Thread Tools |
#1 |
Brett Thomas
Samsung releases hybrid HDD
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
I fapped to your post!
sounds good.
__________________
Welcome to Thunderdome, B*tch XBL: atanum141 |
#3 | |
Mod Master
Looks wicked.
Looking forward to Raptor drives with this kinda tech. Can you imaging a raptor for a couple of gigs of flash memory??? I'd buy that for a dollar (or more like $500 ).Typo:-- Fixed, thanks! - Da Dego
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64 Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF. Quote:
#4 |
DUR HUR
Not just a raptor drive, a parallel perpendicular water holgraphic raptor drive
#5 |
Dark & Sinizter
Awesome. Now I just need to sit back and wait until a 1 or 2 GB flash SATA 120 or 160gb one comes out.
__________________
Nothing here. Go away and dont bother me. |
| sinizterguy |
| View Public Profile |
| Find More Posts by sinizterguy |
#6 |
Banned
i actually watched a long song and dance about flash drives, and they look pretty interesting, except vista has to tell the HDD what to put in the flash memory (otherwise it just acts like a HDD)
Although they did demo the fact, if your not working on it, those hundreds of tiny read/writes that happen can just be buffered in the flash memory, so you can actually get the HDD spun down for like 90% of the time if you aren't doing anything It will become much more interesting when they are a couple of GB though, not that you want to store the OS in nand, but the combination of big enough flash and ram will probably allow the HDD to sit idle Although i do wonder about HDD life - drives last longest when they are on for sustained periods, so constantly starting and stopping the drive seems like a bad idea |
#7 |
^_^
Sounds fantastic, and while the memory size is very small, this should start the ball rolling.
And an extra 30 minutes laptop power is always a good thing! Last edited by riggs; 8th Mar 2007 at 23:41. |
#8 |
Ginger Nut
Nice.
I hope they're releasing a high performance one for us enthusiasts rather than a bunch of laptop drives.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#9 |
Powered by the PG Monkey...
I don't think i'm going to shell out on one of these for a while, not until I'm able to get the entire OS on the flash section, and all my data on the rotary.
Still, as said before, it's nice to see the ball is now rolling
__________________
Scorpion - Opteron 146 - 1GB RAM - 120GB Maxtor ATA133 HDD - 8x DVD-RW - 16x DVDROM - nVidia 7800 GTX Graphics - Gigabyte GA-K8N51GMF-9 Mobo - Undergoing Case Mod Phoenix - Toshiba A120 - 1.73 Celeron (Dothan) - 1GB RAM - 60GB HDD - ATi 200m Graphics Salamander - Intel Pentium III @ 733MHz - 256Mb RAM - Total HDD @ 80Gb
#10 |
Madeira's banana is the best!!!
let the ball roll...... and then buy a uber fast hard drive.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#11 |
Multimodder
wow, that 128mb or 256mb of flash is pretty much worthless... why cant they just stick a 1gb stick or 2gb stick (like in thumb drives) in there and make it a awsome hdd, instead of a decent one.
__________________
Check out my water cooled Lan Box! Core2Duo E6300 @ 3.1ghz | Gigabyte EP45T-UD3P | 2x2GB OCZ Reaper 1066 | 5-5-5-15 @ 1100mhz | Sapphire HD 3870 512mb @ 825/1200 | WD 200GB SATA, 500GB SATA, and seagate 1TB SATA | PC Power and Cooling 750w single 60A rail |
#12 | |
Brett Thomas
__________________
#13 |
Multimodder
My only question would be how this affects the overall drive lifespan - has flash memory progressed beyond the point where it's life under constant read/write is comparable to the rotary part of the drive it's a cruicial part of?
Cheers, Paul |
#14 |
Mod Master
doesnt NAND have a finite amount of read/writes? if its continually cashing data it will surly hit this limit "quite" fast, in comparison to the life time of a standard hard drive -- can you replace the NAND in the disks ?
#15 |
Hypermodder
Flash life has gotten a lot better. The drive can also balance the load of where the reads and writes occur. Samsung has a 32 GB all flash drive with an MBTF of 228 years.
#16 | |
Banned
Also, ontop of that the drive has to cache the files into nand memory anyway, so its just prefetching files better Im wondering what the sweet spot will be where the drive doesnt have to spin up for long periods of time (assuming your not playing media) because the nand has all the data you need |
#17 |
Dark & Sinizter
With this drive in combination with a SD card or other flash memory storing any media I want to watch as well as offering ReadyBoost should increase the battery life on my laptop as it should allow the hdd to spin down.
__________________
| sinizterguy |
#18 | |
Mod Master
I imagine having the swap file in the cache of the HDD would help?
You could in theory set a system managed swap file to be stored in the cache and it would only be filled if needed... How would this work in raid? As your PC 'sees' the disks as one drive, would it still be able to access the nand on the drives? Would you simply double the nand size or lose it alltogether?
__________________
#19 | |
Banned
if you want to find out what actually happens youd need to talk to MS, beacause its their software behind the scenes making this happen, Its called ReadyDrive Edit: Btw its hardly amazing samsung did this, i mean they just followed MS's specs im guessing, they didnt even have to write any software for it - their just the first to get a product out there |
#20 |
Supermodder
Been waiting a long time to see one like this being released, It will improve battery life in laptops by a considerable amount, but if they put in a biggar Flash memory, the prospects for high performance machines, increase rapidly!
Imagine Playing a high intensity game (can't think of one just now), with little to no load times!!! Awosome! |
| Thread Tools | |
