#1 |
I pwn all your storage
Cannot connect to vista share
Running the latest release of Samba (3.0.23) on my FC5 box, with flux.
When I use smbclient to connect to a Vista machine on my network it appears to do a memory dump then return to the prompt. If I connect to a Windows XP machine it works fine however. Weirdly, my XBOX with XBMC (01/01/07) connects fine. |
#2 |
/dev/null
Is there a decent output of "smbclient -L <hostname>"?
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't |
#3 |
I'll check that when I go home, the firewall here is blocking my connection
#4 |
Minimodder
i've been reading the feb '07 issue of Linux Magazine and there is an article about this problem in there,
Quote: Vista has a modified version of the protocol SMB 2.0, which is currently supported by the latest Windows operating systems only; for this reason, Windows Vista automatically downgrades to SMB 1.0 if the requesting operating system is not compatible – or so Microsoft says. As our test revealed, this generosity does not extend to Linux; at present, it is not possible to open Vista shares using a Linux client. you can dounload it as a pdf from here Last edited by horse; 25th Jan 2007 at 11:02. Reason: added quote from the article |
#5 |
But why can my XBMC install connect then?
#6 |
Minimodder
in the article it says that it will downgrade to SMB 1.0 if the connecting OS is not compatible
XBMC is sitting on top of the original X-Box OS (i believe) so vista would see it as Win2K and downgrade |
#7 | |
What's a Dremel?
I had the same problem. I could connect to WIN2K shares from my SUSE box, but not to my Vista Ultimate machine. In order to connect to Vista shares using smbclient you have turn off spnego. Add this line to etc/samba/smb.conf under global settings: client use spnego = no |
| Tags |
| linux |
| Thread Tools | |
