Thread Tools |
#1 |
Geoff Richards
Moderator
Xbox 360 Elite ripped open and examined
#2 |
Don't panic!
Looks nice - I'm still in two minds about the processor though, I'd say it's just a revised die, with a new mobo version. If it were a 65nm part, I suspect, as you guys thought, that it'd be a lot smaller.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#3 |
I have a dremel.
I've just this week purchased a Premium XBOX 360 (white) as I didn't see the point in waiting any longer for the Elite version.
Interesting to see it ripped apart though! Last edited by Lazlow; 24th Apr 2007 at 10:44. |
#4 |
A motorbike of jealousy!
I'll be getting one in September.
Its the black that does it for me, oh and when they finally crack it properly that 120gig hdd will come in handy. |
#5 |
Modder
if they could get an XMBC-type media player working on the 360 I would buy one tomorrow, my xbox1 struggles with some of the HD content that can be dl nowdays
__________________
AB9 Pro C2D E6600 - 512MB 8800GT - Xfi - 4GB and 800GB of SATA storage |
#6 |
Multimodder
when its assured its a 65nm version i will get one in the summer
#7 |
Supermodder
Sorry, stuck at work and most game sites are blocked., so - what's the UK release on the Elite edition? Plan to sell the old and get the new, merely for the 1080p. Sad huh?
#8 |
Holder of the sacred iron
I believe the release date for the elite in the uk is sometime in november. Seems you guys have to wait a little while for the elite across the pond huh?
In any event this is a good move by microsoft. It is almost like releasing a totally new console but rather they are just updating an existing one. Though they are used to just 'updating' things instead of starting from scratch anyway. I dont see why whether or not this is a 65nm core would influence whether or not you buy one. Running cooler and taking less power are two great reasons. But the market for the elite seems to be a higher status and more involved gamer than just your average joe. So either you benifit from HDMI and the 120gb HDD or you don't. Either you think the new elites won't ring of death or you don't. The 65nm core wouldn't have added any new features or options. Also have to comment on the inclusion of the HDMI cable with the elite. WOW. Finally some console stepped up to that plate. We all know the feeling of buying a new console and not having the right cables to hook it up to the tv. Composite, Componet, HDMI... Sounds good to me. Just as a side note about the ring of death. Such a small percentage have that issue while a good many of those are covered under warranties. But what a cool feature for the xbox to almost diag itself and display some sort of problem code on the front. Think of earlier consoles that would just sit and stare at you with a blank screen. Nothing is perfect, but at least microsoft put in something to deal with problems and failures. One question though, am I right to assume that the extra audio dongle that is included with the elite will mean that plugging in the other a/v cable set will disable the hdmi port? Or is it just there to save space by not having a million wires everywhere.... but who's home theatre doesn't.
__________________
..:: Recent Projects ::..
Picture Frame PC / Adding VGA to lcd / Razr Charge Cable Internal USB WiFi / Zune TV Output / Project XodusAMP Integrated AC Inverter / Project IDEpod / Project iPod HDD Reader |
| Warrior_Rocker |
| View Public Profile |
| Find More Posts by Warrior_Rocker |
#9 |
Last I heard we were getting it in August...
#10 |
Supermodder
Thanks to CostCo's very generous return policy, i will probably get one.
plugging the audio cable in to the analog port does not disable the hdmi. It just allows you a diferent audio output sorce insted of the hdmi audio, but you with it pluged in you still get video out from hdmi. there fore i would guess that pluging one of the analog video outs in would also not disable the hdmi output Last edited by LVMike; 20th Apr 2007 at 15:36. |
#11 | |
Hypermodder
As for the HDMI cable, Sony should have made it come standard on the PS3, maybe they'll catch on and understand that people expect it, so good job Microsoft. For the system diag for the Elite, I think that it will help troubleshoot problems that could easily be resolved. My friend's 360, on certain games, will just freeze up when it's trying to load or when it's saving, and I think it's a HD issue, but I don't know when all it does is freeze up, so with this new diag feature, that would really help. Last edited by devdevil85; 20th Apr 2007 at 15:44. |
| devdevil85 |
| Find More Posts by devdevil85 |
#12 | |
DUR HUR
#13 | |
Hypermodder
| devdevil85 |
#14 | |
Don't panic!
MS won't be changing clock speeds anytime - why bother? Normal X360 games run at one speed perfectly well. Why waste dies by trying to enforce higher clock speeds which will just produce more heat and be wasted by the software? The fan speed will probably be the same too, in fact, reading the article linked in the news post, it's exactly the same, but with a 3-pin connector instead of 4. The real reason for switching down to 65nm is to create a cooler-running console (so less heat-deaths), with a cheaper die.
__________________
#15 | |
Hypermodder
| devdevil85 |
#16 | ||
Hardware Nut
The 'lag' is a graphics related issue. The decreased processor die size will have nothing to do with how well the graphics processor works. The processor speed on the 360 is more than enough to handle what games throw at it. Think about it this way... Does a dual core processor in a computer ever get 100% used up by a single game running at a max of 1920 x 1080? I've not found one yet that uses so much CPU the game lags. The 360 has a triple core 3GHz+ processor, which is better than most PC's these days, and it's ONLY used for games. If you're getting more lag once the console heats up a bit, then more than likely you've having heat related issues. Be glad it's only lag though, as most people with heat issues get the 3 red lights. For the record, the three red lights is caused by the X clamps used to hold the heatsinks down putting pressure on the motherboard, making it want to arch. When the graphics chip overheats, it melts the solder connecting the chip to the motherboard, and due to the pressure put on the motherboard by the clamps, the chip partially separates from the motherboard. There are some home remedy fixes for the problem that can be found on Xbox-Scene.
__________________
|i7 920||EVGA Classified E760||6GB Ballistix Tracer 1600||3x XFX 4890CF||X-Fi Fatality||4x WD Black 1TB RAID 10||Revolution 1050w||Corsair Obsidian 800D| |E8400 @ 4.00 w/ NH-U12P||GA-EP45-UD3P||8GB G.Skill @ 445MHz 5-4-4-12||4870 512MB||X-Fi XM||WD Green 1TB||Tagan BZ 700w||Antec P182 Gunmetal| In Progress||Current Rig -- If I helped you, please give me rep!
#17 |
Multimodder
I was extremely excited when they first came out with the Elite details but that has since been blown away. I'm in Australia and I went to pre-order the x360 Elite and I was quoted $AU1,000 which is the same price as the PS3...
So i'm really in two minds now, it's not like Microsoft have really ADDED that much to the Elite, HDMI, 120gig HDD and black casing... that's hardly bringing it into competitive line with the PS3. |
#18 | ||
Multimodder
__________________
May the forces of evil become confused on the way to your house. |
#19 | |
Hypermodder
As for the clock increase, I didn't put much thought into it, but it's true that it will never happen and that most lag problems are from heat or they're from the graphics card. I never really expected anyone to agree with me on that anyway so....anyways, back to Guitar Hero II |
| devdevil85 |
#20 | |
Officious Bystander
Because X360 originally offered only 720p and 1080i, with 1080p support being added later by a firmware update, few early games support 1080p. However, I'd expect it is more commonly supported now. I don't know if X360 is capable of internally upscaling 720p and 1080i to 1080p, but if not, your 1080p TV will happily do so.
__________________
Demand Naked DSL in the UK! |
| Thread Tools | |
