Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Gratuitous Naked Penryn Die Shots
__________________
#2 |
I pwn all your storage
So that's a good few thousand dollars dead right ther.
#3 |
Hypermodder
lol, better if there was a shot of it smashed on the floor.
#4 |
Supermodder
It's neat and all, but uh.. nothing I can do with that pretty coloured wafer of silicon. I'll get moist when it's in a nicely boxed package with my delivery address on it!
However I am sure there are those who will be replying to the article with one hand only..
#5 | |
Senior Super Douche
#6 | |
Richard Swinburne
bit-tech Staff
![]() /note to self, don't wear tight underwear.
#7 |
Supermodder
^^^ doh!
/curse you lucky people!
#8 |
I Mod, Therefore I Own
why do they use round wafers? wouldnt it be less wasteful to use square ones?
#9 | |
Multimodder
__________________
Make fruit hats for pets. |
#10 | |
4-storey MEGA WEDGIE! |
#11 | |
#12 | |
glourious bacon?
You mean cpu's are grown to order?
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#13 |
Silicon is a crystal, it's grown to a wafer.
#14 |
http://en.wikipedia.org/wiki/Czochralski_process
k so its basicaly cos they have to rotate the thingy to get a solid crystal, squares are a bit hard to rotate properly like that
#15 |
Pewlius Caesar
bit-tech Staff
yes, it's to do with the way single crystal Silicon is "grown". They use the same technique for the materials used in aircraft engines, as impurities mean a potentially lower melting point in that particular scenario.
__________________
#16 |
glourious bacon?
Well, blimey. Every day is an education. Is there a theory about that a particular place on a wafer always produces the best dies?
__________________
#17 | |
Hypermodder
| devdevil85 |
| View Public Profile |
| Find More Posts by devdevil85 |
#18 |
Why not? I own a domain to match.
Well towards the edges tend to be somewhat worse. Back when my dad was engineering stuff along those lines, I actually tossed in a solution that helped fix their problematic data quite a bit.
There's a little alignment notch at one point along the edge. Err, not point as it's a circle... but you know what I mean. Anyways, as it turns out, the tiny amount of extra surface area you get along the edge because of that can really screw with heat uniformity data. Toss that point (and, more likely than not, the chip that would be built there), and the data gets a surprising amount better. It's true for the whole edge area (it adds something like 900mm^2), so the edge will cool slightly faster, and as a result might not always have as good of a yield. As dies get smaller though, we can fit more chips per wafer and help counteract this.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
| Thread Tools | |
