RSS
Reply
Thread Tools View Mode
Old 13th Jan 2007, 20:29   #1
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Krikkit's Cheap cardboard box mod! - UPDATE 13/06/07! Now with added extras!
Right, I recently bought an Intel I815-E integrated board, in a tiny form-factor (credit to -H- ), and needed something to put it in.
Having looked at mini-itx.com and various other websites for a small case, I decided to make my own.
Not being G69T, I haven't decided to employ my multi-million pound computer CNC machine, and not being G-nome, I haven't decided to fashion things using aluminum and bent, treated and fiddled-with plexi. No no.
This is a ghetto mod. All I'm using are things I've got lying around my room in various boxes.
First, the components:
On the left, the mobo, equipped with a 1GHz P3 and 512MB PC133 SD-RAM, in Socket 370 form.
Then we've got an old 40GB Seagate HD (which will probably get replaced at some point for a more quiet one), a Samsung CD-RW, and an 430W Enermax, with braided cables (mega overkill for this, but it was the only one I had lying around).
So, down to work. I'll be using a 6-bottle wine box for this, as they're about a s wide as a PSU, and everything fits nicely.
After cutting out a hole for the backplate in the bottom;
I set to work attatching the mobo to its home in the bottom of the box.
No fancy mobo trays or anything here, just some nuts and bolts:
And here we have a couple of pics with the mobo mounted:
Top down:
View of back panel:
It looks like the mobo sticks out from the back, but rest assured that it's pretty flush.
Next came the tricky part - mounting everything else.
The idea is, if you look at this picture;
To have the PSU just above the mobo, with the exhaust fan a couple of inches above the mobo itself, the HD right behind all this (in the 1-inch or so space between the back of the mobo and the box edge) in a vertical position; and then, finally, the optical drive mounted on top of the PSU.
"But Krikkit!" I hear you cry, "Won't the PSU just bend the box where you screw it to the cardboard, because it only has holes at the front?"
Aha, this is why we have the Optical drive above the PSU.
The optical drive is almost exactly as wide as the box, meaning I can use all 8 screw-holes to suspend it into the 2 side-panels. Then all we need to do is attatch the PSU to the Optical drive with some kind of cradle to stop it falling down, and the job's a good 'un, so to speak.
Well, continuing in our theme of not using anything that isn't in the room already, I decided to use a PCI blanking plate, cunningly holed, to hold it up. Let me show you what I mean;
Once the hole was made (with a hammer and a screwdriver, no pussy-whipped dremelling going on here), we had a perfect solution:
The next job is shortening the PSU cables, followed by mounting, then sealing the puppy up. More soon.
Thoughts? Comments?
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 13th Jan 2007, 20:36   #2
ElThomsono
Mod Master
ElThomsono's Avatar
ElThomsono will become famous soon enough
Ha, brilliant!
My only suggestion would be that you consider getting duck tape involved somewhere
Edit: or coat it with tinfoil for that "aluminium" feel.
__________________
If it's broken, I can fix it. But that's ******.
ElThomsono is offline   Reply With Quote
Old 13th Jan 2007, 20:39   #3
Krikkit
Don't panic!
Krikkit's Avatar
Originally Posted by ElThomsono
Ha, brilliant!
Hush, young padawan, the mighty tape will be coming soon, I promise. (I'm not known as "Mr Duct-tape" to my housemates for nothing )
I like the foil idea too - I'll have to get some in there.
__________________
Old 13th Jan 2007, 20:48   #4
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
you need some more fans around for some ventilaton...
otherwise its good!
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 13th Jan 2007, 21:18   #5
zhangmaster12
Hypermodder
zhangmaster12's Avatar
zhangmaster12 is on a distinguished road
omg i did this kind of thing with a 6800 and a pentium d 805. didnt last long, though. i didnt want my comp to fry so i took them out. gpu was nearing 80c!!!!!!!!
__________________
Project Dimension 2400
zhangmaster12 is offline   Reply With Quote
Old 13th Jan 2007, 21:22   #6
Mod_God
Multimodder
Mod_God is on a distinguished road
lol are you serious this is a, well......interesting mod
__________________
If all else fails send it back DOA
Project Nexus: HERE
Mod_God is offline   Reply With Quote
Old 13th Jan 2007, 23:51   #7
Spaceraver
Weekend Junkie
Spaceraver's Avatar
Spaceraver is on a distinguished road
rofl mod... and so retro...
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard.
Spaceraver is offline   Reply With Quote
Old 14th Jan 2007, 00:28   #8
Aman
Multimodder
Aman is on a distinguished road
omg this might just beat the famous orc
Aman is offline   Reply With Quote
Old 14th Jan 2007, 00:37   #9
sui_winbolo
Network Engineer
sui_winbolo's Avatar
sui_winbolo will become famous soon enoughsui_winbolo will become famous soon enough
Whoa, I want that motherboard, what brand of motherboard is that?
__________________
:: XBOX 360 / / SPARTAN sui ::
sui_winbolo is offline   Reply With Quote
Old 14th Jan 2007, 00:48   #10
r4tch3t
hmmmm....
r4tch3t's Avatar
r4tch3t will become famous soon enoughr4tch3t will become famous soon enough
Noice
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms.
Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here
r4tch3t is online now   Reply With Quote
Old 14th Jan 2007, 01:19   #11
CasteR
Minimodder
CasteR is on a distinguished road
this is not even a project......
without duck tape!!!!!!
haha i've done one of these myself except inside a big speaker, worked pretty well it was a head turner!
nice ghetto work though, we all have the secret mcguyver skills inside us!
looks cool though lets see it finished!
CasteR is offline   Reply With Quote
Old 14th Jan 2007, 02:14   #12
Krikkit
Don't panic!
Krikkit's Avatar
Apparently it's an SBC "MicroPCI CompactPCI Embedded Board Industrial Motherboard".
There's a shedload of information here
__________________
Old 14th Jan 2007, 02:24   #13
KayinBlack
I am the Pumpkin King!
KayinBlack's Avatar
KayinBlack has a spectacular aura aboutKayinBlack has a spectacular aura about
Me likes it. I had a cardboard pc once, or twice... or twenty-eleven times.
Very well executed, in finding the right size box.
__________________
Mithril, ongoing... Sponsored by Petra's Tech Shop And Sidewinder Computers
FFVII: Fatal Optimization Sponsored by Koolance
Found cat. Anyone know how to CONTROL cats?
KayinBlack is offline   Reply With Quote
Old 14th Jan 2007, 02:26   #14
specofdust
Banned
specofdust's Avatar
specofdust has a spectacular aura aboutspecofdust has a spectacular aura about
Cant wait to see this finished. Nice idea dude
specofdust is offline   Reply With Quote
Old 14th Jan 2007, 02:53   #15
davidbacsik
Multimodder
davidbacsik is on a distinguished road
Love the mod. My style in deed. Just as a question, what's it for?
davidbacsik is offline   Reply With Quote
Old 14th Jan 2007, 03:08   #16
greensabbath
Got Wood?
greensabbath's Avatar
greensabbath is on a distinguished road
Well it seems cheap, and looks like ass, so you're doing a great job.
Seriously though, we should have a cardboard mod contest
greensabbath is offline   Reply With Quote
Old 14th Jan 2007, 03:40   #17
Yutani
What's a Dremel?
Yutani is on a distinguished road
Great idea I must admit. Just to show all those people out there how multi-functional some of the boxes can really be!
I for one thing are excited and will start my own custom cardboard mod some time in the near future.
Lets get that contest on tracks!
Yutani is offline   Reply With Quote
Old 14th Jan 2007, 05:06   #18
Raziekiel
Modder
Raziekiel is on a distinguished road
You sir may be on your way to Mod of the Year '07!
Raziekiel is offline   Reply With Quote
Old 14th Jan 2007, 05:29   #19
Techno-Dann
Disgruntled kumquat
Techno-Dann's Avatar
Techno-Dann will become famous soon enoughTechno-Dann will become famous soon enough
A cardboard mod contest would rock.
On a more relevant note, this mod rocks too. Needs duct tape, though.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing.
Techno-Dann is offline   Reply With Quote
Old 14th Jan 2007, 14:41   #20
samkiller42
KEEP IT CLEAN!
samkiller42's Avatar
samkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the rough
6 wine bottle box...dam, why didnt i think of this when i bought my new rig
It does look like its a mad mad mod, is this "Gaming rig" up to anything like lan parties? heh, looking good, waiting for the next update.
Sam
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2
Xbox Live: samkiller42¦PSN: samkiller42¦Bungie: samkiller42
samkiller42 is offline   Reply With Quote
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
