Go Back   bit-tech.net Forums > Recreation > Photography, Art & Design
Reply
Thread Tools
Old 15th Apr 2007, 02:47   #1
Bruno_me
Fake-ad‎min
Bruno_me's Avatar
Bruno_me has yet to learn the way of the Dremel
[04/07] Bead of water on a sealed table
edit: I posted the wrong version, it's cropped now
__________________
jello!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bruno_me is offline   Reply With Quote
Old 15th Apr 2007, 06:27   #2
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
I like this, simple and effective, but the compression on the forum makes it look a lot worse then it is when you click on it to view original size.
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 15th Apr 2007, 21:57   #3
Hwulex
Freerider
Hwulex's Avatar
Hwulex has yet to learn the way of the Dremel
Great job on focus, there's loads of detail in that droplet. However, the composition lets the photo down. I'd crop it so the drop is in the bottom right of the frame then up and left from there so the grain kind of falls away in to the background. Basically the top left corner as a crop on its own.
__________________
Clickr my Flickr
Hwulex is offline   Reply With Quote
Old 20th Apr 2007, 00:36   #4
Pygo
Rick Relixed
Pygo's Avatar
Pygo has yet to learn the way of the Dremel
Great shot Bruno_me. This is reminds me of how much I want a good macro lens.
I do agree with Hwulex that a top left corner crop may look better.
What camera did you shoot it with? And what lens?
Pygo is offline   Reply With Quote
Reply
Tags
potm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
