Go Back   bit-tech.net Forums > Recreation > Photography, Art & Design
Reply
Thread Tools
Old 12th Apr 2007, 16:17   #21
Jumeira_Johnny
16032 - High plains drifter
Jumeira_Johnny's Avatar
Jumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run CrysisJumeira_Johnny can run Crysis
To add to the CF debate, I use Ultra II's and the only time I really feel the pinch in speed is car races and air shows. That is with a 22 frame RAW buffer at 5fps. With the 400D you have a 27 frame buffer for JPG and 10 for RAW, at 3 fps. That's not bad, you'll just have to keep your bursts down to 5 at a time if you shoot sports. That will let the buffer do it's job without it getting totaly full and having to wait for it to write the card. I carry 2x4gb, 1x2gb and 3x1gb and routinely fill them all up. I bracket a lot and shoot a lot, so that's me. A 4gb card should hold you until you know how much you are going to be shooting. But at 35GBP, I would get another 4gb.
__________________
Slumbering Death™|Dachshund of War™|TerrierX™|Macbook Pro|1967 Pontiac Catalina|360# Anvil|2 Burner Gas Forge|135 Amp MIG Welder
Jumeira_Johnny is offline   Reply With Quote
Old 12th Apr 2007, 18:25   #22
smashie
Cupid Stunt
smashie's Avatar
smashie has yet to learn the way of the Dremel
Well for my every day bag I use one of these
I'm not going to say buy spare batteries because unless your on a bit of a mission the standard battery lasts very well. But if at any point in the future you do need replacement batteries then Stirlingtek do very good replacements at a good price.
smashie is offline   Reply With Quote
Old 12th Apr 2007, 18:36   #23
yodasarmpit
Ban-Saber
Moderator
yodasarmpit's Avatar
yodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpityodasarmpit is almost as Godly as yodasarmpit
Do buy spare battery, because when you do leave home with a half drained battery, the spare will be a lifeline.
Always having a fully charged battery at hand is much better than having to wait for your one and only battery to charge.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
www.yodasarmpit.com
clickr my flickr
yodasarmpit is online now   Reply With Quote
Old 13th Apr 2007, 08:06   #24
Hwulex
Freerider
Hwulex's Avatar
Hwulex has yet to learn the way of the Dremel
Very true. I never bother charging the in-cam battery as I know I always have a fully charged spare in the bag and I'm normally only going out for a few shots. Only if, like for sports events, I'm gonna be out all day shooting then both will be charged the night before.
__________________
Clickr my Flickr
Hwulex is offline   Reply With Quote
Reply
Tags
camera
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
