RSS
Old 14th Feb 2007, 12:05   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AOpen XC Cube EU965
http://www.bit-tech.net/hardware/200...e_eu965/1.html
Tim S is offline   Reply With Quote
Old 14th Feb 2007, 13:19   #2
Flibblebot
Free from artificial flavourings
Flibblebot's Avatar
Flibblebot has a spectacular aura aboutFlibblebot has a spectacular aura aboutFlibblebot has a spectacular aura about
Originally Posted by Bindi
There are only two DDR2 slots, but they are PC6400 enabled and orientated perpendicular to the front of the case to allow easy installation.
Looks like they're parallel to the front of the case in the motherboard picture...?
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 14th Feb 2007, 13:28   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Fixed - Rich meant perpendicular to the case sides and I didn't pick up on it. Thanks.
Old 14th Feb 2007, 15:21   #4
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
shame there is a lack of good SFF, I adore my SN45g even though it's getting on abit now. Makes a very good server and the PSU in it is pretty increadable for something rated at only 200w.
I think shuttle should come out with a mini server with the SN45g chassises and a more modern C2d mobo and hard disks mounted horizontaly accross the front, that way it could easily hold 5 or 6 disks in a very small area (mounting a zalman ulta thin fan undernath them for optimum cooling) can you imagiain a shuttle with 6TB of hard disk space... drool. They should also make part of the hard drivce cage removable so that a graphics card can be installed and add a flap on the left hand cover so duel slot cards can be installed (and make it look like your shuttle has a super charger)....
dammm If only I had a grand I would do it myself to one of the more modern shuttles (if they still make the smaller ones with a PCI-E slot.)
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 14th Feb 2007, 16:14   #5
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Tbh, if they made a server with G2 or G5 chassis that would be faaar nicer looking.
Shuttle should really make stuff to order: Choose what chassis you want, choose what board you want in it and then they make it.
Bindibadgi is offline   Reply With Quote
Old 14th Feb 2007, 17:46   #6
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
It seems odd to abandon PCI yet include a parallel port. It's not a bad attempt but, as stated in the article, needs a little revision. (Why so many useless internal USB ports? - in a SSF case 2 should suffice.)
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
