RSS
Reply
Thread Tools View Mode
Old 3rd Feb 2007, 18:54   #1
Koradhil
Supermodder
Koradhil's Avatar
Koradhil is on a distinguished road
Project: Mystique by Koradhil [ Completed ]
Mystique is my second project for Cooler Master. It is quite obviously based on a CM Mystique enclosure. I didn't choose a specific theme, I'm just aiming for something looking very futuristic and sleek. The hardware isn't very new, but I'm not going to use the pc much anyway.
Thanks to Cooler Master Europe for supplying the Mystique 631.
Hardware
» Cooler Master Mystique 631 (miditower, silver)
» DFI Lanparty nForce2 Ultra B (ATX, AGP, nForce2, black PCB)
» AMD Athlon XP Mobile 2500+ (Barton core, socket A, 1.8ghz)
» XFX GeForce 6800GT (256mb, AGP8x, green PCB)
» 2x 1GB Mushkin XP4000 DDR (CL3)
» Tagan Black 480 Watt
» Densitron 4x40 character LCD (green backlight)
» Custom watercooling kit
Sketches made in SketchUp:
The 4x40 character LCD I'm using:
__________________
» BRAND NEW SITE
Projects: Nimex | Gemini | Aquamedia | Mystique | Orion | Protoss
Powered by A.C.Ryan, Cooler Master, Corsair, EPoX, PQI, Recom, Revoltec, Sapphire.
Koradhil is offline   Reply With Quote
Old 3rd Feb 2007, 18:55   #2
Koradhil
Supermodder
Koradhil's Avatar
Last week I received most of the supplies I need, so the project can finally start now.
The UV acrylic, green for this project, blue for my other project.
I got a new sponsor, they sent me two reservoirs, a Repack 5.25" bay reservoir for my media center PC and a Cape Coolplex Pro 10 for this project. Both reservoirs are made by Alphacool.
This is the pump I'm going to use, a Hydor Seltz L30 II (1200lph, Hmax 1.95m)
I'm probably going to leave the cover off the pump.
__________________
» BRAND NEW SITE
Old 3rd Feb 2007, 19:03   #3
Gandala
What's a Dremel?
Gandala is on a distinguished road
Wow, the drawings looks really awesome. Though, why are you putting the LCD on the side, instead of in the front?
Btw. when you haven't started with the modding, you dont have a log.
Gandala is offline   Reply With Quote
Old 3rd Feb 2007, 19:44   #4
Faried112
Modder
Faried112 is on a distinguished road
Go go go go go,
Faried112 is offline   Reply With Quote
Old 3rd Feb 2007, 21:34   #5
Koradhil
Supermodder
Koradhil's Avatar
Indeed I haven't started with the modding yet. Well actually I have, because I've replaced the ATX connector of the PSU with a 20 pins instead of the 24 pins it used to have (old motherboard still has 20 pins ATX).
I'm putting the LCD on the side because it won't fit on the front or top because the PCB on it is 19cm wide and the case is 20cm wide... Also it fits perfectly next to the PSU
Small update... I've taken the PC apart and took some photo's. The motherboard:
Of course the ugly CPU cooler will be replaced by a waterblock. I'm building a custom waterblock from the base of a DangerDen TDX:
The TDX was made for a socket 939 system so it won't fit on this board. Therefore I'm going to make a new cover from a 8mm thick piece of acrylic. Something like this:
__________________
» BRAND NEW SITE
Old 3rd Feb 2007, 23:46   #6
RonaldoR9
Multimodder
RonaldoR9 is on a distinguished road
lookin forward to seeing the finish of this project
RonaldoR9 is offline   Reply With Quote
Old 3rd Feb 2007, 23:48   #7
Raziekiel
Modder
Raziekiel is on a distinguished road
Looks good so far, can't wait to see how your waterblock turns out
Raziekiel is offline   Reply With Quote
Old 3rd Feb 2007, 23:52   #8
Captain Slug
Infinite Patience
Captain Slug's Avatar
Captain Slug is on a distinguished road
If you want to make the mounting plate last i recommend making it out of polycarbonate or acetal/delrin.
__________________
Past Project: Baby Mk.V | Current Project: Metal Slug | My Guide To Machining Plastics
Captain Slug is offline   Reply With Quote
Old 4th Feb 2007, 00:07   #9
Sol Badguy
Multimodder
Sol Badguy is on a distinguished road
socket A and 2500+ barton !! im still running on mine, too poor to upgrade. question though, why go through all the trouble to build a pc if you arent going to use it?
__________________
college = broke
kid gets pawned thread
the "1" thread
Sol Badguy is offline   Reply With Quote
Old 4th Feb 2007, 00:08   #10
Koradhil
Supermodder
Koradhil's Avatar
I have a spare piece of 8mm acrylic lying around so I'm using that. It says Perspex on the protection film but that is just a trade name for Polymethyl methacrylate (PMMA) acrylic.. but I don't know anything about different types of acrylic anyway.
@Sol Badguy: I'm modding it for Cooler Master and to use it at casemodding competitions. A while ago I sold my main PC so my new main PC is my media center (Aquamedia) which has a 3000+ Venice with a GeForce 7600GS. After CeBIT I'm going to build a new main PC with better hardware. I might sell Mystique when I have no more use for it, if anyone is still crazy enough to buy an Athlon XP :P
__________________
» BRAND NEW SITE
Old 4th Feb 2007, 01:48   #11
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
Ah, I like the colour scheme you're going for here! I think having the LCD on the side is actually a pretty good idea, because I for one have my case on top of my desk, and it's a lot easier to look at the side of it than to move around so I can see the front of it.
Duste is offline   Reply With Quote
Old 4th Feb 2007, 01:57   #12
zhangmaster12
Hypermodder
zhangmaster12's Avatar
zhangmaster12 is on a distinguished road
SYSEM OF A DOWN !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THEY ROCK!!!!!!!!!!!
anyway, really nice sketchups, cant wate to see waterblcok
__________________
Project Dimension 2400
zhangmaster12 is offline   Reply With Quote
Old 4th Feb 2007, 09:50   #13
Koradhil
Supermodder
Koradhil's Avatar
Thanks all
I actually hardly ever listen to SOAD, I have like 20k mp3's in my mediaplayer shuffling.
__________________
» BRAND NEW SITE
Old 4th Feb 2007, 10:59   #14
kylelnsn
Supermodder
kylelnsn's Avatar
kylelnsn is on a distinguished road
Great project, nice job keep it up cant wait to see more! very nice!
__________________
-|"If it aint broke, MOD it!"|-
I have a website!
kylelnsn is offline   Reply With Quote
Old 4th Feb 2007, 11:59   #15
Koradhil
Supermodder
Koradhil's Avatar
Mini-update, I stipped down the case to bare metal.
I took off the slides for the drivebays. Obviously I don't want purple in my casemod I'm going to spray them black.
I've made two holes in the back of the case for the fittings of the radiator which is mounted at the back of the case. I didn't have a 2cm drill but my fake dremel did the job
To give you an idea of the way the watercooling is going to be placed I placed the pump and reservoir in the case as well. The radiator is held in place by a piece of tape
The sketches are already old :P I have a new idea for the window.
Only without the text of course
Made the plexi cover for the CPU waterblock:
Still needs to be sanded and holes drilled and tapped for the fittings.
__________________
» BRAND NEW SITE
Old 4th Feb 2007, 16:38   #16
Koradhil
Supermodder
Koradhil's Avatar
VGA waterblock, took the base from an Asetek block.
__________________
» BRAND NEW SITE
Old 4th Feb 2007, 16:47   #17
Evenge
Supermodder
Evenge is on a distinguished road
Hey nice project you got here! Cool I say!
Evenge is offline   Reply With Quote
Old 4th Feb 2007, 17:14   #18
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
Please can you remove the right-angle connector coming from the pump out-put..
I't will kill your flow, and I actually think it may look better with a gentle curve on the tube. Otherwise, i'm liking where this project is heading.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 4th Feb 2007, 22:33   #19
Koradhil
Supermodder
Koradhil's Avatar
Indeed I have thought about the right-angle connector at the output of the pump. I originally intended not to use it but the tube will kink if I don't. I'll try some other tubing later (UV green) which is more flexible. Otherwise I'll use a metal spring around the tube but I'd have to buy a new one because I only have one for 6x1 tubing. Another option is using 8mm Tygon tubing but I'd have to order that as well.
__________________
» BRAND NEW SITE
Old 4th Feb 2007, 23:23   #20
Damouse
Multimodder
Damouse's Avatar
Damouse is on a distinguished road
maybe i missed it, but can you post the radiator youre using?
__________________
Dummm.
Damouse is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
