#1 |
Supermodder
Vista compatibility
I know that some games aren't playable (or at least not well) in Windows vista but will updates be made or something which will change this or will some games always be unplayable on vista? the reason i'm asking is because i have a tendency to lose or throw away OSes when new ones come out but it seems like i should keep XP so that I can play older games on it. Your thoughts?
#2 |
Ginger Nut
At the moment I believe it's mostly a driver problem, the games themselves have been fine.
I know CSS was unplayable a while ago but now it's just fine. But if you give us a list of games that you play we can try and check them.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#3 |
Supermodder
well i play a lot of games but there i often see old games that i havn't played in a long time and feel like playing them. So i just want to know if eventually all games will be playable on vista or at least most and what will determine whether games will be playable on vista
#4 |
I pwn all your storage
There's a thread in PC gaming I think about peoples experiences.
#5 |
Mod Master
Don't "throw away" XP!
Use it to dual-boot with Vista, for any games which you can't run under Vista
__________________
Beauty is in the eye of the beer-holder
#6 | |
My dremel is broken.
Thats exactly what I did... Dual-booting Vista and XP Pro... as I fiddle with Vista and get accustomed to it, maybe i'll clean install vista as a whole, but for now, dual boot!
__________________
Project Cryogen
Planning: [---------|-] Parts: [--|--------] Construction: [----|------] Gettin' there. |
#7 |
Mod Master
Vista + VMware/virtualPC = win, no need for a dual boot
![]() also, its more a "you can no longer use stupid copy protection" standpoint that MS has that is breaking games - hooza! |
| Tags |
| windows |
| Thread Tools | |
