RSS
Reply
Thread Tools View Mode
Old 14th Feb 2007, 18:34   #1
blackflag
I Kill Dremels
blackflag's Avatar
blackflag will become famous soon enough
Project: Ever-So-TightLi (06/01/07 - Project has been shelved)
UPDATE 06/01/07:
Well, it seems to be my luck...
Some components in my server died over the long weekend so I needed to steal from this project to get my system partly functional (and it's still not 100%). As a result I'm stuck with an incomplete pile of parts.
As such Ever-So-Tight-Li is on indefinite hiatus...
When I get more time (and money for parts) I will be back...
Until then...
Hello all,
I've been out of the mod game for a while now since my wife and I found out we were having a little boy. Now that he's here I've been dying to get a proper project going, complete with log. My last project, a dual loop Aqua Computer cooled Lian Li V2000 didnt have a project log because I was scrambling to get it finished.
Now that my boy's here, I don't have a ton of time to work on mods, but at least that slow pace will allow me to take pictures, and actually post.
So, in the spirit of getting back in the game, I'm starting not one, but two project logs, this one being the first. Here's the link to the other one so you can check it out when you're done here: Think Outside the (X)Box. Somehow I always start more than one project at a time... damn ADD!!
So, with all that guff out of the way, the project I'll be chronicling here is based off a Lian Li V300. I haven't seen a lot of projects based on this case, and being a big fan of the V1000 and V2000, I liked the look and the small footprint.
I wanted to transform my v2000 from my gaming machine to a server to store all my DVD ISOs. This is what it looked like before:
Not really conducive to any LAN-ing (if I find the time to do that again soon).
It was running an AMD 4400+ X2, 2GB Corsair XMS, BFG 7800GTX SLI, with a 74GB Raptor and 4 x 250GB Western Digitals in RAID-5. I mentioned there was a dual loop, so essentially I had double the watercooling parts. I removed one loop, the X2 4400, the RAM, and vid cards and replaced it with an Opteron 144, 2GB of generic **** RAM, and an eVGA GeForce 7300GT.
These are the "after" pics.
I replaced the Cuplex XT I had on my X2 with a Cuplex Pro.
I swapped out the Aquabay from the front and replaced it with ventilated Lian Li drive bay covers.
To the server I added 4 x 500GB hard drives, and a 160GB boot drive, for a total of 2.41TB (before formatting). Should be enough to tide me over until my DVD collection gets completely out of hand and requires more space.
I ditched the windowed panel and put the stock one back on.
With cover off:
Closer:
Ok, so with the stage set now, we're about up to speed. Having my entire desktop match is important to me, so with a silver Apple 20" Cinema Display, I needed to make everything go in the same color scheme.
I bought a Logitech G7 recently because I couldnt stand the cord on my G5, and it's got that faux-carbon fiber finish to it.
Great, I love carbon fiber too.
If you recall back to the PC-65 days, Lian Li cases used to have that fake carbon fiber strip on top, so this will all fit in with the overall color scheme.
I have a G15 keyboard that could be tied in closer with the scheme if the black areas were CF. I suppose if I find the time I'll get around to doing that with the CF vinyl.
With the hardware and watercooling parts I yanked out of the V2000, I was almost set for the V300 case. Finally, I'm sure you're thinking.
So here it is. I stripped the fans, power button, and USB ports out.
Sorry about the dust, it's been sitting on my desk for a couple of months now.
I'm not a huge fan of that black strip (it looks too plain) so I'm currently waiting for some carbon fiber strips (genuine) to arrive. I figured that by doing this it would give the case that "retro" vibe from the PC-65.
I'm going to reuse one of my AquaTubes from the other case, so I went about mounting it in the top of the case.
Not sanded/filed yet:
Filed/sanded/drilled:
Test fitted:
Lookin' pretty nifty, if I do say so myself. Don't mind the mismatched socket cap and button head screws, they will all be button head in the end.
Now, I know what many of you may be saying: 7800GTX's won't fit in the V300 because of that 3.5 drive cage. How right you are! Lian Li really screwed the pooch in this department. In an ordinary circumstance the video cards wouldn't fit; this isn't even taking into account the 2 7800GTX Aqua Computer blocks I've got on the cards.
__________________
Project: SpeLL7
blackflag is offline   Reply With Quote
Old 14th Feb 2007, 18:35   #2
blackflag
I Kill Dremels
blackflag's Avatar
I set about cutting out the drive bays and these are the results:
After I did a mock up I saw that despite my careful cutting, the loop between the two video cards will still get in the way of the remaining support braces and hard drive rack. I'll most likely have to cut those out too and get creative with mounting the hard drive, pump, and DVD-RW .
There were still some items I needed to pick up for the V300. Since I'm running SLI with a socket 939, there's only one choice of motherboard: EVGA. In addition to the motherboard I picked up the following:
PSU:
Slot load DVD+/-R (since space is at a mucho premium):
Tubing (Tygon is MUCH more flexible than A-C or Mazzer):
Cuplex XT chipset block:
Alphacool pump:
2 Fans:
Originally I was going to use a BIX2 radiator, but found that it's just a few mm too wide and the case sides wouldn't fit back on. So, I'm waiting for 2 Black Ice 120mm GTS's to arrive.
Speaking of the side panels, I have plans to deal with the pre-cut drive faces. More on that in the next update...
This is what everything looks like on the board:
So, as you can see everything is really tight. Also not pictured is the Audigy 2 ZS I'm putting in the PCI slot... I also have a Bulgin anti-vandal switch to replace the one I ripped out. I like this one a lot better than Lian Li's because the feel is a lot smoother.
More to come as I make further progress...
Till then...
__________________
Project: SpeLL7
Old 14th Feb 2007, 18:44   #3
Dustin
Supermodder
Dustin's Avatar
Dustin is on a distinguished road
Looking forward to this!I'd love to see the v300 finished.Watercooling should be indeed a tight fit in a v300!
Good luck
__________________
Got Brains bitch...
Dustin is offline   Reply With Quote
Old 14th Feb 2007, 18:52   #4
axscpu
Multimodder
axscpu is on a distinguished road
sweet mod...... so I asume that your old hardware in the lian-li v300a right?
how do you plan to place the 2 gts in there, or are you going tomod hte facial of that sweet case???? can't wait to see what you come up with
__________________
Akira: Asus m2npv-vm, a64x2 5600, khx6400d2llk2/2gn, X-fi
Nami: Asus p5n32-e sli, c2q6600, twin2X2048-8500c5d, Geforce 8800gtx
Sakura: Asus p5b-vm, c2d 6600, twin2X4096-6400dhx, Radeon 2900xt
axscpu is offline   Reply With Quote
Old 14th Feb 2007, 19:14   #5
M_D_K
Kiteninja
M_D_K's Avatar
M_D_K is on a distinguished road
Nice start to the v300 , you have the same mobo that i just ordered except mines on tis way from the USA not bad for £40 posted haha bargain for a mATX SLI board.
I see your going for 2 120s i'll be using a Single 120.2 rad you can fit it on one of the doors.
Morgan.
__________________
MY Flickr -- My Website
Canon 50D, 24-70L, 70-200L,1.4&2x TCs, 17-50, 10-17fish, Nifty, 580EXII, Lencarta Studio.
M_D_K is offline   Reply With Quote
Old 14th Feb 2007, 19:15   #6
trig
sweet sweet hangin joben
trig's Avatar
trig will become famous soon enough
looks great so far...look forward to more
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
trig is offline   Reply With Quote
Old 14th Feb 2007, 19:51   #7
blackflag
I Kill Dremels
blackflag's Avatar
@axscpu:
Yes, my X2, Corsair RAM and 7800GTXs are going into the V300. I feel weird not putting brand new tech in there (as I usually do with my mods) but I don't really have a reason other than e-penis extension to get new stuff just yet. I have to be responsible now that I'm a dad . I'm going to stand the radiators up flat against the grill. There are several holes pre-drilled in the chassis where the 80mm fan panel was mounted. I will need to fabricate some bent mounts to secure the radiators in place, and then use a bridge between the 2 radiators (similar to an SLI bridge). It may be aluminum, but I also have some carbon fiber pieces laying around (bent and flat) that may do the trick and look pretty cool in the process. I have some flat M3 tapered bolts that will fit in there perfectly.
@M_D_K:
Are you using a V300 as well? To fit the components in the way I want, things are too tight to fit the rad on the side panel (too much water cooling gear there already). That and I want to keep the sides nice and neat, and able to easily be removed. I'm not even 100% sure if I'm going to have a windowed panel or not. One thing I know for sure, I will not be using any lighting other than 2 white LEDs in the AquaTube.
__________________
Project: SpeLL7
Old 14th Feb 2007, 20:51   #8
M_D_K
Kiteninja
M_D_K's Avatar
Originally Posted by mj007
@axscpu:
@M_D_K:
Plan so far is to put it on the Left hand panel, remove the Floppy and CD bays, make a support for the PSU and Laster 2 new Stainless sidpanels with grills for the rad matching the front design to keep in with the case.
It should all fit with a DDC etc... got 2 6800s and an x2 going in want to keep it clean as poss .
Morgan.
__________________
Old 14th Feb 2007, 20:58   #9
ReFredzRate
Relix Headshot!!
ReFredzRate's Avatar
ReFredzRate is on a distinguished road
Niiiice... I'm sure as hell gonna keep my eyes on this one
__________________
..::Underground::..
Chenbro Gaming Bomb - Asrock K7VT4A Pro - AMD Sempron 2600+ - Geforce FX5200 128Mb - 1024Mb 266MHz DDRAM - 80Gb 7200rpm IDE Seagate - 80Gb 7200rpm SATA Western Digital - DVD-RW 8x - Cooled by Zalman
ReFredzRate is offline   Reply With Quote
Old 14th Feb 2007, 21:33   #10
blackflag
I Kill Dremels
blackflag's Avatar
Yeah, I had considered getting the panels cut to match the pattern of the front, but thought it may look too "hole-y".
I have a blank silver PC-60 panel that will be the source of the aluminum for the side panels, I just have to decide what the sides will be before I send them out to be cut.
Thanks for the compliments so far guys!
__________________
Project: SpeLL7
Old 14th Feb 2007, 22:22   #11
Tile
Banned
Tile is on a distinguished road
Deleted
Tile is offline   Reply With Quote
Old 15th Feb 2007, 05:52   #12
calib3r
Multimodder
calib3r's Avatar
calib3r is on a distinguished road
Thread subscribed.
__________________
| 3.6GHz Core 2 Duo E8600 | 3GB G.Skill DDR2-1066 | 320GB Master | 640GB Slave | 1GB NVIDIA GeForce 9800 GX2 | Windows Vista Ultimate |
calib3r is offline   Reply With Quote
Old 15th Feb 2007, 09:48   #13
airchie
Mod Master
airchie's Avatar
airchie is on a distinguished road
Yep, I like the look of this, subscribing....
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Old 15th Feb 2007, 13:19   #14
guysy1110
Multimodder
guysy1110 is on a distinguished road
this is clean work ! cant wait to see the progress
guysy1110 is offline   Reply With Quote
Old 15th Feb 2007, 16:38   #15
sirkillalot617
Hypermodder
sirkillalot617's Avatar
sirkillalot617 is on a distinguished road
I like your work very much so far. Those Hard drives must suck up alot of power.
I was going to do something like that for my movie collection but then I heard a 1tb hard drive was being released So Il wait for that
Watching closly.
__________________
Me my guitar and a whole lotta technology
sirkillalot617 is offline   Reply With Quote
Old 15th Feb 2007, 17:01   #16
unanimous
What's a Dremel?
unanimous is on a distinguished road
Great mod man.
Im workin on one, almost the same, but my dremel kinda broke........
Lawl
unanimous is offline   Reply With Quote
Old 15th Feb 2007, 17:05   #17
unanimous
What's a Dremel?
My dremel was only $20...... crappy peice of shiit
Old 15th Feb 2007, 17:35   #18
Fozzy
Ultramodder
Fozzy's Avatar
Fozzy is on a distinguished road
PSU:
Alphacool pump:
2 Fans:
Till then...
In my v300 the HDD rack is in the way for tubeing to run over the Videocard. I'll be interested to see how you get around that.
Fozzy is offline   Reply With Quote
Old 15th Feb 2007, 19:18   #19
blackflag
I Kill Dremels
blackflag's Avatar
You are correct. I will most likely be hacking that HDD rack up or running the tubing through the holes in the rack...
__________________
Project: SpeLL7
Old 15th Feb 2007, 20:06   #20
Evenge
Supermodder
Evenge is on a distinguished road
wow now I noticed that you got 2 logs running at the same time!
What can I say about this? Cool...
Evenge is offline   Reply With Quote
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
