Project:Stacker830 Mod (mission2) by Faried112 26-04-2007 made of Sidepanel
Discussion in 'Project Logs' started by Faried112, 15 Jan 2007.
  1. Faried112
    Faried112 What's a Dremel?
    15 Jan 2007
    Hi all,
    I'm Faried from Holland. I'm already started modding my stacker830, but I did not have a log on Bit-tech :D
    Last December I was in a competition(Te Benelux Casemod League) where I finished on the 4e please with a case that still was under construction.
    These thinks I will chance the next 2 month.
    -Inside the case, it will be painted black,
    -The slide panels, and the way they open :rock:
    -Cable slaving, make some covers,
    -To make the front stealth,
    -Finish the top of the case,
    If you will like to see al the photo's
    These are my photo’s from the begin till now:
    This TFT must be some where .......
    UV motherboard tray,
    Broken :wallbash:
    Heat that :hip:
    Water-cooling
    Done: :dremel:
    Green thunder :confused: :confused: :wallbash:
    New one, with SE M600i charger,
    TFT in front bay,
  2. Faried112
    15 Jan 2007
    This is a photo’s shoot of the moment, but soon it will bee in peaches again. :D
    Dusty :worried:
    That’s it for the moment, soon there will be more update's :dremel:
  3. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    wow, nice and colorful, like you plexi work, will you be painting this baby? black would look very nice?
  4. Faried112
    15 Jan 2007
    The inside wil be black. Ediejo(from extreme lian li, stacker steath) know some one to pouder coat the whole frame black. The outside wil stay aluminium with ofcourse black details :)
  5. marauder16
    30 Sep 2006
    nice, wonder how will that look, good luck with it :thumb:
  6. Infenro
    Infenro What's a Dremel?
    7 Oct 2005
    in the top hdd enclosure you should try and get the raptor with a window, or try and mod a window. But yea im liking this case mode especially the acrylic motherboard tray
  7. Faried112
    15 Jan 2007
    I saving some money for a raporX. But it's expansive in Holland, about 200 euro :duh:
    The motherboard tray is not finished yet, a update will come sone…..
    Whiteout broken acryl ate, and under construction :idea:
    Edit: [​IMG]
  8. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    very nice !!!
    The red plexi at the bottom looks amazing
    Keep on
  9. Faried112
    15 Jan 2007
    Foto update:
    Today I have worked on the slide panels. Its still not ready because I m waiting for red acryl, but now you can get some idea of how it will be, :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: lol
  10. elliod
    elliod What's a Dremel?
    1 Oct 2006
    WOW man that is one good looking case right there man
    Subscribed.
    keep up the good work can't wait tpo see what comes out from there.
  11. clesven
    clesven Banned
    17 Jan 2007
    Crazy stuff man! Shows how well a stacker can be moded. I don't love the thunder/mesh, but the acrylic and your worksmanship is nice,
  12. Faried112
    15 Jan 2007
    Yep,
    Stacker830 cant be modded as easily as an normal case, use you’re imagination and youll get it done,
    On the end of the this week ill start with the inside of the case. Whit thanks to Edijo(form project Stacker stealth, Bat case, and of course the Extreme lian li) the inside will get powder coated black. :clap:
  13. Faried112
    15 Jan 2007
    Today I have been worked on the slide panels again. I have to make something on the panels because I have a plan to chance the way they open :D :jawdrop:
  14. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Nice sidepanels :)
  15. Faried112
    15 Jan 2007
    Thanks, there still not finished :D
  16. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Nice to see you here! And i see some nice sidepanels.Cant wait to see the result. :rock:
  17. Koradhil
    9 Nov 2004
    Just ordered a lot of UV acrylic so I'll be modding again soon too ;)
    Ed what are you up to?
  18. Ediejo
    31 Jul 2005
    Check my worklog and you see. ;)
    Sorry for the spam Faried112.
  19. LowCostInks
    LowCostInks What's a Dremel?
    17 Jan 2007
    Looking good! how did u get the screen to the front?
  20. Faried112
    15 Jan 2007
    It’s a 7 inch screen, and a little bigger than the DVD drive so I had to cut some aluminium to make it fit. If you like I can make some pictures to show you?
