RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st Jan 2007, 12:55   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Clean install Vista with upgrade DVD via loophole
http://www.bit-tech.net/news/2007/01..._via_loophole/
Tim S is offline   Reply With Quote
Old 31st Jan 2007, 13:03   #2
rupbert
Hypermodder
rupbert's Avatar
rupbert is on a distinguished road
How can they stop it though without forcing the serial number to be entered on installation?
rupbert is offline   Reply With Quote
Old 31st Jan 2007, 13:03   #3
Hepath
Hypermodder
Hepath is on a distinguished road
Standard MS product testing!
Mind you glad of this as having to reinstall 2 operating systems would have been a right royal PITA!
__________________
C#.Net Certified Application Professional (MCAD)
DFI Lan Party NF4 UT SLI-D | AMD64 4000+ San Deigo (XP90-C) | OCZ PC4800 DDR Plat | Seagate 300Mb 8Mb | PBDV1640P DVD/RW | TAGAN TG480-U22 480W | BFG 6800GT OC (Artic Cooling NV5)
Hepath is offline   Reply With Quote
Old 31st Jan 2007, 13:26   #4
Paradigm Shifter
Lethargic
Paradigm Shifter's Avatar
Paradigm Shifter will become famous soon enough
Hang on, does the 30 day trial allow you to enter a serial at the end of it, or does it lock you out irrevocably and require you to reinstall? If it's the former, why the double install hassle? Surely a single install then clocking the date forward to force serial entry/activation will be sufficient...
Of course, if it's the latter, then it doesn't work.
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA
Paradigm Shifter is offline   Reply With Quote
Old 31st Jan 2007, 14:06   #5
rupbert
Hypermodder
rupbert's Avatar
It's the former.
Old 31st Jan 2007, 14:18   #6
Phil Rhodes
Supermodder
Phil Rhodes is on a distinguished road
Hi,
I think it's fairly clear this is the sort of thing that'll be closed down fairly soon, so we'll end up doing two installs.
What really gets up my nose is that this is all based on the ridiculous, arrogant Microsoft fantasy that you don't have to reinstall yearly. Obviously, Windows is so perfect and longlived that you never have to reinstall it, so this isn't a problem, is it!
Oh, no. Just a sec.
Phil
Phil Rhodes is offline   Reply With Quote
Old 31st Jan 2007, 14:23   #7
rupbert
Hypermodder
rupbert's Avatar
Hi,
Oh, no. Just a sec.
Phil
Yeah personally I reformat every 8 months; I use an image that I create after the initial install and setup and just use Acronis DriveImage to quickly shadow it onto the drive...
Old 31st Jan 2007, 14:42   #8
Mother-Goose
Tories ftw!
Mother-Goose's Avatar
Mother-Goose is on a distinguished road
rupbert, might have to ask you about how that works at a later date me thinks. Am I right in thinking it is only the OEM version that is affected by this lockdown or is it retail as well?
__________________
Goose
Q6600, Striker Extreme, 4GB 6400C4 Dominator DHX, Raptor X, 2x400GB spinpoints, BFG 8800GTX OC, Stacker 830 Evo, HX620, Nova T 500, Freezer 7 Pro
Mother-Goose is offline   Reply With Quote
Old 31st Jan 2007, 14:43   #9
Paradigm Shifter
Lethargic
It's the former.
OK.
So I just discovered an even easier work around?
And how exactly, did this "workaround" spread around the web when there is an easier (and even more obvious) way?
__________________
Old 31st Jan 2007, 14:49   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I don't know whether the latter works because you're not "upgrading" anything.
Old 31st Jan 2007, 15:10   #11
Mother-Goose
Tories ftw!
I'm assuming people buying the upgrade ed. would get the retail version as the full OEM isn't much more?!
__________________
Goose
Old 31st Jan 2007, 15:25   #12
Paradigm Shifter
Lethargic
Well, yes, exactly. I've not got a release copy of Vista to test this - last build I've got is RC2.
__________________
Old 31st Jan 2007, 20:54   #13
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
i think the OEM version is cheaper than the upgrade.....
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 31st Jan 2007, 21:44   #14
The Bart Man
Modder
The Bart Man is on a distinguished road
The OEM version should be the same as the retail version only you don't get any support. The upgrade version is cheaper then te retail but more expesive then the OEM. But if this workaround works (witch is a verry simpel one) that could safe a lot of money. Would it be possible for microsoft to track you down if you installed it this way?!
The Bart Man is offline   Reply With Quote
Old 31st Jan 2007, 23:10   #15
Constructacon
Constructing since 1978
Constructacon's Avatar
Constructacon is a jewel in the roughConstructacon is a jewel in the roughConstructacon is a jewel in the rough
Why would they bother? You've bought a legitimate version of the software and installed it (even if not exactly how they wanted you to). The PR fiasco would not be worth their time (or loss of profits) if they shut down people who bought legitimate software and stopped them using it for something this silly.
__________________
Remember - for every silver lining there is a cloud.
"Of course, overclocking doesn't normally involve a tank of acetylene large enough to blow a house off its foundation." - zackbass
MAME Over - Custom built arcade cabinet.
This season's mod - The New Black
Also modded - "Got Milk?"
Constructacon is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
