RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 18th Mar 2007, 22:11   #1
Pfaffen
Multimodder
Pfaffen's Avatar
Pfaffen is on a distinguished road
Project: WorldMap
This is my first Case Mod.
Pfaffen is offline   Reply With Quote
Old 18th Mar 2007, 22:14   #2
ElThomsono
Mod Master
ElThomsono's Avatar
ElThomsono will become famous soon enough
Welcome to bit-tech; in order to get your picture to display properly, you'll have to host it somewhere like imageshack and then paste the code they give you into your post
__________________
If it's broken, I can fix it. But that's ******.
ElThomsono is offline   Reply With Quote
Old 18th Mar 2007, 22:21   #3
Pfaffen
Multimodder
Pfaffen's Avatar
Thanks
Thanks... Also first time posting the results.
Old 18th Mar 2007, 23:21   #4
Mr-IK
Supermodder
Mr-IK's Avatar
Mr-IK is on a distinguished road
Looks pretty nice
Would fit perfectly into one of those old english looking offices
Mr-IK is offline   Reply With Quote
Old 18th Mar 2007, 23:30   #5
ElThomsono
Mod Master
ElThomsono's Avatar
Yeah, that's pretty cool
Great design too
__________________
Old 19th Mar 2007, 00:27   #6
Pfaffen
Multimodder
Pfaffen's Avatar
Close up
Here is a close up of the front of the case. The DVD tray is concealed behind the map. The button for the DVD is walnut (I left it unfinished) The frame for the case is mahogany and the map is glued to .25" plexiglass.
The brass screws (3 per HD) hold the two 250GB SATA drives. I re-enforced the plexi with a smaller plate of plexi. So now the two droves "float" in the case. Actually, they are only affixed on one side.
Here is the case before I glued the map to the plexi.
Old 19th Mar 2007, 01:35   #7
OremLK
What's a Dremel?
OremLK is on a distinguished road
That's really cool. I like the wooden frame. Did you put it together yourself?
OremLK is offline   Reply With Quote
Old 19th Mar 2007, 01:42   #8
greensabbath
Got Wood?
greensabbath's Avatar
greensabbath is on a distinguished road
Your design looks strangely familiar . Good job though.
greensabbath is online now   Reply With Quote
Old 19th Mar 2007, 13:10   #9
Pfaffen
Multimodder
Pfaffen's Avatar
Strangely familiar
greensabbath,
Your case was my inspiration. I was very impressed with yours and like alot of the features yours offered.
Old 20th Mar 2007, 00:11   #10
Pfaffen
Multimodder
Pfaffen's Avatar
Yes, I started about 6 weeks ago.
Old 31st Mar 2007, 00:07   #11
Pfaffen
Multimodder
Pfaffen's Avatar
Another shot
Old 31st Mar 2007, 13:33   #12
Pfaffen
Multimodder
Pfaffen's Avatar
Original pieces
Here are the original pieces.
And some more closeups...
Old 31st Mar 2007, 14:31   #13
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
That looks nice indeed.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 4th Apr 2007, 22:24   #14
Smilodon
The Antagonist
Smilodon's Avatar
Smilodon is a jewel in the roughSmilodon is a jewel in the roughSmilodon is a jewel in the rough
I was going to say the same. Nice work though
__________________
"You have to wonder about a business plan based on the notion that people want to interact with a soda can." -Jeff Salkowski abot the :CueCat
My Flickr
Smilodon is offline   Reply With Quote
Old 7th Apr 2007, 11:21   #15
Spaceraver
Weekend Junkie
Spaceraver's Avatar
Spaceraver is on a distinguished road
sadly you didnt post it as a log.. i'd hand out a few stars.
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard.
Spaceraver is offline   Reply With Quote
Old 7th Apr 2007, 12:41   #16
Pfaffen
Multimodder
Pfaffen's Avatar
Not posting to the work log
I had originally intented on posting this on the work log, but after I read the rules, I figured it would be better served in the finished work sections.
Also, I'm looking for a place to host all the pictures. I have almost 200 picts of the projects. From the very first to the last.
Anyone know where to host that many pictures. I used image shack at first but seem to be limited on the number of pics there.
Old 7th Apr 2007, 12:55   #17
Pfaffen
Multimodder
Pfaffen's Avatar
Close-ups
Here are some closeups.
This is the DVD Drive and the eject button.
This is the front 120mm cooling fan vent.
This is the back with the two 80mm fans.
The case has (1) 120mm fan in the front, (2) 80mm fans in the back, (1) 120mm fan in the PSU that vents to the bottom and the CPU fan. Keeps everying nice and cool. Then again the AMD 64X2 4600+ doesn't run that hot to begin with, but the two SATA drives are kept comfortable.
Old 13th Apr 2007, 00:47   #18
Pfaffen
Multimodder
Pfaffen's Avatar
Moved pictures to photobucket.
Old 10th Jun 2007, 21:36   #19
Pfaffen
Multimodder
Pfaffen's Avatar
90 days, and still running.
On to my next project: Case Mod Fibonacci
__________________
Pfaffen
Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth
Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases
Old 17th Jun 2007, 15:16   #20
wbdog206
Don't mind me.
wbdog206's Avatar
wbdog206 is on a distinguished road
wow that is cool,the map idea is great.
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
