Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
DisplayPort 1.1 approved by VESA
__________________
#2 |
Madeira's banana is the best!!!
cool... it looks like an usb......
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#3 |
Et arma et verba vulnerant
UDI looked more impressive tbh. 10.8GBit/s hardly gives any room for increased resolution
__________________
[AMD A64 2800+ + Zalman 7700][MSI K8N Neo Platinum][1GB Corsair PC3200][Leadtek Geforce 6600GT][Seagate Barracuda 7200.7 80GB + Maxtor Diamond Max Plus10 200GB + Maxtor Diamond Max16 120GB][Plextor PX-716 DVD-RW + 2x Plextor Premium 52x32x52 CD-RW + 16x Samsung DVD][Coolermaster ATC-201 BXT][Antec TruePower 430][Dell 2405FPW + Mitsubishi Diamond Pro 2070u][Logitech MX1000][Matias Tactile Pro][Griffin Technology PowerMate Black] Email Me |
#4 |
whatever
will it mean the death of vga and dvi? yes and no...
vga yes.. dvi no... i bet graphicscards will have one displayport 1.1 and a dvi port in the future... |
#5 |
Why not? I own a domain to match.
I don't care until there's at least four outputs per card. Seeing how monstrously huge some recent video cards have been, I don't think it's asking for that much if they'll be able to fit them.
</display whore>
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#6 |
Dark & Sinizter
Sounds good - as long as it makes it smaller and easier to plug in and plug out.
Dont really see the need for higher resolutions than those supported by Dual-Link DVI which this will support - but there is always someone out there who wants more.
__________________
Nothing here. Go away and dont bother me. |
| sinizterguy |
| View Public Profile |
| Find More Posts by sinizterguy |
#7 |
Hypermodder
good. any actual standard that is open and not privatized/fee-based like HDMI which will make products cheaper. Also, it's smaller than DVI and VGA. I've been waiting for this to come out for like 6 months. I read an article on it on Cnet and just thought it was a good idea put on hold... glad I was wrong.
Question: What is the best way to get both the video an audio from the computer (assuming it has a DP1.1 port) to the Display (the Moniter/Projector/Plasma) and also to your Surround Sound System (Receiver) with only one direct path? My guess is that you would have to take the cable from the back of the video card to the receiver and have a DP1.1 port on the receiver (which would take care of the audio) and then from the back of the receiver to the Display. Am I right? Basically it's the same for HDMI I would expect. |
| devdevil85 |
| Find More Posts by devdevil85 |
#8 |
Supermodder
What’s the point of another port? HDMI is the digital standard in the HD AV era and PC's are trying to integrate more in an AV setup why have such a similar yet incompatible port? Why not suck up the fees and use HDMI. Seems pointless to me.
__________________
Don Dan |
#9 | |
Supermodder
__________________
NEW!!! X2 4200+| 2 x XFX Geforce 6600 gt in SLI | Asus A8N-SLI Deluxe | 4 x hitachi 250 gb sata hdd + Maxtor 160 usb 2.0 total of 1160 GB | 2 x 1024 MB DDR-400 (2 GB ) | Tagan U force 580 Watt | Saving money for an macbook and an Iphone (2nd edition)
#10 |
Dark & Sinizter
Because you have to pay to have an HDMI port. For consumers to have cheaper products, a free port like the declared one is required.
__________________
| sinizterguy |
#11 |
DUR HUR
Spiffy, VGA/DVI connectors are a right ******* to use.
#12 |
I'm not a modder.
Agreed, and how many time have you suddenly got a blue tint to your screen when it comes a bit loose?
In my setup, the weight of the cables puts a great strain on the sockets on the back of my gfx card, so I would love something that would fix this (they are currently supported with electrical tape)
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#13 | |
Supermodder
__________________
It sure took me a long time to realize I hadn't changed my forum settings since returning from Canadia-land. |
#14 |
complete spanner
Considering the low licencing costs for hdmi, manufacturers should have swallowed the nominal fees for the benefit of the consumer.
__________________
My sweetest downfall |
| genesisofthesith |
| Find More Posts by genesisofthesith |
#15 |
hmmmm....
I'm all for it, as long as bandwidth can be increased ala dual link. Not having to screw it in is a bonus, especially when reaching around behind the monitor or computer feeling your way around, then having to screw it in. DP for the win. UDI would be better, although with no support I don't think it will become widespread.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#16 |
Spoon? What spoon?
on the monitors themselves I think that they will have more ports, not less
probable list: VGA DVI DP Component HDMI at least we can hope that they include some sort of split-screen/switching in the panels. The BenQ 24" is a perfect current-day example of this Last edited by Bluephoenix; 30th Jul 2007 at 18:59. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#17 | |
mother into a board?!
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#18 | |
Ultramodder
__________________
PC (Now out of use): Athlon 64 3000+ Winny | Asus A8N-SLI | 1024mb OCZ Premier | 6600GT 128mb | 160GB WD | NEC 3520 DVDRW | Coolermaster Centurion 530 | Hiper Type-R 480w Laptop: Dell Studio XPS 13 | Core 2 Duo P8600 2.4ghz | 4gb Ram | GeForce 9500M 256mb | 320gb 7200rpm | DVDRW | 13.3" LED WXGA |
#19 |
what?!, your plug has an AC adapter sort of thing?!?! Its the only thing that I can think off where it can possible brake the port.
Look, the plug is design to hold that weight, else stop buying crazy products. In My opinion, it is just some crappy thing so that when you buy a new video card, and you came home, you realize that it doesn't fix because, it takes a new plug. So you change your mobo, so that means a new CPU, new RAM type, and oh look a new SATA cable, so you need to change your HDD. Moreover, the Mobo take a new power plug, so you need to change the PSU. Then guess what, the PSU doesn't fit in your case, so you need a new case, and finally when you thing you can save your IDE Optical drive.... no they decided to not have that plug anymore on the mobo... and guess what.. the only device you can plug to have an optical drive is this Blu-ray/HDDVD/DVD/CD combo reader/burner... In other words, you just purchased a new computer... Ok I TOTALLY exaggerated, but you get my point.
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! Last edited by GoodBytes; 8th Apr 2007 at 17:14. |
#20 |
Spoon? What spoon?
@goodbytes - not really, smart buying decisions and the fact that standards such as DVI, VGA, and DP exist ensures that such an event will not happen.
the only way such a thing would happen is if you were using a computer made around 2001 and wanted to put an SATA HDD and a DP card in it. (the DP card wouldn't be an issue if an AGP vers is made) |
| Bluephoenix |
| Thread Tools | |
