RSS
Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 15th Mar 2007, 18:04   #1
IanW
I *am* a Dremel
IanW's Avatar
IanW is a jewel in the roughIanW is a jewel in the roughIanW is a jewel in the rough
New EVGA 680i mobo announced - with Innovatek w/c blocks pre-installed!
Story at the Inquirer here.
I probably should have posted this in "Extreme Cooling", but I thought it might provoke some interest in here.
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64
IanW is offline   Reply With Quote
Old 15th Mar 2007, 21:51   #2
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
a lil overkill dont you think, so you really need to water cool the power regs and south bridge and its not really full water cooling since they didnt include ram and hard drive blocks but are those needed either?
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 15th Mar 2007, 21:55   #3
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
They aren't needed but even less they have to do with the mobo. After all it was the maain thing of the piece of news there?
WC on regulators'n'stuff is definitely overkill unless one is gonna take the most out of the mobo. Also those might become handy if one aims for a silent setup, has watercooling on processor and minimal airflow through the case.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 15th Mar 2007, 22:15   #4
Woodstock
So Say We All
Woodstock's Avatar
and i think money wise it will be rip off as there will be innovatek's markup, evga's markup and finnally the stores markup. And you will have to take the blocks off to leak test them as well.
__________________
Old 16th Mar 2007, 00:22   #5
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
It'll be overpriced, but it's awesome - getting reg, NB, SB and CPU blocks with a mobo is pretty cool tbh. The only question is, what size fittings will they supply?
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is online now   Reply With Quote
Old 16th Mar 2007, 01:35   #6
Woodstock
So Say We All
Woodstock's Avatar
probally one that no one uses and i personally rather have the choice on which blocks went in
__________________
Old 17th Mar 2007, 21:06   #7
mctigger
Supermodder
mctigger is on a distinguished road
Over kill!!! but would be cool to have and use!!!
mctigger is offline   Reply With Quote
Old 18th Mar 2007, 08:45   #8
Kurayamino
As long as the Raven flies
Kurayamino's Avatar
Kurayamino is on a distinguished road
:O an anorexic 8800GTX
__________________
Intel Core 2 Duo E6700, Abit AW9D-MAX Intel 975X, GeIL 4GB PC6400C4 800MHz Ultra Low Latency, BFG GeForce 8800 GTX OC2, Western Digital Raptor 150GB, Creative X-Fi Xtreme Music, Corsair HX 620W, CoolerMaster Stacker 830, 24" Dell 2407 Flat Panel, Logitech G11 Keyboard, Logitech G5 Mouse
Kurayamino is offline   Reply With Quote
Old 21st Mar 2007, 02:58   #9
zhangmaster12
Hypermodder
zhangmaster12's Avatar
zhangmaster12 is on a distinguished road
wow! omg! thats one SEXY mobo!
__________________
Project Dimension 2400
zhangmaster12 is offline   Reply With Quote
Old 23rd Mar 2007, 22:56   #10
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
best use for this would be an entirely passive cooling setup (short of the radiator fan(s) )
add in some FlexXLC and an LC 8800GTX and you would have a full LC system that's still under manufacturer warranty. a true milestone, to be sure.
Bluephoenix is offline   Reply With Quote
Old 26th Mar 2007, 20:41   #11
K404
Minimodder
K404 is on a distinguished road
Restriction-tastic. Temperatures will royally suck.
K404 is offline   Reply With Quote
Old 27th Mar 2007, 03:22   #12
KayinBlack
I am the Pumpkin King!
KayinBlack's Avatar
KayinBlack has a spectacular aura aboutKayinBlack has a spectacular aura about
Some systems are BUILT to be low-flow. Don't knock it till you've tried it. Used both, prefer low-flow myself.
__________________
Mithril, ongoing... Sponsored by Petra's Tech Shop And Sidewinder Computers
FFVII: Fatal Optimization Sponsored by Koolance
Found cat. Anyone know how to CONTROL cats?
KayinBlack is offline   Reply With Quote
Old 27th Mar 2007, 03:29   #13
Bluephoenix
Spoon? What spoon?
I personally use a third type, distributed flow.
It requires some complex math, but is ultimately the most efficient.
the general Idea is that the source tube is a large-diameter and then is split off to specific diameters, and at a specific flow rate. by causing a slight backup in the system it enables a parallel 4 stick RAM to CPU loop; and no worries about heat buildup from part-to part as with a conventional loop.
Old 31st Mar 2007, 15:04   #14
Fibbles
Supermodder
Fibbles is on a distinguished road
8/10mm compression, based on Innovatek standards and the pics. They are G1/4" threaded so anything should work.
I don't know about the rest of the blocks, but the full card Innovatek coolers have decent flow paths and aren't restrictive when used with larger than 8mm ID fittings (there's a thread in the WC section comparing an Aqua Computer and Innovatek full card block: good info).
Although if past Innovatek performance is still relevant, then the blocks (all but video) won't give better performance with more (better pump or bigger tubes: see Pro Cooling's review of the Innovatek Rev3 and notice that it performs nearly the same, despite different setups).
__________________
Giant Battle Monsters
Fibbles is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
