Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Microsoft to ignore Vista upgrade loophole
__________________
#2 |
Trust the Computer
The whole Vista purchasing system is a bit of a mess if you ask me. Although you can get Home Premium for under £60, which is brilliant value, you've then got Ultimate costing about £320 for retail, 3-pack OEMs which cost no less than buying them seperately and upgrade editions (including student ones of course) which aren't upgrades at all...
<A88> |
#3 |
Mod Master
If it stops piracy (you have to buy the upgrade disk) then it will just mean more sales of a vista disk (be it OEM/UPGRADE/RETAIL) etc.. so its a good thing to be fair.
Also, its good for those that get the crappy update disk from OEMs if they want to install Vista cleanly on their PC that came with XP+update disk. Go MS for making a nice decision
#4 |
Tories ftw!
so basically (just to clarify to me) you can do a fresh install of vista from the update disk without actually having a previous install of any os on the hdd?
__________________
Goose ![]() Q6600, Striker Extreme, 4GB 6400C4 Dominator DHX, Raptor X, 2x400GB spinpoints, BFG 8800GTX OC, Stacker 830 Evo, HX620, Nova T 500, Freezer 7 Pro |
| Mother-Goose |
| View Public Profile |
| Find More Posts by Mother-Goose |
#5 |
What's a Dremel?
yes
#6 | |
Officious Bystander
[edit] oh no - I'm wrong - this is how it USED to work with XP etc. Apparently Vista upgrades supposedly require booting from within XP/2K, though you can still, having gone through this process, wipe the HDD and do a clean install from there. The loophole also removes the need to install XP/2K first. [/edit] As I understand it, the 'loophole' is that, if you don't put the XP key in on installation, you can get Vista to boot on a 30 day trial basis, and you can then validate that into a non-trial copy of Vista by inputting your Vista key, without ever having shown Vista a valid XP disc or licence key.
__________________
Demand Naked DSL in the UK! |
#7 |
DUR HUR
I wouldn't have though MS cared all that much TBH. The people who buy the upgrade disk will firstly, be buying a product off them, and if it makes the few people that bother to do it more likely to get vista, is an increase in the market dominance at the cost of a few quid. It's not like MS arn't rolling in the stuff.
#8 | |
Banned
i don't suppose someone could clarify for me, do you actually need to enter a XP serial to do this ?
#9 |
Trust the Computer
You just need the serial/product key which came with the Vista upgrade.
<A88> |
#10 | |
Ecky thump
Moderator
A cunning move by MS, some geeks will be dashing out to buy Upgrade figuring they're putting one over on teh evil M$.
![]() If the system's going to change in future the logical point is if MS decide to slipstream SP1 into a new pressing a la XPSP2. That's not far away, really. However,
OEM with a new motherboard still looks best bang-for-buck if you don't change mobos too often. ![]() Quote:
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. |
#11 |
Brett Thomas
Over here, the cost difference is a little less of an issue. OEM is $129, upgrade is $159. I bought the OEM version simply because I don't mind having only the 64 bit code - it's not really much of a problem. But those who may switch computers now and again would probably buy the upgrade just for the versatility.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#12 |
Madeira's banana is the best!!!
if it fills their pockets with cash......
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
| Thread Tools | |
