Reply
Thread Tools View Mode
Old 19th Jul 2007, 21:47   #101
ulysses Cazuquel
Sex, Casemod & Rock'N Roll!!!
ulysses Cazuquel's Avatar
ulysses Cazuquel has yet to learn the way of the Dremel
Originally Posted by Dean MF View Post
Dang! Really nice cuts there!
ulysses Cazuquel is offline   Reply With Quote
Old 19th Jul 2007, 22:48   #102
EmJay
Supermodder
EmJay has yet to learn the way of the Dremel
Looks good! I'm looking forward to seeing how this turns out.
EmJay is offline   Reply With Quote
Old 19th Jul 2007, 23:36   #103
JesterQ
Hypermodder
JesterQ's Avatar
JesterQ has yet to learn the way of the Dremel
WOW ... amazing ...
__________________
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised.
JesterQ is offline   Reply With Quote
Old 20th Jul 2007, 21:43   #104
ulysses Cazuquel
definitively finished structure
Old 27th Jul 2007, 05:56   #105
ComputerKing
ComputerKing's Avatar
ComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the Dremel
lol that's look like turbo rocket or some thing I love the unit it's an awsome idea well done and good luck
__________________
GigaByte Triton 180|GigaByte EP45-UD3R|Intel Q9450|8GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|7TB Space
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 1st Aug 2007, 04:13   #106
ulysses Cazuquel
Now with the purchase of 100 record of cuts of dimensions 25mm x 0,7mm I go to come back to make mine cuts in the project
Initially I will make the cut of the tribal drawing to place in box of the source
Tomorrow I initiate the cuts with many photos
Old 1st Aug 2007, 04:19   #107
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF has yet to learn the way of the Dremel
Are those the discs you use to cut your awesome designs into the case?
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 1st Aug 2007, 13:55   #108
The X
Minimodder
The X's Avatar
The X has yet to learn the way of the Dremel
Originally Posted by ulysses Cazuquel View Post
Awesome cuts !!!
The X is offline   Reply With Quote
Old 1st Aug 2007, 20:21   #109
ulysses Cazuquel
Thanks Dean MF
Most important 07mm is the dimension of the disc cuts of 25mm x 0,7mm
Here first the tribal one cut and tomorrow I cut the other tribal one and later I cut drawing in acrylic the same to make the effect
Old 1st Aug 2007, 20:25   #110
Dean MF
PC Freak!
Dean MF's Avatar
Wow dude! Really amazing cuts! I wish I had your steady hands!!
__________________
My PC:
Old 1st Aug 2007, 20:27   #111
SPQQKY
Evil Modder
SPQQKY's Avatar
SPQQKY has yet to learn the way of the Dremel
Those small cutting wheels are the bomb, they slice a lot better than the thicker ones. They just come apart so quick. Have you tried the thin diamond wheel yet, Ulysses?
Great detail though, really nice. Keep up the good work.
__________________
I could be bounded in a nutshell and count myself a king of infinite space, were it not that I have bad dreams.
Core2Duo E8400 @ 4GHz - Gigabyte GA-EP45-UD3P - 4 x 2 GB G.Skill Pi Black-6400C4 - eVGA GeForce GTX 260 - Auzentech X-Plosion
1 x 250GB and 2 x 300GB Barracuda - LaCie 1TB BD - Corsair CMPSU 620HX - etc., etc.
SPQQKY is offline   Reply With Quote
Old 1st Aug 2007, 22:04   #112
GuitarBizarre
banned
GuitarBizarre has yet to learn the way of the Dremel
Your dremel work is making god jealous...keep it up!
GuitarBizarre is offline   Reply With Quote
Old 2nd Aug 2007, 19:33   #113
ulysses Cazuquel
Thanks SPQQKY, GuitarBizarre and Dean MF
I did not use disk cuts of diamond
I finished the cut todaday second tribal it
I also madethe frame of the cover of box needing some details that i must it finishes tomorrow
Old 3rd Aug 2007, 19:35   #114
ulysses Cazuquel
Today I made the finishing in the one of the dragons using disk cuts of lesser that to obtain with the cuts of the tribal ones
Now it lacks only plus a dragon to make finishing
Old 3rd Aug 2007, 19:41   #115
Dean MF
PC Freak!
Dean MF's Avatar
Honestly dude. You must be an alien!! No human being can make dremel cuts like that!!! AMAZING!!
__________________
My PC:
Old 4th Aug 2007, 00:48   #116
MoRBiD
Multimodder
MoRBiD's Avatar
MoRBiD has yet to learn the way of the Dremel
he has lazers on the ends of his fingers.....
they is wicked cuts dude ... orsum infakT
keep it up i might get you to carve some of these into my arms ...
__________________
DiBRoM
MoRBiD is offline   Reply With Quote
Old 5th Aug 2007, 00:39   #117
ulysses Cazuquel
Old 5th Aug 2007, 04:38   #118
Teyber
Teyber's Avatar
Teyber has yet to learn the way of the DremelTeyber has yet to learn the way of the Dremel
if you can do that with a dremel... please go buy yourself a scroll saw!
and whad did you use to cut out your pci covers?
Teyber is offline   Reply With Quote
Old 5th Aug 2007, 05:09   #119
Dean MF
PC Freak!
Dean MF's Avatar
Oh man! That looks really great!
__________________
My PC:
Old 8th Aug 2007, 01:16   #120
ulysses Cazuquel
Originally Posted by Teyber View Post
if you can do that with a dremel... please go buy yourself a scroll saw! and whad did you use to cut out your pci covers?
Teyber,
to make the cuts in the acrylic I used Rotary tools and any Cutting Wheels
Now this mine I finish cut made in this week
They are Chinese letters with meaning of Silver Dragon
Tomorrow I rank photos of where I will go places these letters
The names Silver and Dragon in Chinese
Here cut and lacking finishing
Cut finished with finishing
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
