RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 13th Jan 2007, 15:40   #1
GuardianStorm
Ultramodder
GuardianStorm's Avatar
GuardianStorm is on a distinguished road
How To: Metal Bending Guide
As requested, a short guide on how I bend metal
First off I'll start with what tools I use.
^ A Large Hammer, And Square.
From Top to bottom:
A piece of wood
German Beech Mould
A piece of softwood
A Sheet of metal to be bent.
The piece of wood and the Mould are used to clamp the metal in the vice, and the second (the discoloured piece) is used for absorbing the hammer impacts, as to not dent the metal
^ This is the Vice setup I use. The mould is on the far side, followed by the metal, followed by a piece of wood. The mould and block of wood really need to be longer than the piece of metal to be bent, and when put in the vice, keep the tops level.
I also point out that you will need to take into account the thickness of the metal you are bending.
^ This is roughly how I work the length of my metal. The length of the long side you want is 20mm and the short side 5mm. You have 1mm thick metal, and thus I overlap my dimensions by 1mm, to allow for the thickness of the metal to make up the rest of the distance. NOTE: I always have a piece of metal too big in the direction of folding, so that I can trim off excess, and make the piece the exact correct length.
^ I start off the bend using the thin end of the softwood. You only need to behind the metal slightly, one or two hits of the hammer per area is generally fine. Work along the length of the metal to keep a consistent bend.
^ This is the angle I have ended up with after my first set of hits. A little too far bent over for a larger sheet of metal. As this is only a narrow bend, I will continue to bend the metal with the thin end of the softwood.
^ For a taller sheet of metal, I would now flip my softwood, and use the large flat side. This stops this happening:
^ The bend is now fully down onto the top of the mould, however it is not complete yet.
^ I would next use the thin end of the softwood along the corner of the metal. This is to help press the metal right into the corner of your mould, and thus end up with a cleaner 90 degree angle (this works with other angles too, obviously)
^ Next I flip the bend, so that the side we were hitting with the hammer & softwood is now in the vice, and the original held side of the join is exposed. This is then hit with the hammer & softwood to also help the angle form properly.
^ If the piece is the right size to fit into the smaller metal vice we have, I will finish the corner off on that. This is how the corner went into the vice.
^ And here we have it post flattening (Again using the hammer & softwood). All that remains to do is make sure the flat parts of your metal are properly flat.
^ One finished bend. The metal is not perfect, as I wrote the guide using a scrap piece I had lying around.
I hope this was useful to everyone
__________________
Sites: My Site :: My blog
Tools: Project Log Previewer
Curent Projects: Dark Vortex
Finished Projects: Yarrrbox :: Laptop Stand :: Bench PSU MK2 :: FS2
Guides: How To Bend Metal
GuardianStorm is offline   Reply With Quote
Old 13th Jan 2007, 15:44   #2
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
wonderful! \o/
Bindibadgi is offline   Reply With Quote
Old 13th Jan 2007, 17:50   #3
galimim
Minimodder
galimim is on a distinguished road
Nice guide!! It is the way I do it and it has never failed me
__________________
AMD Athlon 64 3200+ 2000@2700Mhz under Zalmanom 9500CU ASUS A8N-E
Gigabyte 6600GT 256Mb 500/800Mhz@581@870Mhz
IT IS SAD BUT TRUE I AM SORRY FOR BAD ENGLISH
A X-boX mod in design
galimim is offline   Reply With Quote
Old 13th Jan 2007, 19:08   #4
h_2_o
Multimodder
h_2_o is on a distinguished road
I used to do it that way a lot, good guide btw. then one day i decided to try a break from harbor freight and to be honest it is a bit easier. if you can grab one for cheap and do a lot of bending they are well worth it. the one thing i really like about it is i do not get the vise marks on it any more and i really dont need to do the touchup with a hammer and softwood. anyway if you are not sure what i'm talking about lookie at this
http://www.harborfreight.com/cpi/cta...emnumber=39103
h_2_o is offline   Reply With Quote
Old 13th Jan 2007, 22:47   #5
GuardianStorm
Ultramodder
wonderful! \o/
Thanks
Thanks
Originally Posted by h_2_o
I used to do it that way a lot, good guide btw. then one day I decided to try a break from harbor freight and to be honest it is a bit easier. if you can grab one for cheap and do a lot of bending they are well worth it. the one thing I really like about it is I do not get the vise marks on it any more and I really dont need to do the touchup with a hammer and softwood. anyway if you are not sure what i'm talking about lookie at this
I use a very good break when I'm in the university workshop, its bending bar is made up of lots of segments so that if you need to bend up a small flap of material in the centre of something (think about how you would bend a net of a box) you can just use the block that is wide enough. Very useful.
I would get one of those breaks, however I am in the UK, so I cant really buy that one. I am on the lookout for one though
__________________
Old 13th Jan 2007, 23:15   #6
h_2_o
Multimodder
very cool, ever play with a cnc break? a friend has one and those things are freaky cool. I dont get to play with it much but like the one you have at the university workshop it can do crazy things. sorry you dont have any local shops that sell the small breaks they work rather well for most of the stuff i do.
Old 14th Jan 2007, 13:13   #7
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
nice....
same principal as the motorised one we have at school.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 14th Jan 2007, 13:57   #8
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
Thanks for the guide, I'll definately use it!
Duste is offline   Reply With Quote
Old 14th Jan 2007, 14:41   #9
ỒĊBłůē
Also available in black
ỒĊBłůē's Avatar
ỒĊBłůē is on a distinguished road
Nice guide
When we did fabrication back when I was an apprentice, there was a formula for calculating material allowances for bending sheet metal - I'm stuffed if I can remember it though
Here you go.
ỒĊBłůē is offline   Reply With Quote
Old 2nd Feb 2007, 19:46   #10
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka is on a distinguished road
Thanks
Thanks
yah I have 2 finger brakes ( the segments are called fingers) and then an 8' tradional brake as well as a press. It is the convenient way to bend things but this is the nice at home way when all you have is a vice and hammer.
you'd be surprised what you can do on just a brake, you can make very strong joints and bend interesting shapes, I made a tool box without using any type of screw, rivet, or weld to keep it together. all I used was a brake and a shear to cut the pieces.
here's the tool box at large I use it to carry my fabrication tools from time to time.
here's the joint, IIRC it's called a Pittsburg lock, used it a lot back in the early 20th century when riveting wasn't practical. It's an interesting concept to phsically lock 2 pieces of sheet in a straight line or at a 90 degree angle and trust me you'll never get it undone
metarinka is offline   Reply With Quote
Old 20th Feb 2007, 12:08   #11
mnpctech
I *am* a Dremel
mnpctech's Avatar
mnpctech is a jewel in the roughmnpctech is a jewel in the roughmnpctech is a jewel in the rough
I love the low buck Diy guides!
__________________
mnpctech.com (web's most unique case mod parts, international orders welcome!)
My Case Mods: NVIDIA ION Cube / Bio-Mechanical Khaos / AMD Corporation / HD 100 / CPU Stingray / The Wall
mnpctech is offline   Reply With Quote
Old 20th Feb 2007, 20:14   #12
GuardianStorm
Ultramodder
thanks very much (its low pound here though )
the Pittsburg lock looks interesting too, might have to experiment with that when i get home from uni
__________________
Old 3rd Mar 2007, 11:27   #13
Rage.
Multimodder
Rage. is on a distinguished road
fantasmo. will help me a lot when/if i use metal.
thanks heaps =D
__________________
Rage.
I believe in skill. When you train, you get better therefore enhancing your skill. When you get to a skill level so high that it's impossible to improve, you are uber. Too bad for you though, noobs can only become trained noobs.
PROJECTS
http://forums.bit-tech.net/showthread.php?t=130546
Rage. is offline   Reply With Quote
Old 26th Apr 2007, 15:42   #14
cr3ativ3
Minimodder
cr3ativ3 is on a distinguished road
quite helpfull, imo!
i was thinking about using this method, and now i know that i'll need that tiny piece of soft wood to absorve(is this the word?) the hammer impact, so you dont your piece of metal "injured"..
nice!
__________________
i hope that someday i'll be able to post my mod here...
PORTUGAL
System: AMD Opteron 148 @ 3003Mhz :: DFI Lanparty UT SLI-D :: GSKILL PC4000 HZ 2x1GB DDR500 :: HIS X800GTO iTurbo IceQII 256MB DDR3 :: LCpower Scorpion 480w Modular :: Seagate Barracuda 80Gb SATA & Maxtor 300Gb SATAII
cr3ativ3 is offline   Reply With Quote
Old 26th Apr 2007, 18:28   #15
GuardianStorm
Ultramodder
glad your finding it useful.
@cr3ativ3: you mean 'absorb' but yes, it is there to absorb hammer impact.
__________________
Old 27th Apr 2007, 10:03   #16
cr3ativ3
Minimodder
yes, that's the word!
tried that yesteray by the way, and the test went quite well
regards
__________________
PORTUGAL
Old 30th Nov 2007, 09:44   #17
Gordy
Evil Teddy
Gordy's Avatar
Gordy is on a distinguished road
I have one of the bending brakes linked above and they are very good. They produce almost perfect bends everytime. Without marking the metal.
__________________
modding.gordyhand.co.uk
Gordy is offline   Reply With Quote
Old 10th Mar 2008, 10:07   #18
karolis
Code Monkey
karolis's Avatar
karolis is on a distinguished road
Great tutorial, but i have a question.
I need to bend 5mm width piece of folded 2mm thick aluminum into a 2cm radius quarter-circle.
Now i've seen people using something similar to those tube bending machines to do that, but is there a way to achieve that with home tools?
Also, maybe this is not the right thread for this, but, how would i go about attaching 2 perpendicular pieces of alu? Welding? As i have no experience in that at all, any other method? this is structural point, so the seal must be strong.
karolis is offline   Reply With Quote
Old 10th Mar 2008, 11:43   #19
GuardianStorm
Ultramodder
you could bend round a corner of suitable diameter (broom handle etc), rather than on a corner, but I don't know how a rolling machine would work I'm afraid.
__________________
Old 10th Mar 2008, 12:04   #20
batuhan
What's a Dremel?
batuhan's Avatar
batuhan is on a distinguished road
not bad
batuhan is offline   Reply With Quote
Reply
Tags
guide
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
