RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Feb 2007, 12:23   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Seagate 160GB 2.5" Portable Hard Disk
http://www.bit-tech.net/hardware/200...arddisk/1.html
Tim S is offline   Reply With Quote
Old 3rd Feb 2007, 13:16   #2
mikeuk2004
What you Looking at Fool!
mikeuk2004's Avatar
mikeuk2004 will become famous soon enough
Looks nice. I have 3 usb on my laptop one on the side and 2 on the back under a flap. I always use the one on the side as its easier to get too. If i had to use the 2 on the back id probably end up with it broken.
__________________
-|- Xfire - Mikeuk2005 -|- Xbox Live - Mike UK 2006 -|- Playstation Network - Mikeuk2004 -|-
mikeuk2004 is offline   Reply With Quote
Old 3rd Feb 2007, 17:46   #3
Pie_uk
here... take a slice of my pie
Pie_uk's Avatar
Pie_uk is on a distinguished road
used this and its good. however i opted for a 320gb maxtor for £71.99 pc world
__________________
Im a MAC
Pie_uk is offline   Reply With Quote
Old 4th Feb 2007, 02:18   #4
David_Fitzy
Multimodder
David_Fitzy's Avatar
David_Fitzy is on a distinguished road
heh I just bought a Generic 2.5" USB box with a WD 120G in it. But rather than use it as is I'm going to swap the 20GB in my lappy with the WD in the caddy when I return to the UK.
__________________
Duel of the Duals!
Athlon XP2400+ | Generic FX5200 | SOYO Platinum Dragon Ultra | 1GB Crucial Ram | Maxtor PATA 7200 HDDs: 2x40Gb (RAID0), 2x200Gb(RAID0) | Jeantech Phong case | Black DVD-everything | Black Skythe Kama-meter | dreaded blue LED fans (didn't read the description properly)
At least it's all one colour scheme now
David_Fitzy is offline   Reply With Quote
Old 4th Feb 2007, 02:26   #5
LAGMonkey
Group 7 error
LAGMonkey's Avatar
LAGMonkey will become famous soon enough
so let me get this strait. it needs 1 AMP to run?! and its a 2.5inch laptop HDD?!!!
surely this cant be right? you generally only require 500mA to run a laptop HDD so the rest must be used to power the blue light!
or have a really missed a trick with this one?
__________________
---------------LAG out!---------------
http://www.ctrlaltdel-online.com
100% Brainless]
LAGMonkey is offline   Reply With Quote
Old 4th Feb 2007, 09:54   #6
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
Looks good, but my 80Gb Wester-Digital Passport drive only needs one USB port, and is slightly smaller, and cost under £50 from Amazon on a deal.
Still, i love my portable HDD, and if this gets people go buy them, then it all good.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 4th Feb 2007, 18:13   #7
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Max Amperage (Amps?). Spinup power is significantly more than idle running.
Bindibadgi is offline   Reply With Quote
Old 4th Feb 2007, 19:03   #8
RTT
bwarp
Moderator
RTT's Avatar
RTT is a jewel in the roughRTT is a jewel in the roughRTT is a jewel in the rough
USB is low voltage though (5.5v max?) so it'll probably be running it through a step-up transformer to double the voltage and halve the current back down to 500mA. (and in either case it's still consuming the same amount of power (W)).
RTT is offline   Reply With Quote
Old 5th Feb 2007, 02:06   #9
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Don't forget the power needed to power all that bluetooth/WiFi jiggery - that stuff isn't exactly low-power either...
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 25th Mar 2007, 23:23   #10
led_zeppelinzoso
Multimodder
led_zeppelinzoso's Avatar
led_zeppelinzoso is on a distinguished road
I have this drive, and I was suprised to find out that it works with only one USB pluged in, or just a normil USB cable, atleast on a desktop. I'm going to try it on a laptop sometime.
led_zeppelinzoso is offline   Reply With Quote
Old 26th Mar 2007, 08:54   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Yea they work on 1 plug just fine most of the time, but you are maxing out that USB port.
Old 28th Mar 2007, 01:16   #12
led_zeppelinzoso
Multimodder
So... am I safe, or what? is it ok to do that???
Old 28th Mar 2007, 01:48   #13
Krikkit
Don't panic!
Krikkit's Avatar
You're probably safe, but remember that you're running on the ragged edge of what is and isn't supposed to be done, it's better off with 2.
__________________
Old 28th Mar 2007, 09:26   #14
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
I've been doing it for months on both laptop and PC with just one.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
