RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Feb 2007, 16:19   #1
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Kingston vs OCZ DDR2-800MHz Memory
http://www.bit-tech.net/hardware/200..._review/1.html
Bindibadgi is offline   Reply With Quote
Old 23rd Feb 2007, 17:48   #2
masteroffm
What's a Dremel?
masteroffm is on a distinguished road
funny that I just just picked a KHX6400D2LLK2/2G kit yesterday. I was all set to put together my core 2 duo system last night but I wasnt able to locate a 775 mounting bracket for my thermalright XP120 at any of the local computer shops. I was so disappointed that I was going to have to wait until tonight to put it together
masteroffm is offline   Reply With Quote
Old 23rd Feb 2007, 18:16   #3
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
So I guess the question is, then, what is your recommended 2GB kit for a C2D system in this sort of price bracket (£150-180), assuming I intend to OC to a moderate level (i.e. push the E6300 for whatever I can get out of it, but without having to add exotic cooling solutions or any other crazy OC stuff).
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 23rd Feb 2007, 20:45   #4
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
Any kit should do you well; as to hit a "moderate level" you need 500FSB, and at that, to get yourself DDR2-1000; provided you're locking and linking that is.
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 24th Feb 2007, 10:35   #5
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
Ahh. Must be entertaining to tweak the settings over and over again and run the tests that are most likely not to give any breaking news. I didn't notice if you mentioned it, but do the water cooled thingys fit to the slots next to each other? I ran into problems with some aftermarked coolers... (On my mobo the sticks must be in slots next to each other for dual-channel)
Also great images! As some sort of photographer I really appreciate when people take their time taking the piccys and everything is accurate and nice. Good job!
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 1st Mar 2007, 13:55   #6
Highland3r
I Mod, Therefore I Own
Highland3r is on a distinguished road
Random question (which may well have been explained in the article) why are the tests carried out at different timings?
Surely comparing 3,3,3,x -> 4,3,3,x is going to lead to the tighter timings performing better? Likewise, TRAS values do have an impact on performance and didn't seem consistent between tests.
Fair enough, when testing for a max OC or tightest timings then run as tight (or loose) as you need to/can do for a set FSB otherwise run the timings that all modules can make at a certain speed. Least that way "like for like" comparisons can be made.
Maybe I've missed the point however (which is probably likely) and this was explained somewhere in the report!
__________________
Prawn or not...?
Highland3r is offline   Reply With Quote
Old 1st Mar 2007, 14:14   #7
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
We went for the fastest timings we could get that were stable, then stock timings to see if there was a difference between the modules themselves and the modules compared to others. Then we went for the highest overclock we could get with an upper limit of 5-5-5-15, as well as leaving the mobo to decide what was "optimum" and giving it a free rein do see the difference. A single timing makes SFA difference on performance, even less so in the real world. Unless you're a sandra obsessive I can't tell the difference between a P965 at 5500 and DFI at 5000.
Some of the modules were rated C4, some C5, so we have to measure the rated speed of the modules you buy. Why would we test all the modules at the same speed when some are rated faster than others? It's a "this is the maximum we could get from them and this is how they will perform in our system, and this is how much they cost: is it worth it?"
I see your point on like for likes in that it makes it easier, but the 680is have a limited number of memory bus adjustments: it goes from 1066 to 1142MHz as it clocks in the next ratio. I know of no one who has bought the DFI RD600 despite it having 3MHz memory adjustments and the P965 boards are even more tied in with FSB and memory bus making comparisons even harder.
Jipa: Took me 3 days of running again and again and again The OCZ's do fit next to each other fine, like on AMD boards in dual channel.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
