View Poll Results: which picture to use for backside fanguard
pic one: scarab 18 100.00%
pic two: Cobra 0 0%
pic three: crocodile/king Sobek 0 0%
Voters: 18. You may not vote on this poll
Reply
Thread Tools View Mode
Old 18th Feb 2007, 15:50   #21
TapperSwe
Supermodder
TapperSwe's Avatar
TapperSwe has yet to learn the way of the Dremel
Like i said in the beginning of this project as soon as i had done the model i realiced that a regular psu wouldn't fit because of the case size but abowe all the pyramid shape .So i had to get myself a server psu and after some serious digging i got this one : http://www.zippy.com/P_product_detai...code=P1H-6400P
i chose zippy because they are known for making very high quality psu,s they also make a hole in your wallet 150 pounds,well well lets start with the installation of the psu.
As soon as it arrived i had to test it because i heard that server psus with their small fans often makes an irritating sound:
Unfortunately this psu was no exception ,so i started thinking out a way to silent the fans i finally came up with the idea to put 2 sound absorbing walls with a 4 cm gap betwen for the air to run throu its basicly the same thing you can do to a computer http://www.ixajt.com/sarkofagen/sida.jpg , this is a sketchup of it so u might understand better ,(I'm a very poor at sketchup i have only used it 3 times so its ok to laugh ) :
The psu silenter contains 3 main peaces and this paper model contains all of them, base ,back and front (i used the front and back piece out of same model with a small change do:
Base cuted and bended:
I took out a rubber math from a hdd silenter box and cuted out peaces witch i later putted on the sound absorbing walls ,u can also see that i have done 2 alu square bars to hold the psu:
Here the is psu mounted on base and space for cord has been done:
Here i im working with the 2 aluboxes:
And this is wat came out one box for outblowing air.
And one box for incoming air:
Here is some pictures of al 3 parts and how they suposed to be mounted (upside down) ,u can also see the sound absorbing rubber inside the boxes :
And one pic of the gap betwen base wall and box wall:
Now its time to install the parts in the case i started out by cuting out a hole fore the outcoming air from psu:
Then i instaled the base ,(the power cord will exit in the hole for outcoming air):
Here is the front and u can see how its mounted over the opening:
And the back part ,u can see that its realy close to the door and back of case:
One pic of all parts in case before psu instalation:
And here is the final result ,i also put rubber where the cords comes out:
How well this sount silenting works remains to be seen until i fire this thing up . but i heard that people who has built computers this way got them really quite. (I think im the first one to do it on a psu do )
Well that's it for today comments are of corse wellcome ,next update will be
on next sunday.
__________________
Build done:The Legacy of King Khufu:
http://forums.bit-tech.net/showthread.php?t=129157
Speakers Done:
http://forums.bit-tech.net/showthrea...129157&page=11
TapperSwe is offline   Reply With Quote
Old 20th Feb 2007, 07:42   #22
modsquad
Grease Monkey Undergraduate..
modsquad's Avatar
modsquad has yet to learn the way of the Dremel
looking good, Tap..
what's next?
modsquad is offline   Reply With Quote
Old 20th Feb 2007, 10:31   #23
TapperSwe
Supermodder
TapperSwe's Avatar
modsquad
Thx, Att the moment im working with the hdd holder ,and stealthing the dvd.
__________________
Speakers Done:
Old 21st Feb 2007, 10:30   #24
favelado
What's a Dremel?
favelado has yet to learn the way of the Dremel
The PSU cover looks very interesting!
But wouldn't it have been better if you just exchange the small noisy fan with a bigger one? In my opinion this would be the easier and probably more silent way ...
But however, the idea of the sound absorber is pretty cool and well realised!
favelado is offline   Reply With Quote
Old 21st Feb 2007, 11:20   #25
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
Originally Posted by TapperSwe
jokkos:
How nice that such a good modder/builder as u drops in to look at my work ,i have seen your project and for what i saw that Der_Meister you got going on must have taking some serious planing and workskills ,it looks very good and i will absolutely comment on it when its done(hope u get that pump to work soon).
Regarding the peace on top ,yes it was pretty hard to bend i don't know if u noticed but i bend all my alu in a very simple construction of 2 squareshaped bars and a rubberhammer (in my kichen) .
hmm I missed this reply.
What can I say? Thanks, I've got the pump working.
And any modder that does part of the work in the kitchen is a good modder...heh. Join the club
oh yeah, the psu cover seems like a good idea, I hope it works well.
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 21st Feb 2007, 14:45   #26
TapperSwe
Supermodder
TapperSwe's Avatar
Favelado:
Thx, i do know that this construction will silent down the psu ,the question is more how mutch ,I will try it when case is done both with cover on and of and see how mutch the difference is and report here . Regarding changing the fan to a biger one, im not sure what u mean the psu is only 4 cm in hight so thats not an option if u ask me (or u might got a nother idea? ).
Jokkos:
Yeah building cases in the kitchen is really hardcore lol. I do also work on my balcony when cuting biger parts of alu because of all the dust.
__________________
Speakers Done:
Old 21st Feb 2007, 15:14   #27
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
psst you can get .jpg:s out of sketchup from File - Export - 2d graphic
Nice work with the sheet metal.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 21st Feb 2007, 16:39   #28
Evenge
Hypermodder
Evenge's Avatar
Evenge has yet to learn the way of the DremelEvenge has yet to learn the way of the Dremel
Great work man, really nice idea!
Evenge is offline   Reply With Quote
Old 21st Feb 2007, 17:31   #29
TapperSwe
Supermodder
TapperSwe's Avatar
Jipa:
Thx for the coment and tip i will use jpg for my next sketcup pics.
Evenge:
thx allways nice with some encouraging words.
__________________
Speakers Done:
Old 24th Feb 2007, 13:25   #30
TapperSwe
Supermodder
TapperSwe's Avatar
I completed my work one day earlier so here is the update.
This week i have been working with the hdd holder and like i told in the beginning of this worklog i will put pyramid details inside the case.
I began with thinking what i could do with the hdd and i realized that i could make it in sarcophagus style. Here is some info on sarcophagus if u interested:
http://www.liverpoolmuseums.org.uk/w...arcophagus.asp
And here is the worlds moust known sarcophagus:
http://www.compulink.co.uk/~archaeol...utankhamun.htm
I also wanted to pick up the vibrations from the hdd and after some thinking i came up with a pretty cool idea, proceed and u will see what i mean.
Ok here is where the hdd is giong to be placed:
I also like most of people want to cool my hdd ,so I'm adding a fan in the middle:
View on my "workshop" from livingroom,damn winter,he,he:
Hole cuted and filed/sanded:
Bended,u can also see that i have drilled holes for the fan:
If u open a cd/dvd player u will see that the whole reading mechanism and dvd/cd holder is resting on top of this rubberthings ,
the reason for that is that they pick up the vibrations from the laser reader which goes back and forth in high speed and from the spining dvd/cd (like a shock-absorber/damper on a car). So i figured if they work like shock-absorbers here they must work on a vibrating hdd to.:
I started up by puting them in the holes where the hdd is going to be monted,i will also put them on the base, u will see later on:
If u look on this pic u can see that the hdd has no contact with the hdd holder ,same thing for the screws that holds the hdd, it runs thro the rubber not touching the holder either.:
Lets put the sarcophagus on the visible side of the hdd holder i started up with a template made by me ,u will see that i dident use the entire pic because the screws/rubbers holding the hdd would get in the face of the sarcophagus.
Pic on sheet, i draught everything beside the lines outside the body on free hand:
I cuted all big areas with the multitool i also used drills and alot of filing do the beard and small area underneath the head:
I also wetsanded it because al parts of this case is going to be grited down to 1200 and polished but on engravings u cant do it afterward because that will remove the engraving ,i will however give it a bit more wetsanding before the polishing (not gona polish now) This also gives it a bit of an old look.(seen best on the beard at the moment).I took no pics of the engraving.
__________________
Speakers Done:
Old 24th Feb 2007, 13:34   #31
rowin4kicks
a man walked into a bar ...
rowin4kicks's Avatar
rowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for president
hey that looks really good how did i miss this mod!?!
looks like you got everything planned out alright
i love the use of those cd drive parts!
goood luck
__________________
Penguin v5.0 - i7 - 580 GTX - Fractal XL R2 - Dell U2410 x2
My Flickr
rowin4kicks is offline   Reply With Quote
Old 24th Feb 2007, 13:54   #32
TapperSwe
Supermodder
TapperSwe's Avatar
Lets move over to the feets ,i drilled holes and putet the ruber in same way as with the hdd:
On this pics u see that it actually works ,the feets can move to all directions so if i press the holder back/forward or side to side u see that the feets moves along with the holder :
Here it is installed in the case ,it will later be secured with 4 nuts(one on each feet/leg). On the second pic im pressing the holder upwards on one side and that makes one rubber to get pressed together by the screw and one to stretch out ,so this do really work as i planed :
Some final pics of the hdd holder and fan:
WEll this sarcophagus/hdd holder took me over 10 hours to complete so i would really love to get some thoughts abaut it .
Next uppdate is planed on saturday 03/03/2007.
__________________
Speakers Done:
Old 24th Feb 2007, 15:53   #33
TapperSwe
Supermodder
TapperSwe's Avatar
goood luck
Thx ,I think u could use this rubbers as a a simple way of picking up vibrations even in a regular case instead of rubberbands, u would thast have to drill up the holes a bit (6 mm).
__________________
Speakers Done:
Old 24th Feb 2007, 16:23   #34
Lunn1
Multimodder
Lunn1's Avatar
Lunn1 has yet to learn the way of the Dremel
you know you can buy those dampeners online so you dont have to tear apart your drives to get the, unless those drives are gonners. Ive got quite a bit of them that came with my case, and yes they made a difference.
__________________
AMD X2 5400 |2 gig Gskill Ram|Asus M2N-E SLi |Dual 8500 GT|Corsair 620w PSU |Lite-On Lightscribe DVD burner|320 SATA RAPTOR
Lunn1 is offline   Reply With Quote
Old 24th Feb 2007, 16:38   #35
TapperSwe
Supermodder
TapperSwe's Avatar
Lunn1:
No, i dident know u could buy them never seen them in sweden anyway (could be wrong),dosent matter because the cdplayers i teared apart was non fuctional.
So that leaves me not being able to take credit for the idea of putting them betwen the HDD and HDD holder, damnit i thought it was a brilliant idea lol,(are they mounted exactly the same way?) Never mind i found them with google just now , it must be those small blue ones with screwes (the ones in dvd/cd players are bigger and should therefore work even better )
http://www.heatsinkfactory.com/Nexus...s-p-16351.html
But i must be the first to make hddholder feets out of them ( i hope ) .And that gives it the advantage of 2 vibrating absorbing solutions on one and same hddholder he,he.
__________________
Speakers Done:
Old 25th Feb 2007, 05:07   #36
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the Dremel
...WEll this sarcophagus/hdd holder took me over 10 hours to complete so i would really love to get some thoughts abaut it ...
It's one of those nice touches that can turn an average mod into a good one or turn a good mod into a great one.
__________________
"There are no ordinary people. You have never talked to a mere mortal." C.S Lewis - The Weight of Glory
Tyinsar is offline   Reply With Quote
Old 25th Feb 2007, 08:51   #37
Gramps
Registered User
Gramps has yet to learn the way of the Dremel
Lunn1:
I'm not sure it's the same density rubber in em, but theese bushes ("bussning" in swedish) @ ClasOhlson.se would be cheaper to buy -> http://www.clasohlson.se/Product/Product.aspx?id=386928
Gramps is offline   Reply With Quote
Old 25th Feb 2007, 09:41   #38
TapperSwe
Supermodder
TapperSwe's Avatar
Tyinsar:
Thx for the comment ,but I'm even more greatfull that u left the whole dampener debate to rest .
Gramps:
I'm guessing those rubber rings are much harder than the ones in a CD/DVD player because they are supposed to protect cable's running thro metal sheets.
Lets take this from the beginning ,i knew about this rubber things/dampeners in CD/DVD players because i used a cdplayer for my electric operated gunholster project,so i thought that i had a god idea(still thinks) to put them to use between hdd and holder, and why search for something u already have at home (since i had 3 cd players in my basement?).
In my mind its my idea but unfortunately this solution was allready out on the market (never seen them myself do, only rubbers for fans) so lets plz just leave it at that (it would be really pathetic of me claiming to have come up with this solution if i knew it was allready out there).Im guilty of charge and admit it , in contrast to Clinton "I never had sex with that Monica Levinsky" lol.
Im not saying that u cant criticise me but its no fun when the small things takes over the entire work(this hdd dampners was 30 min out of over 10 hours of work).
The HDD feet is still my solution do,coming out as a kit in Peking 2008 , lol.
__________________
Speakers Done:
Old 25th Feb 2007, 11:56   #39
TapperSwe
Supermodder
TapperSwe's Avatar
Ok lets see if i can get some help with this:
My concern is the fan wich is located underneath the HDD atached to the hdd holder ,its only a 5 mm distance between the HDD and fan and if im not wrong there is magnets round the cpfans and i have heard that mangnets an some cphardware dont go good together, so my question is could this be a problem?.
If it is i will have to place do a hole and place the hdd cooling fan in the bottom of the case instead of in the hdd holder, that would give them a distance of abaut 4 cm instead but would require some undesired work.
Replies are highly appreciated
__________________
Speakers Done:
Old 25th Feb 2007, 12:26   #40
Bas van der Werff
Multimodder
Bas van der Werff's Avatar
Bas van der Werff has yet to learn the way of the Dremel
i don;t think there will be a problem with the fan being so close the hdd there are hddcoolers with fans close to the hdd take a look at this http://www.mycom.nl/Products/View/84161.aspx
Think that it isn't going to be a problem, hope this might help
Bas van der Werff is offline   Reply With Quote
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
