extremes life will be better and worse than the forecast from the Ah figure.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 30th May 2008, 01:32   #19
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Read the bloody post why don't I?!
__________________
Old 30th May 2008, 02:17   #20
mvagusta
Did a skid that went for two weeks.
mvagusta's Avatar
mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.
I'd be fricken amazed if any AA could put out 20a for even one second
Maybe a large battery pack of AA's could output 20a, maybe that's what is meant here
mvagusta is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
