Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
PowerColor Radeon X1950 Pro SCS3
__________________
#2 |
DUR HUR
You certainly gave that card a grilling
I think thats probably enough grill jokes for one day
#3 |
Supermodder
Good card, though 512 megs seems a bit standard for any 950 pro in production these days. Considering the pcb is identical for both the 256 and 512....
I've really wanted a 8xxx series card since they've come, but I'm waiting for the evil Nvidia to morph to 80 nano meter like AMD has done here. That BFG water block card on the right side of my screen would be alot more tempting if it were 80-or dare I say 65 nm! And of course GDDR4! The industry is entirely to comfortable on ddr3..
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs |
#4 |
I feel your presents.
Page 1 - last para - "and trail versions" - 'trial'
Page 2 - para 4 - "Although it’s a 512-bit internal memory interface, it’s still a 256-bit connection to the 256MB of local GDDR3 memory, though." - last 'though' not needed Page 2 - para 8 -"That’s not all though, as there is more cooling on the card than the heatsink we’ve been taking the piss out of for the last couple of pages though." - not sure I agree with cursive words on a professional site, but BT:NG and all that.. also, last 'though' not needed. Page 2 - para 10 - "Moving onto the selection of ports on the card’s PCI bracket, there’s a pair of HDCP compliant dual-link DVI ports capable of running a pair of monitors at resolutions up to 2560x1600 each." - use of 'pair' in one sentence, perhaps 'duo'? Page 2 - last para - "This is like what most other board partners.." - omit 'like' to make the sentence sound less chavvish Page 3 - bullet points - no need for semi-colon use after each bullet point Page 6 - para 1 - "There are also real time shadows and a subtle HDR lighting effect too." - either 'There's..', omitting 'are' OR omit 'a' and add an s to 'effect'. Page 7 - para 2 - "around your ankles with no where to go." - nowhere, one word Good review. The difference between a 7900GTX and 8800GTS is quite staggering.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#5 |
Pewlius Caesar
bit-tech Staff
thanks for the repetitions/typos!
__________________
#6 |
Ultramodder
I don't know if it was mentioned but I don't think you can do crossfire with the cooler in the way.
#7 | |
Pewlius Caesar
bit-tech Staff
__________________
#8 |
I pickle they
wow that's one humungous grill on that card O_O
#9 |
The Froggy Poster
Well you COULD do CF with internal connectors, you'd just need long ribbons or to have PowerColor remove a few fins so the bridges would fit
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#10 | |
Ultramodder
#11 |
The Froggy Poster
Well something like what ASUS gives you for their 680i motherboards.
And there's no cutting of the videocard involved, just some snipping of sink fins
__________________
#12 |
Pewlius Caesar
bit-tech Staff
If anyone was going to do anything like that, I'd guess it'd be one of the many modders on this forum. There's bound to be someone crazy enough!
__________________
#13 | |
I pwn all your storage
#14 |
Ultramodder
Oh I'd do it too. But I'd sooner watercool it and keep the stock HS for RMA's
| Thread Tools | |
