Reply
Thread Tools View Mode
Old 12th Sep 2007, 21:30   #181
ulysses Cazuquel
Sex, Casemod & Rock'N Roll!!!
ulysses Cazuquel's Avatar
ulysses Cazuquel has yet to learn the way of the Dremel
the images are not with good quality more serve to show the function of the acrylic supports well that I made
The main reason of I to have bred these acrylic supports was so that the illumination of leds in the letters was more the possible uniform and this to obtain
Tomorrow I finish with a finishing and am deciding if young chicken or not them acrylic supports
support glue in the metal
withdrawal of the glue excess
illumination test
ulysses Cazuquel is offline   Reply With Quote
Old 14th Sep 2007, 20:54   #182
ulysses Cazuquel
Done finishing and ready for the painting
Acrylic supports spotted
Pigment of effect of the Merck that will be using in the ink silver
Next week I go to paint parts of the cabinet to see the result of the effect
Old 18th Sep 2007, 00:50   #183
ulysses Cazuquel
It can seem the same photos but they are not and the reason of I to paint was again because I did not like the form that the ink was on the cut
Tomorrow I must it finishes to another lateral and also to make the finished painting
Old 18th Sep 2007, 03:29   #184
ComputerKing
ComputerKing's Avatar
ComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the Dremel
This is so professional work! I love the clean and perfect work you do! this dragons RULE@!%^ Do it and complete it , hey what about that tons of holes? What they do
well done
__________________
GigaByte Triton 180|GigaByte EP45-UD3R|Intel Q9450|8GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|7TB Space
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 18th Sep 2007, 04:07   #185
Teyber
Teyber's Avatar
Teyber has yet to learn the way of the DremelTeyber has yet to learn the way of the Dremel
i THink all the holes are for the led's. Nice work my friend
Teyber is offline   Reply With Quote
Old 18th Sep 2007, 21:25   #186
ulysses Cazuquel
Originally Posted by ComputerKing View Post
This is so professional work! I love the clean and perfect work you do! this dragons RULE@!%^ Do it and complete it , hey what about that tons of holes? What they do well done
ComputerKing, Acrylic supports made for me for leds
Thanks Very Much Teyber,
Old 29th Sep 2007, 19:43   #187
ulysses Cazuquel
Old 30th Sep 2007, 00:36   #188
ulysses Cazuquel
Old 30th Sep 2007, 14:18   #189
widmod
Supermodder
widmod's Avatar
widmod has yet to learn the way of the Dremel
great detail work there
__________________
Project GTA IV PC : Modding the case and NEW hardware.
Gaffa-Tape is a very simple modding device
I will not apologize for my language skills
widmod is offline   Reply With Quote
Old 30th Sep 2007, 18:20   #190
ulysses Cazuquel
Image supplied for the Merck manufacturer of the pigment Arctic fire showing the effect that they are Turquoise / Silver / Red / Gold.
The result of the painting with the pigment arctic fire painted by me
Old 6th Oct 2007, 01:07   #191
ulysses Cazuquel
connectors mike's for adaptation that I will make in the necessary cabinet because the spower supply able was dislocated for low
Old 10th Oct 2007, 00:31   #192
ulysses Cazuquel
Old 10th Oct 2007, 03:32   #193
ulysses Cazuquel
Old 10th Oct 2007, 05:23   #194
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF has yet to learn the way of the Dremel
Hey ulysses, everything looks great so far! But I think you need to paint that fan grill the same as the case. It looks out of place at the moment.
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 11th Oct 2007, 02:01   #195
ulysses Cazuquel
adaptation of finished connectors and plugs
Old 20th Oct 2007, 20:40   #196
ulysses Cazuquel
the stage is to sandpaper the mass that I used to place the letters in the cabinet
The mass that used to fix the letters Chinese at the case does not set well with that and I will have to try another way
Initially the way I found was putting the letters in a metal mold, and paste in case
This solution I am making to put the letters Chinese
First put a metal plate in the case
After I made the mark and cut
I put the letters and already have photos
This week I paint this part of the case
I am preparing the inside of the Case for painting
That resolved the problem I had the weight that used to hold the letters using a piece of metal and glue
The result was great
Old 21st Oct 2007, 19:49   #197
Asulc
Learning to mod
Asulc's Avatar
Asulc has yet to learn the way of the Dremel
I want to see components in that case!
You have god-like dremel skills!
Just an idea, but maybe you could paint the inside of the case the same color, or just black?
__________________
~Asulc~
Asulc is offline   Reply With Quote
Old 21st Oct 2007, 22:06   #198
ulysses Cazuquel
Thanks Asulc
paint the inside of the case the same color The side
Support for the leds tested only specifying the installation of 27 white LEDs that make this week along with the painting of the inside of the cabinet
Old 28th Oct 2007, 20:53   #199
ulysses Cazuquel
Part of the inner cabinet painted
The result was very good
It has more photos
Old 28th Oct 2007, 20:57   #200
zhangmaster12
Hypermodder
zhangmaster12's Avatar
zhangmaster12 has yet to learn the way of the Dremel
you are a BEAST!
__________________
Project Dimension 2400
zhangmaster12 is offline   Reply With Quote
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
