Thread Tools | View Mode |
#1 |
Ganzerli Mino
Project Impossible Modding - 07/02 Improving
Let's start a new project!
This is my very first time to keep a detailed worklog in english, so don't blame me if my english is poor... For this project I've made a lot of research and planned a lot of things to do, let's begin! The main concept is to DON'T mod the case itself :-] Shocked? Let me explain somethig, this project is a challenge between me and Antanio, the creator of this beatiful case called CABE. My main goal is to add a water cooling loop inside the case without modding it in the outside. He told me that nobody was able to do that, and I've decidet to try to fit a water loop inside this little case... Let the picture talk for me : the victim is a Cabe with smoked plexy top from Modd.it : Rear view : Lateral drive access : The guideline of my project are described above : - No external modding No outside rad, no extra holes, nobody have to imagine that the case is water cooled! - Keeping the original look The Cabe is made from steel , plexy and black trim so I've decided to mantain the same material and colours for the inside. - Using a lot of italian water cooling gear Here in Italy we have some guys that produces wb, so I've decided to use the most "Made in Italy" gear as possibile. Lots of people in all the italian forums helped me with photos, measure, ideas and a lot patience, tnx guys! But the biggest thank fly out to my wife AralT3, she is the best to support me! And now, let's take a closer look to the Cabe to see exactly the amount of free space to play with :-]
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding Last edited by Mino; 7th Feb 2008 at 14:39. |
#2 |
Ganzerli Mino
First of all, the overall dimension are really small, ony 30 cm each side, less than 12 inches...
Taking apart the top, I can see the fantastic mirror finish of the steel, do you agree? As you see, the fans and the motherboard tray are 45° rotated relatively to the base. This means more work to do, but let's take a look to the device tray : Even this tray is made from steel, Antanio planned to have the dvd drive accessible from the side of the case, but I need to have it in front, so a little bit of work in this area... As you can see, the two front bay are designed only for short device like fanbus or cardreader. Anyway,, the total number of drive bay is this : 1 floppy , two slot for 3and1/2 device, two for 5and1/2 device , one short 3and1/2 and one short 5and1/4. The other PITA will be the psu, I would like to use my Enermax Liberty but the modular connector don't allow me to use the dvd... Here is the motherboard tray (fully removable with yust two screw) and the control panel with two usb ports, reset and power button, led, and the mini speaker. I need to modify this piece, is too naked for me...
__________________
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding |
#3 |
Ganzerli Mino
Let's begin removing the motherboard tray and taking some pics to see how it's polished :
Dont'forget those sexy bay cover : Starting to remove the device tray to measure the free space for the psu : Considering the molex and the ide cable, considering that I want the drive stealth, the free space is about 11.5cm , 4,5 inches. Near to impossible to find a good PSU with this measure... The only psu that I found was a poor 180w, chinese brand, I'm considering to keep my Enermax and changing something for the dvd drive.
__________________
#4 |
Ganzerli Mino
We will consider the psu issue later, now I want to speak about the fans :
As you can see the locking mechanism is easy, just a laser cutted steel frame and I'll keep this piece. Here is the temporary fan with the rad, the trick part is to find a method to screw togheter this items :-] Due to the less free space, the rad will be mounted horizontal, but the fan remains at the default inclination , 45°. A little search point me to Bill, at MNPCTech where I found the template for the fan holes, after a few minutes playing with coreldraw I've print two of this to paper and glued to a piece of alluminium.
__________________
#5 |
Ganzerli Mino
And now the cutting :
I've made two of this, for two rad :-] Then I marked the spot for the holes : I've drilled all with a 4.15mm bit, then screwed together and marked the center for the cup bit : And now, a lot of patience, grease and vertical drill...
__________________
#6 |
Ganzerli Mino
Here is the setup:
The Alu goes hot really quickly, so I've used this piece of ice, is made with an Ikea mould, they sell this to put the ice on the bottles, but why don'te be creative? Here are the finished pieces, now I have to use a file to smooth all the side : Some comments about this work? :-]
__________________
#7 |
Ganzerli Mino
After about an hour of work, I want to see how they work :
This fan is not the one that I'll use in the mod, it's just a spare fan :-] : I want to use the silicon pad, so I'll mount it to see the effective dimension. But, a little surprise, the holes in the rad are not ready for the screw! I've made the correct hole, M4, and this is the result : A bit strange, but is exactly what I have in mind to have !
__________________
#8 |
Ganzerli Mino
This is the correct position :
Wow, it fits perfectly! Now let's go on with something different, the paint process of this little part is not so interesting ... Stay tuned for the next update, and please give some comments , but don't blame me for my poor english :-]
__________________
#9 |
what is the cheesecake?
freaking awesome case you're starting off with there, this should be interesting to see how you shoehorn all the WC gear into there
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT |
#10 |
Multimodder
Yeah, definitely want to see how this progresses - looks wicked.
CC |
| casey_cole |
| View Public Profile |
| Find More Posts by casey_cole |
#11 |
Hypermodder
that is such a weirdly cool case
i love it very intresting prject you got here!
__________________
Penguin v5.0 on it's way... AMD Phenom II X4 955 - 4Gb 1600Mhz Corsair Dominator - XFX Radeon HD 5850 - Corsair HX650W - 500Gb Samsung F2 |
| rowin4kicks |
| Find More Posts by rowin4kicks |
#12 |
Pussy Lover
Great Job bro, i love this case,and i believe in you!
Grande rigorθ!
#13 |
Oh, the monstrosity...
Hey rigormortem, great to see you doing a project log here at Bit-tech.
That case is really looking apart, how many of those are around? Limited edition? Looking forward to see how you cope with it's limited space and water cooling. Janne
__________________
I have spread my dreams under your feet, tread softly because you tread on my dreams. Project: Orange Monster Project: Phantom Black Project: Red October |
#14 |
Sierra my delta, bravo!
Easiest way would be to have a 5.25'' Pump/Reservoir combo for the larger 5.25'' bay and then have a slot drive for the smaller 5.25'' bay.
#15 |
I *am* The Stig
sweet looking case
where did you get it??? |
#16 |
Ultramodder
The Mag 2 LE will screw into a G1/4 inch hole like the ones on water blocks then you could use a t-fitting. I'd say you definatly need 1/4inch tubing in that case but you might get away with 3/8th's if you're lucky. I'd say the hardest part is the radiators but you figured that out so....
#17 |
a.k.a KazeModz
wow I like the slanted Mobo tray, thats a really neat idea, I will have to think of something like that for the future.
__________________
Current Rig: RubyRED
Lian-Li A05B (2) Swiftech 220 Radiators (2) D5 Variable Pumps (2) Res and a whole lot of modding Retired Rig: Project F.E.A.R. TT Lanbox Lite Swiftech H2O-120 Q6600 G0 OC@3.6ghz 2900XT 4gb SuperTalent Memory |
#18 |
Ganzerli Mino
Let's do some reply-work, and wait 'till sunday for the update :-] Some WC gear are arriving to my home :-]
@Fod : integrating all is the major trouble, it's like playing tetris :-] @casey_cole, rowin4kicks, Fox the ripper, : tnx a lot! @Darkened : Hy Janne! I'm happy to see your post! the case is not a limited ediction, but is the last of this kind, the next release will be in alluminium, but if you're interested, www.modd.it , the price is near 180 euros... Even I'm interested on how to put all the wc inside :-] @Duste : yes, this will be the easiest way, but I have in mind to use all the 5,25" bay, one for the dvd, and the other two for two water cooled hard disk :-] @The Brast : directly from his creator, Antanio, his store is www.modd.it , if you're interested drop me a PM... @Fozzy : I'll go for 1/4 tubing, now I'm schocked by the price of the Tygon... @HourBeforeDawn : the slanted mb tray is a touch of genius, I agree! And now, I'll go to the chrome guy, he's working for me :-] Stay tuned, more update on week end!
__________________
#19 |
mmm, yep
Oh wow, that thing is nuts! Looks like you have it pretty well under control and seem to have a good plan thought out. Good luck!
__________________
Finished:~~~~~~~~~~~~~~~~~In Progress: Project Phoenix (Lian Li PC-101B Orange Case Mod)
The "Secret of the Ooze" Modded Tt MatrixVX Modded Cooler Master Cavalier 3 My First Case Mod |
#20 |
The Froggy Poster
That is easily the best looking micro-atx "cube" i've ever seen, and the level of worksmanship you're putting towards liquid chilling it is astounding.
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
| Tags |
case mod ![]() |
| Thread Tools | |
| View Mode | |
