RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Apr 2007, 08:55   #1
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
The_Pope is on a distinguished road
Wolfdale versus Core 2 Duo
http://www.bit-tech.net/news/2007/04...us_core_2_duo/
The_Pope is offline   Reply With Quote
Old 19th Apr 2007, 08:58   #2
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
Wolfdale is looking very nice.
Its Socket 775 I guess, with DDR2 or what?
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 19th Apr 2007, 10:03   #3
chrisuk
Modder
chrisuk is on a distinguished road
From what I remember they are pin compatible with Core 2 Duo, so all that should be needed is a BIOS update.....I could be totally off mind you!
There looking pretty good though, will def have to consider when I finally decide to part with my hard earned cash for a new rig.
chrisuk is offline   Reply With Quote
Old 19th Apr 2007, 10:28   #4
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Yes, socket 775 with DDR2. They should be compatible with current chipsets, subject to BIOS updates.
Were the processors in this demo identically clocked, or was the Wolfdale clocked higer and/or on a 1333 FSB with the Conroe on 1066?
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 19th Apr 2007, 11:53   #5
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
They'll also be supported by Bearlake, too.
Tim S is offline   Reply With Quote
Old 19th Apr 2007, 14:20   #6
Dr. Strangelove
Supermodder
Dr. Strangelove's Avatar
Dr. Strangelove is on a distinguished road
Or do you feel the need to wait until bit-tech gets a-hold of one to really see if it's worth your cash?
How can you even ask such a silly question?? Naturally we want you to get a few into your hardware testing dungeon, and test it till it sweats
__________________
If it isn’t broken, fix it.
If it is broken, mod it till it looks like it's meant to be broken.
Dr. Strangelove is offline   Reply With Quote
Old 19th Apr 2007, 15:06   #7
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
after you guys test it i will see if i buy it or not.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is online now   Reply With Quote
Old 19th Apr 2007, 21:47   #8
JaredC01
Hardware Nut
JaredC01's Avatar
JaredC01 has a spectacular aura aboutJaredC01 has a spectacular aura about
After the new AMD's come out to compete with the new intel, at that point I will decide which processor to buy...
__________________
|i7 920||EVGA Classified E760||6GB Ballistix Tracer 1600||3x XFX 4890CF||X-Fi Fatality||4x WD Black 1TB RAID 10||Revolution 1050w||Corsair Obsidian 800D|
|E8400 @ 4.00 w/ NH-U12P||GA-EP45-UD3P||8GB G.Skill @ 445MHz 5-4-4-12||4870 512MB||X-Fi XM||WD Green 1TB||Tagan BZ 700w||Antec P182 Gunmetal|
In Progress||Current Rig -- If I helped you, please give me rep!
JaredC01 is offline   Reply With Quote
Old 20th Apr 2007, 00:58   #9
wafflesomd
Hypermodder
wafflesomd's Avatar
wafflesomd is on a distinguished road
Here's useful thought.
Lets start actually writing software that actually takes use of multiple cores!
Sheesh, almost nothing, is multi threaded yet.
wafflesomd is offline   Reply With Quote
Old 20th Apr 2007, 11:16   #10
Dr. Strangelove
Supermodder
careful that's a big nono, Intel and AMD sure don't want us to figure that one out cause then why would we buy the 16 cores slapped in one package deal CPU?
You are naturally completely correct, I would say dual core (or dual CPU) is great (yeah you can alt-tab out of games without having to wait 5min), 4+ cores who needs them? (apart from specific server programs made to use multiple cores)
__________________
Old 20th Apr 2007, 13:23   #11
mclean007
Officious Bystander
mclean007's Avatar
Agreed, quad core has very little application on a consumer desktop at this stage. Yeah you may be able to encode Xvid, run a virus scan, run a Photoshop batch conversion and play SupCom all at the same time, but who really does that? Until games like Alan Wake, that really take advantage of multicore, come out, dual core is ample for 99% of home users and quads should stay where they belong - workstation and server rigs.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
