Thread Tools |
#1 |
Brett Thomas
CableCARD ready HTPCs coming soon!
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Group 7 error
So what is being said in the article is that now for the first time there are Digital Sat and cable PCI cards that will take a Common Interface and smart card thus allowing to you view Pay TV services without the need of a set top box?
I may have missed somthing but if thats what is being said then im afraid its incorrect. Twinhan has a range of cards for Sat (DVB-S) Cable (DVB-C) and Terrestrial (DVB-T) that allow the use of a smart card. the sat tuner can be found HERE and you can get it from different sources although they are from the continent these bods sell it (found using google) EDIT:: just done some searching and that CableCARD thing is somthing new to me! I wonder if itll fit into the product above that ive mentioned? EDIT2:: Just remembered as well that there is already a way of getting access to the scrambled screen if you have a digital TV card. I believe the program is called "Poor mans CAM" its an emmulator that provided you have a legal smartcard (and reader) itll emulate the Comman Access Module (Nigra, SECA etc.) and decrypt the signal.
__________________
http://www.ctrlaltdel-online.com 100% Brainless] Last edited by LAGMonkey; 21st Mar 2007 at 15:26. |
#3 |
Multimodder
MPAA always spoil our fun, I've been looking forward to a digital tuner which accepts smartcards. I doubt that the BIOS lock will last very long in the hands of a hacking group.
__________________
Duel of the Duals! Athlon XP2400+ | Generic FX5200 | SOYO Platinum Dragon Ultra | 1GB Crucial Ram | Maxtor PATA 7200 HDDs: 2x40Gb (RAID0), 2x200Gb(RAID0) | Jeantech Phong case | Black DVD-everything | Black Skythe Kama-meter | dreaded blue LED fans (didn't read the description properly) At least it's all one colour scheme now |
#4 | |
Supermodder
SoftCAMs are legal here in Canada because of a wonderful law we have. If someone beams a radio/tv/satellite signal onto your property, and there is no retail or legal way to buy it (Like Dish Network, who do not accept Canadian subscribers), it is perfectly legal for you to descramble and view the signal, as you are in no way defrauding the company supplying the signal ('cause you can't get it anway).
__________________
Robert "Anakha" Johnston Going to Canada on Nov 28th! I'm going home! |
#5 | |
Dark & Sinizter
If that is true, that is pretty cool.
__________________
Nothing here. Go away and dont bother me. |
| sinizterguy |
| View Public Profile |
| Find More Posts by sinizterguy |
#6 | ||
Group 7 error
![]() Disclaimer, Stealing TV is BAD (VERY BAD) and is illegal in the UK. its just not worth the time or the effort.
__________________
http://www.ctrlaltdel-online.com 100% Brainless] |
#7 |
The Froggy Poster
Stealing? I guess we're also stealing the radio too.
Am i the ONLY one of us all who is appaled by the "oem only" crap?
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#8 | |
Dark & Sinizter
__________________
| sinizterguy |
#9 | |
Group 7 error
On the "OEM only" notation i too am very appaled by it.
__________________
#10 |
Supermodder
Now all they need to do is a sky version!
I think the oems only rule is apceptable for now mainly as they get to be guinea pigs, but im sure they will eventually be selling them retail once they've locked the content down. |
#11 |
Dark & Sinizter
Sky or Virgin - Either should be OK.
__________________
| sinizterguy |
#12 | |
Group 7 error
But if you REALLY fancy it, you need one of those DVB-S or DVB-C cards that have a CI (common interface) slot. Then you need a CAM to fit into said slot and then you can use your virgin or sky digital card which is placed into the CAM.
__________________
#13 | |
Supermodder
I think when i upgrade to play HD i think i'll be checking them out. |
| Thread Tools | |
