RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Feb 2007, 17:07   #1
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
NVIDIA to release new 680i LT chipset
http://www.bit-tech.net/news/2007/02...0i_lt_chipset/
Bindibadgi is offline   Reply With Quote
Old 9th Feb 2007, 18:10   #2
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is on a distinguished road
Does the chipset really contribute that much to the cost of the board? Even assuming it does, few mobos approach the cost of even one decent video card, much less two for SLI. Seems like a strange place to try to sell a budget part.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 9th Feb 2007, 20:54   #3
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
Most won't buy it due to the loss of the USB ports.
With no room available these days for a PCI USB Expander card, A lot of consumers rely heavily on the included motherboard USB ports.
only a gamer looking to build a powerful LAN machine would even consider buying one. (if they could find a case that doesn't weigh as much as an M1A2 tank from all the cooling required)
And I second the comment about the motherboard-as-budget part. The motherboard is often the only place in a system where compromise is not an option because it regulates a system's future ability to upgrade.
Bluephoenix is offline   Reply With Quote
Old 10th Feb 2007, 13:13   #4
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
meh artificial product differantiation through "SLI", all mobo's with 2xPCIE 8x or 6x could support it if the nvidia drivers allowed it.
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 11th Feb 2007, 16:25   #5
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
I still reckon it's a "clearing inventory" part that they will shift quite cheaply. Chipsets generally cost 1/4 to 1/3rd of the board, depending on what you buy, how many, your relationship with vendor etc
Old 12th Feb 2007, 21:54   #6
masteroffm
What's a Dremel?
masteroffm is on a distinguished road
actually yes. the chipset is the most expensive single part of a motherboard. IIRC the northbridge chip for a 925 motherboard was somewhere in the range of US$50, and the ICH6R was something like US$35 on a motherboard that ran US$220
edit: link with pricing on the nforce4 chipset
http://theinquirer.net/default.aspx?article=27553
masteroffm is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
