RSS
Old 6th Mar 2007, 15:45   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Asus Commando
http://www.bit-tech.net/hardware/200...ommando/1.html
Tim S is offline   Reply With Quote
Old 6th Mar 2007, 17:19   #2
NuTech
Back again...
NuTech's Avatar
NuTech is on a distinguished road
Quality review to Bit-tech's high standards as usual.
On a side note, anyone know what ever happened to the Asus Frontlinker? Maybe somebody at HQ can pull some strings and find out?
__________________
NuTech
NuTech is offline   Reply With Quote
Old 6th Mar 2007, 17:45   #3
rupbert
Hypermodder
rupbert's Avatar
rupbert is on a distinguished road
So is the Asus P5B Deluxe the better board in terms of value/features then?
rupbert is offline   Reply With Quote
Old 6th Mar 2007, 18:03   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Depends what you're after, Wifi? Solid state caps? LCD screen? Onboard switches? A couple more heatpipes to provide better stability during the summer? Slightly better overclocking potential, 400 or 450? You have to judge if the £20 is worth it considering your needs.
Nu: I'll put it on my list to ask Asus at CeBit.
Bindibadgi is offline   Reply With Quote
Old 6th Mar 2007, 19:45   #5
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Awesome review yet again, there's a flurry of mobo's coming atm, it's awesome.
Looks like a good board really, have you any quibbles that didn't make it to review?
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 7th Mar 2007, 05:34   #6
BUFF
Hypermodder
BUFF is on a distinguished road
As always a good review by Bit-tech.
Seems quite a variable board going by the forums - some people think that it's as simple a case of QC & whether they were made in the new Chinese factory or not.
Also a lot of reports of them being noisy, Clunk over on Hexus had 3 which I think have all gone back (certainly 2 have).
Plans for an AB9 QuadGT review?
BUFF is offline   Reply With Quote
Old 7th Mar 2007, 08:09   #7
rupbert
Hypermodder
rupbert's Avatar
@ BUFF
Noisy when using the optional cooler?
Old 7th Mar 2007, 13:07   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Noisy? As in electrically? Because the thing doesn't have a single fan. I never used the optional cooler, and it survived 24 hours of stress test without it.
When I see Abit at CeBit I'll ask for one. We gave up on the AB9 Pro since ours died
We had 3 EVGA 680i boards and every one was bad, so sometimes you get good and bad batches of any manufacturer.
Old 7th Mar 2007, 13:54   #9
BUFF
Hypermodder
lots of threads on the net about toroid buzz (even at stock) - as I said Clunk on Hexus returned 3 ...
e.g. http://forums.anandtech.com/messagev...&enterthread=y
Old 7th Mar 2007, 14:21   #10
rupbert
Hypermodder
rupbert's Avatar
@ BUFF
That sounds like a group of defective boards, when you said noisy I assumed every board was inherently noisy.
I've used the Asus P5B-Deluxe without this problem, so I'm guessing it's not a widespread issue?
Old 7th Mar 2007, 17:22   #11
BUFF
Hypermodder
well they've been in the US, UK & Europe so it's a big group ...
HardOCP just posted their review today & they too struggled to get over ~460fsb.
Old 7th Mar 2007, 18:06   #12
rupbert
Hypermodder
rupbert's Avatar
@ Bindibadgi
Can you confirm the review board did not have this 'buzzing' issue? It would put me off buying it to be honest.
Old 8th Mar 2007, 09:08   #13
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Well the labs aren't exactly quiet with some seven machines running on and off, but I'm usually pretty susceptible to high pitched whines and this didn't have any that I noticed the entire time.
I was actually looking at a way to stop the coils whining the other day: apparently if you move them whilst the board is running (with something non metallic) until they seem better, and drop liquid neophrane/silicon on them it kills the noise.
We've had this board since mid-Jan though, so if recent board batches are iffy either try to wait or buy from somewhere noone else does?
Old 8th Mar 2007, 10:00   #14
rupbert
Hypermodder
rupbert's Avatar
@ Bindibadgi
Thanks for the follow up.
I think I'll probably go for the P5B-Deluxe instead, I would be concerned that I couldn't return the Commando because it 'whines'...
Old 8th Mar 2007, 10:21   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Go for it, you'll save twenty quid in the process and gain onboard WiFi. Asus even do a Vista edition P5B now.
Old 8th Mar 2007, 10:34   #16
rupbert
Hypermodder
rupbert's Avatar
Vista Edition?
Old 8th Mar 2007, 10:36   #17
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
Vista Edition?
http://www.asus.com/products4.aspx?l...20&modelmenu=1
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 8th Mar 2007, 19:25   #18
randosome
Banned
randosome is on a distinguished road
so whats the difference, it supports a TPM module (but you have to buy it separately)
And it supports readyboost - though i don't understand how that makes any difference to the motherboard at all
And i guess it has vista drivers
did i miss anything ?
randosome is offline   Reply With Quote
Old 12th Mar 2007, 13:31   #19
Kubix
What's a Dremel?
Kubix is on a distinguished road
Had a commando since it came out, not noticed a whine or anything off the board. Running it will an E6700 and it never skips a beat, one of the better boards i have had. the optional cooler i havent used a there is plenty airflow within the case.
Kubix is offline   Reply With Quote
Old 12th Mar 2007, 14:06   #20
rupbert
Hypermodder
rupbert's Avatar
Thanks for that, and welcome to the forums
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
