RSS
Reply
Thread Tools View Mode
Old 1st Apr 2007, 01:12   #1
ulysses Cazuquel
Casemodding Make You Even!!!
ulysses Cazuquel's Avatar
ulysses Cazuquel is on a distinguished road
Silver Dragon "Watercooler" Pag17
As it had promised I am in return with a new project using as main subject known dragons beyond the painting of 3 effects that will be used
Here this picture of the architecture of the cabinet that I will use where his main quality this in the laterals ones that are totally flat contributing to me not to have any problem to do my cuts
Here this the image of my first cut already printed of the two dragons that I will start cuts it in the next
week
ulysses Cazuquel is offline   Reply With Quote
Old 1st Apr 2007, 01:46   #2
Damouse
Multimodder
Damouse's Avatar
Damouse is on a distinguished road
very nice dragon design, i like i like!
argh i hate zoomable pics... could you not? The dragons are too cool for me to avoid this thread
__________________
Dummm.
Damouse is offline   Reply With Quote
Old 1st Apr 2007, 14:08   #3
Bas van der Werff
Multimodder
Bas van der Werff's Avatar
Bas van der Werff is on a distinguished road
What brand & type of case is that?
__________________
Radical Fusion update [9th June 07]
If you're putting more blood into you're project than sweat, double check that you're holding the tool correctly.
Bas van der Werff is offline   Reply With Quote
Old 3rd Apr 2007, 00:17   #4
ulysses Cazuquel
Today it was the day of leaving the lateral ready for the cut tomorrow
I began sanding all lateral ties to be in the metal
Then I made the demarcation to put the drawing of the dragon so that each dragon was perfectly in the same height was very difficult, but obtained success!!
Now it just lacks to remake some lines and to start the cut tomorrow
Old 8th Apr 2007, 04:25   #5
ulysses Cazuquel
here the first and only image of the cuts of the dragons therefore now only when it will be finished
Old 8th Apr 2007, 11:59   #6
Bas van der Werff
Multimodder
And?
__________________
Old 8th Apr 2007, 12:50   #7
dan-ere-07
Supermodder
dan-ere-07 is on a distinguished road
Nice cuts keep it up !!
dan-ere-07 is offline   Reply With Quote
Old 11th Apr 2007, 01:53   #8
ulysses Cazuquel
Old 12th Apr 2007, 20:53   #9
ulysses Cazuquel
Old 12th Apr 2007, 21:16   #10
stormshadow
What's a Dremel?
stormshadow is on a distinguished road
omfg. nice
stormshadow is offline   Reply With Quote
Old 12th Apr 2007, 21:20   #11
ssR
Carbon God
ssR's Avatar
ssR is on a distinguished road
awesome stuff dude. you got probably one of the best if not the best dremeling skills i've seen on those forums
__________________
Galleries: My DeviantArt || My PhotoLight
Gear: A620 || 50D+BG-E2N || Canon EF 17-40 F/4L USM || Canon EF 50mm F/1.8 II || Canon EF 85mm F/1.8 USM || Canon EF 100mm F/2.8 Macro USM ||Canon 70-200 F/4L IS USM || Sigma 10-20mm F/4-5.6 EX DC HSM || Manfrotto 055xprob with 804RC2 head || Canon Speedlite 430EX II
ssR is online now   Reply With Quote
Old 13th Apr 2007, 16:34   #12
dan-ere-07
Supermodder
wow the best side panle ive seen well done
Old 14th Apr 2007, 20:27   #13
JAxen
Multimodder
JAxen's Avatar
JAxen is on a distinguished road
mawd skillz!!
JAxen is offline   Reply With Quote
Old 14th Apr 2007, 20:42   #14
picio71
What's a Dremel?
picio71 is on a distinguished road
__________________
ItaliaModding.it Staff => My project ..:: - P.I.L.S. - Spiderman - Red Devil PC - Picio's PSU - ::..
picio71 is offline   Reply With Quote
Old 21st Apr 2007, 04:25   #15
ulysses Cazuquel
I finished the cuts today them dragons and with them they had been more than 90 cut record
bigger resolution
Old 21st Apr 2007, 05:01   #16
Fozzy
Ultramodder
Fozzy's Avatar
Fozzy is on a distinguished road
That's some damn good cutting
Fozzy is offline   Reply With Quote
Old 21st Apr 2007, 18:37   #17
ulysses Cazuquel
image effect cut dragons
Old 21st Apr 2007, 18:44   #18
TapperSwe
Supermodder
TapperSwe's Avatar
TapperSwe is on a distinguished road
Very nice work
__________________
Build done:The Legacy of King Khufu:
http://forums.bit-tech.net/showthread.php?t=129157
Speakers Done:
http://forums.bit-tech.net/showthrea...129157&page=11
TapperSwe is offline   Reply With Quote
Old 21st Apr 2007, 20:19   #19
Raziekiel
Modder
Raziekiel is on a distinguished road
WOW. Thats all I can say...
Raziekiel is offline   Reply With Quote
Old 22nd Apr 2007, 02:52   #20
ulysses Cazuquel
here an image you to see before and later and seeing the care that I had with the details
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
