Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Cooler Master shows concept case design
__________________
#2 |
Supermodder
Any more pics from CeBIT? I'd like to see how my casemod looks over there at the Cooler Master stand
#3 |
Hypermodder
That case looks pretty *futurish*, I think I like it
#4 |
Bwahahahahaha
Over-engineered much? I'll wait and see what the retail versions are like, but that doesn't appear to show the same quality we're used to seeing from Coolermaster (eg. ATC201/210, Wavemaster).
#5 |
The Real Pacman
bit-tech Staff
^ agree ever since the split with ATC CM cases have been lacking. Although this doesn't look that bad, if they got rid of the hand rails it would look quite funky.
__________________
XBL : Shogun Hiren Homepage | HD Tach | Last.fm | DeviantArt bit-tech newsletter | bit-tech Blog |
#6 |
Spoon? What spoon?
hopefully it'll have most of the things that makes the 830 such a wonderful case to use. (removable tray, easy changeover to other configurations)
the 'gutter' will probably be ripped out by most, and the drive cages are a bit of a disappointment to those of us that prefer to use removable 5.25" modules. the bottom mounted PSU is nice to see, hopefully they can do like the Antec P180 and put a vibration damping cage around it. Personally I think that the use of only 5.25" slots with a moveable cage was the best thing to happen to the full-tower cases. |
| Bluephoenix |
| View Public Profile |
| Find More Posts by Bluephoenix |
#7 |
ITS OVER 8000!
Where o' where is our original Wavemaster with 120mm fans Coolermaster??
That would deffo be case for everyone. |
#8 |
Supermodder
The Mystique has 120mm fans also.. I got a yellow wavemaster right here and I got a Mystique 631 as well
#9 |
Multimodder
I like their quality, but personally I don't like the design...
#10 |
Multimodder
wow that case looks awful, it way too complex, and the side handles look a bit funny... ah well, guess not everything is perfect
__________________
Check out my water cooled Lan Box! Core2Duo E6300 @ 3.1ghz | Gigabyte EP45T-UD3P | 2x2GB OCZ Reaper 1066 | 5-5-5-15 @ 1100mhz | Sapphire HD 3870 512mb @ 825/1200 | WD 200GB SATA, 500GB SATA, and seagate 1TB SATA | PC Power and Cooling 750w single 60A rail |
#11 | |
6 screens / 1 card
This case looks interesting, I like the handles but not the door (it looks nice but I don't like doors on cases) or window (don't have a window above my car's engine, don't need a window above my CPU).
__________________
It's not about how life treats you, it's about how you treat life. |
#12 |
sensational.
I like the case it looks quite good except for those rather funky looking handlebars :/
__________________
█▓▒▒▓█▓▒▒▓█▓▒▒▓█▓▒▒▓ Originally Posted by Greeneyedguy advice to all u masturbators... its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips... |
#13 |
Multimodder
Looks like the perfect base for a mod I had in mind (saves me a lot of acrylic cutting) but most of it would disappear, including those handles. Its not a bad idea to put them on the base but why on top as well?
#14 |
Multimodder
Mutton dressed as lamb
__________________
Give them cake |
| HandMadeAndroid |
| Find More Posts by HandMadeAndroid |
#15 |
Supermodder
Looks a bit like a mini-van with those roof rack bars. I wonder if Thule will bring out a compatible luggage box or bike carrier.
| ralph.pickering |
| Find More Posts by ralph.pickering |
#16 | ||
6 screens / 1 card
sounds like something the user "nature" would say (though I'm usually more perplexed by his posts) (which used to be followed by a request for Bindi to change his avatar)
__________________
#17 | |
So Say We All
__________________
Hell hath no fury like a hippo with a machine gun.
#18 |
6 screens / 1 card
Thanks, I'm here until Friday
. Try the veal, (or should that be lamb? )
__________________
#19 |
Lethargic
Looks like they've borrowed some ideas from the Mac Pro case... (the HDD caddy/bay efforts...)
If it's well built, it could be a good case. If they use too much plastic, however... it's gonna be flimsy as hell and more of a liability than an asset. (Hopefully something like the two-material three-ply Antec used for the P180?) Not really sure I like those rails on the top and bottom, though...
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#20 |
Multimodder
I'm officially sick of window panels. The case looks fine, but the sooner the side windows goes the way of the dodo, the better.
__________________
May the forces of evil become confused on the way to your house. |
| Thread Tools | |
