Reply
Thread Tools View Mode
Old 14th Aug 2007, 17:11   #141
ComputerKing
ComputerKing's Avatar
ComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the DremelComputerKing has yet to learn the way of the Dremel
AWSOME.... WTF damit wooot nice work
good luck.. more
__________________
GigaByte Triton 180|GigaByte EP45-UD3R|Intel Q9450|8GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|7TB Space
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 14th Aug 2007, 21:21   #142
ulysses Cazuquel
Sex, Casemod & Rock'N Roll!!!
ulysses Cazuquel's Avatar
ulysses Cazuquel has yet to learn the way of the Dremel
Updates of today
I fixed the architecture of box in the case
I placed the letters in the case that they need to be painted or to be chromed
I also placed the Ankh cross
Tomorrow I will try to make an illumination has tested to try to show the effect
ulysses Cazuquel is offline   Reply With Quote
Old 14th Aug 2007, 21:36   #143
ComputerKing
damit ****!!!!! holy ****....
Sexy hot cutting.... WTFFFFF how you do that.... you are a magican
__________________
Old 15th Aug 2007, 01:53   #144
wbdog206
Supermodder
wbdog206's Avatar
wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.
great work with the dremal it looks
like it's been laser cut.
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 16th Aug 2007, 04:43   #145
ulysses Cazuquel
Illumination has tested basic to see the effect of the illumination on the cuts and the effect of leds
In the final illumination I will go to use the blue color with 4 cathods and will use leds white
Old 16th Aug 2007, 04:48   #146
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF has yet to learn the way of the Dremel
Wow ulysses! The illumination effect is awesome!
What is your plans for the front panel?
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 16th Aug 2007, 10:17   #147
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
I agree it looks awesome. good choice on the green lights
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 16th Aug 2007, 17:08   #148
ComputerKing
Just WOWOWOWOOW
__________________
Old 17th Aug 2007, 17:55   #149
ulysses Cazuquel
Originally Posted by Computerking View Post
Just WOWOWOWOOW
Next and I finish cut of the project
I will start the cuts tomorrow
Old 17th Aug 2007, 20:05   #150
Dean MF
PC Freak!
Dean MF's Avatar
The blue will look awesome with the mother of pearl this case will be painted!
__________________
My PC:
Old 18th Aug 2007, 00:47   #151
ulysses Cazuquel
Perfect friend Dean MF therefore I chose the blue color mainly for the painting
I thank to each commentary its very
Old 18th Aug 2007, 14:28   #152
ulysses Cazuquel
First image of the cut of the initiated dragons today
Old 18th Aug 2007, 15:44   #153
ComputerKing
WTF NICE !!!!!!!!!!!!!!!!!!!!!! wowowo
__________________
Old 19th Aug 2007, 18:49   #154
ulysses Cazuquel
today I finished of I cut to the dragons lacking some details that I will finish tomorrow
Tomorrow already start to remake the cuts of the dragons stops more later 2 days of finishing in the cuts
Old 19th Aug 2007, 18:51   #155
Dean MF
PC Freak!
Dean MF's Avatar
Dude, you need to borrow me your hands for a day or two! Damn! You cut like a laser!! You sure you're not an alien?
__________________
My PC:
Old 19th Aug 2007, 19:46   #156
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Edward Scissorhands-only with dremels Ulysses Dremelhands!
Seriously, dude you are incredible! -both your design and rock-steady cutting.
Cheapskate is offline   Reply With Quote
Old 22nd Aug 2007, 21:24   #157
ulysses Cazuquel
Thanks Cheapskate and Dean MF
more two days of finishing and I will finish the dragons
Old 22nd Aug 2007, 21:52   #158
KaotiK
Modder
KaotiK's Avatar
KaotiK has yet to learn the way of the Dremel
Immense cutting skills there. Its a work of art.
KaotiK is offline   Reply With Quote
Old 23rd Aug 2007, 10:28   #159
ComputerKing
HELL! dude you not real! you are a lazer cut machine talk with use! Impossible! this is impossible! HOW, I can't think that be done with dremel! dude you have QX6850 on your head to do that, DAM. Well done, Good luck and Take care and Show more Amazing work.
__________________
Old 23rd Aug 2007, 22:59   #160
ulysses Cazuquel
Thanks very much KaotiK, I go continues making art so that thus you it continues seeing my projec
Thanks Computerking
I am only a little sad because for the time being I did not have as to film cutting
to place here because I know that many would like to see
photo of today with more details done and tomorrow I finish later painting
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
