Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Deep fried PCs on the market within a year...
__________________
#2 |
Ultramodder
I love to see a mod that uses oil and watercooling at the same time. Ok it may be useless somehow but i imagine the tubes running into the oil embeded system. watercooling the cpu/gpu(s)/chipsets.
I know i am eh.. weird..
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#3 |
DUR HUR
I've seen someone with a oil cooled system lik this, it ran at like -20 or something stupid, dunno how he got it that cold. His motherboard bas basically a big block of ice
#4 |
Supermodder
I participated in a looong forum discussion about this over at procooling.com (i think it was). The end conclusion was that it does work, but it has a tendency to kill your caps, and you should probably not do this with your favorite rig. if anyones interested I'll see if I can dig up the thread...
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
#5 | ||
Don't panic!
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#6 | |
6 screens / 1 card
__________________
It's not about how life treats you, it's about how you treat life. |
#7 |
Player Character
bit-tech Staff
I think the main problem with oil cooled rigs is that you need to be sure you won't be taking any part of the system out after the oil is in there. What do you do if you want to swap your graphics card out or swap your RAM into a new computer and its covered in cooking oil? Wash it?
__________________
#8 | |
6 screens / 1 card
Welcome new staff guy
__________________
#9 |
Player Character
bit-tech Staff
Nobody loves monkey island as much as I do. And anyone who even thinks they do...well, they fight like cows!
__________________
#10 | |
6 screens / 1 card
Mr. dairy farmer, you can't start the fight with a comeback.
__________________
#11 |
Ultramodder
"Look behind you... a three headed monkey!"
What a classic
__________________
#12 |
Peanut Extrordinare!
"Your fiancee' looks like a monkey in a neglege!"
*Note to self, never use comebacks from games in a real life situation*
__________________
#13 | |
hmmmm....
But it would be a huge hassle to upgrade, it would be much heavier to move, I can't really see any benefit, possible more consistent temps over time as dust is less likely to accumulate around the heatsink preventing flow.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#14 |
Spoon? What spoon?
one thing people have overlooked here is that if regular cooking oil is used it will slowly cause chemical reactions with some of the board components, creating very tiny free-floating electrically conductive particles.
It would be quite fine in the short term, but over the long term and given the sizes of contacts/traces these days it would not be fun after a few years. The charges of the contacts would also be a draw for the debris (a la electrostatic painting) I also don't foresee this being able to handle an 8800GTX SLI setup without additional cooling, but for that hassle you might as well use the secondary cooling system as the primary in the first place. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#15 |
I *am* a Dremel
It's always been a dream to do a computer like this, but there's monetary and practical considerations. Sounds like they are trying it first with servers/ rackmounts etc systems not desktop PC's my concern is not so much with the frying of the computer, but the what if situation I've personally dropped or dented a computer case before, but I can just imagine the first time this thing springs a leak or is dropped and you have a gallon plus of oil dripping over your desk or what not (also the comp would overheat and shutdown) That's my concern for the practicality of such a system
as far as the ability of such a system to do significant cooling I have faith. these oils would have a higher specific heat (IIRC) than air as such it would take more energy to heat up than air, convection and heatsinks would handle flow. and radiation/sublimination would release the energy into the air, proof-of-concept systems have been made before. Also a decent amount of electrical transformers which handle much higher voltage and temperatures are oil submerged/cooled. there also might be an aspect of maintainence over the years though in terms of contamination and such |
#16 |
Ultramodder
Just imagine if you somehow cracked open the case...oil all over the place!
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD. |
| Neogumbercules |
| Find More Posts by Neogumbercules |
#17 |
Bwahahahahaha
Following on from what metarinka was talking about, the server market is about the only place an idea like this could gather ground.
If you think about the average amount of power used by fans in your typical 2-4U server. They're never pansy-fans, and I'm sure it adds up, particularly over the years (and with an entire farm). 10W x 3 = 30W? Even if that's extreme, and per-server, it's a difference that could turn up some interesting TCO differences over a 5-year period. Also, if Intel can sell new chips based on lower-power requirements, surely Very-PC could sell their new server-cooling solutions based on the promise of eliminating the need for powerful (and noisy!) fans in the system. It's not as nuts as it sounds, and especially considering I'm due to be working in an office with a number of servers locked up in a £1,800 sound-proofed rack -- something I'm sure the management would rather have not forked-out for! Though there are problems, of course. Fumes? If the oil gets too warm, it could begin to evaporate, causing some unpleasant smells (chips in the morning, afternoon and evening?) There's also the possibility of needing to top-up the oil, and what may be the most important consideration: How long until the oil needs replacing? If that winds up being too often, then I should imagine any benefits in TCO would go straight out of the window with the downtime required to "change the server oil". But pushing the reduced power requirements, they could be on to something, should they manage to squash any bugs in the theory.
#18 |
Supermodder
Well dug around and found the thread Here (Warning close to 400 posts).
I think they tried several types of oil, and yes smell was one drawback (as far as I remember) I myself managed to get hold of 25L of transformer oil to try it out, but never got any further than that. If anyone reading this lives in Copenhagen and wants to try this I'll be happy to donate the oil. This oil is probably some of the best for the job as it's designed to cool electronics (at very high voltage), only drawback is that as far as I remember also smells quiet bad.
__________________
| Dr. Strangelove |
#19 |
Spoon? What spoon?
If you were to do an entire rack, you might as well have some sort of very large low-speed fan over a radiator and circulate the oil from all the systems through a cool and filter loop.
If done that way I can see this being quite practical for servers. Desktops will still be the domain of air and water cooling though. |
| Bluephoenix |
#20 |
As long as the Raven flies
BRB, My pc needs an oil change!!!
__________________
Intel Core 2 Duo E6700, Abit AW9D-MAX Intel 975X, GeIL 4GB PC6400C4 800MHz Ultra Low Latency, BFG GeForce 8800 GTX OC2, Western Digital Raptor 150GB, Creative X-Fi Xtreme Music, Corsair HX 620W, CoolerMaster Stacker 830, 24" Dell 2407 Flat Panel, Logitech G11 Keyboard, Logitech G5 Mouse |
| Kurayamino |
| Find More Posts by Kurayamino |
| Thread Tools | |
