#1 |
Mod Master
Making Custom Thumbscrews
Disclaimer; I totally ripped off the guide on metkumods with their idea of making custom thumbscrews and using dice for them, but I found this one at school today and remembered the mod and just had to try it myself.
Tools needed: - Drill - Strong adhesive (epoxy or superglue) - Clamp or vice grip Items needed for mod: ^ Object to mount screw into (in this case a dice) and a standard case screw. Step 1: Place object in a vice or just hold it if you can. Step 2: Drill shallow hole into the item. I got the idea of using the 1 dotted side of the dice because then theres a perfect hole in the middle so your hole will be smack in the middle, and theres no surrounding holes to partially drill out. Fits perfectly! Step 3: Put glue into the hole and put in the end of the screw, clamp in place until the glue dries. All done! Works! Doing this is a great and cheap way to make custom or novelty thumbscrews. Its also so simple and straightforward that writing a guide is almost redundant. Enjoy! EDIT: Ripped off article here: MetkuMods- Theme Screws
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W Last edited by mattthegamer463; 7th Feb 2007 at 23:29. |
| mattthegamer463 |
| View Public Profile |
| Find More Posts by mattthegamer463 |
#2 |
Minimodder
Look very nice, mattthegamer463.
#3 |
Multimodder
Looks very nice!
Simply but nice mod!
__________________
Mod finished,please have a look
- > Turbine Power Project |
#4 |
As long as the Raven flies
Cool! Never thought of that! Nice One!
__________________
Intel Core 2 Duo E6700, Abit AW9D-MAX Intel 975X, GeIL 4GB PC6400C4 800MHz Ultra Low Latency, BFG GeForce 8800 GTX OC2, Western Digital Raptor 150GB, Creative X-Fi Xtreme Music, Corsair HX 620W, CoolerMaster Stacker 830, 24" Dell 2407 Flat Panel, Logitech G11 Keyboard, Logitech G5 Mouse |
| Kurayamino |
| Find More Posts by Kurayamino |
#5 |
Multimodder
I have to try that some day.
__________________
| 3.6GHz Core 2 Duo E8600 | 3GB G.Skill DDR2-1066 | 320GB Master | 640GB Slave | 1GB NVIDIA GeForce 9800 GX2 | Windows Vista Ultimate |
#6 |
Mod Master
Step 1) put a hole in the dice
Step 2) put your junk in the dice Step 3)
__________________
I'm the Redneck Kbot, I leave my christmas lights up all year long. |
| ConKbot of Doom |
| Find More Posts by ConKbot of Doom |
#7 |
Mod Master
Glad everyone likes it
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
| mattthegamer463 |
#8 |
Multimodder
ROFL this is funny. i find it commical to put a dice on a screw on your case haha. unless your case is a boardgame, i dont think it would be very good however it is a novel idea. i can use this for other things =D
ta
__________________
Rage. I believe in skill. When you train, you get better therefore enhancing your skill. When you get to a skill level so high that it's impossible to improve, you are uber. Too bad for you though, noobs can only become trained noobs. ![]() PROJECTS http://forums.bit-tech.net/showthread.php?t=130546 |
#9 |
Supermodder
Thanks to this guide I can now have a dice on my PC to go with my hanging dice in my car
![]() Seriously, nice and easy guide and I was surprised by how the end result turned out. |
#10 |
Spoon? What spoon?
actually this can also be ued to make round generic thumbscrews, by using a lathe, grinder, or drill press to rotate the screw shaft and sand down the dice (the color of which is chosen previously); and you have an instant colored plastic thumbscrew.
mix with dice of theme color for best effect. for those with a lathe this can be used to create some awesome designer thumbscrews. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#11 |
Supermodder
i made some of these for my white and blue themed case and they are friggin sweet. Although i did strip out one of the screw holes cuz i over tightened it... Any body know of an easy fix for this?
__________________
Rig 1 - Q9400 @ 3.4GHz, EP45-UD3P, 4GB GSKILL DDR2 1050, EVGA GTX 260 - 216, Win 7, 1TB WD, 320GB WD, corsair 620HX. ![]() Rig 2 - E6300 @ 2.6GHz, P5N-E SLI, 8GB OCZ Vista Upgrade @ 856, EVGA 8800GT, core 740, shaders 1386, mem 2040mhz, Linux Mint, Ultra 500 watt psu. 2x 80GB sata drives. Project Kaintuck! Finished http://forums.bit-tech.net/showthread.php?t=160235 |
| morris8809 |
| Find More Posts by morris8809 |
#12 |
Spoon? What spoon?
go to a hardware shop and get a thread tap and a new screw for the tap thread size.
the hole will be slightly larger (so will the screw size, but when it's on it shouldn't be noticable. to avoid trying to put the new screw somwhere else if you disassemble the case, try and get a colored screw. |
| Bluephoenix |
#13 |
Mod Master
** its a die **
(plural is dice)
#14 | ||
Mod Master
__________________
| mattthegamer463 |
#15 |
Minimodder
nice guide, quite simple, but usefull to those who want their own "touch" in their mod
as i saw above written, i'll try that soon too! regards
__________________
i hope that someday i'll be able to post my mod here... PORTUGAL System: AMD Opteron 148 @ 3003Mhz :: DFI Lanparty UT SLI-D :: GSKILL PC4000 HZ 2x1GB DDR500 :: HIS X800GTO iTurbo IceQII 256MB DDR3 :: LCpower Scorpion 480w Modular :: Seagate Barracuda 80Gb SATA & Maxtor 300Gb SATAII |
#16 |
Multimodder
That's awesome and cudos to bt staff for runnin' through the forums for us!
#17 |
Multimodder
Nice guide
![]() Might try it myself
#18 |
I pickle they
this is pretty freak'n cool! thanks!
| Tags |
guide ![]() |
| Thread Tools | |
| View Mode | |
