RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Apr 2007, 11:18   #1
Gumbatron
Multimodder
Gumbatron's Avatar
Gumbatron is on a distinguished road
SHED Comp (kinda finished)
Every work shed needs at least 1 computer, so I decided that I would put one in my shed. After getting sick of having to go inside whenever I needed to look something up on the net.
SHED Comp was orriginally built a couple of years ago, but the second coat of clear was all stuffed up. It went spotty (I think it was because I didn't use enough thinner). Recently I got around to having another go at finishing it. Here are the results:
And a little on the making of (at least the final bits).
I wanted a comp with a decent air flow, and a way to remove as much dust as possible. Luckily I had aquires some rather large fans from an old HP server (It was about as big as a fridge ). For comparison, there is an 80mm and a 120mm fan in the pic:
The fan is mounted in the top 2 CD Rom bays, and illuminated by 4 blue LEDs (They really could have been a bit brighter):
The case itself is an old Aopen case that I think I paid $5 for. But it's a nice solid case. The interior is kept pretty tidy, most of the PSU cables have been removed, and the remaining ones sleved. The IDE Cables were routed under the Motherboard Tray.
The CD Rom drive is steathed into the 10mm thick acrylic front panel. This is painted metalic blue, then silver then black (reverse order to normal painting, coz it's on the inside). I also made custom backlit buttons, but didn't take any pics of the workings behind them
There's a big vent in the front. This is actually an exhaust vent. Since the Big fan sucks air into the case, through the air cleaner (The pod on top of the case). As you can see, I have a spare stick of RAM in there, just in case she starts playing up :
OK, on to the new paint. The original paint job was a bit dodgy. As can be seen by the amount of holes and low spots that needed filling:
After a few coats of Matte Black, it was on to the Logo. Still can't believe I spent hours cutting out all the lettering, just to peel it off and throw it away after a few minuites of painting:
Then it was on to clear coat (hopefully more successfully this time):
Before I forget, the air filter material is underneath the blue mesh on the top. I also forgot to take pics of how that all went together. But here's a pic of the under side of the filter pod. The mesh and window are held on with small plastic tabs that screw into the underside of the pod. That way there are no visible screws :
Still needs some more rubbing and some wax in a couple of weeks. But here's where she stands at the moment:
Let me know what you think...
__________________
Current Rig: 3800, 1024MB Corsair , DFI NF4-UD, 6800GT, 2 X 300GB (Raid 0) in this
Old Rig: trying to keep it short
Projects: Rack-O-Matic 3000; SHED Comp; HEAVY Water (On Hold); Rustic(New)
Gumbatron is offline   Reply With Quote
Old 25th Apr 2007, 11:35   #2
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
Dude, that's a nice looking case right there. :O
Duste is offline   Reply With Quote
Old 25th Apr 2007, 13:59   #3
itsjustacompaq
Supermodder
itsjustacompaq's Avatar
itsjustacompaq is on a distinguished road
i agree, i love the idea of that fan on top. you did a really good job getting that paint to shine too,
__________________
my new setup: Asus p5n-sli mobo, Asus EN7600GS Silent vid card, Hiper 530w psu, Seagate Barracuda 7100.10 250 gb hdd, Corsair xms2 2gb ddr2, asus lightscribe dvd/rw drive, and a corsair ram cooler all in a Coolermaster Centurion case
current projects:
project: monochrome-stage one completed
HondaBox (in car PC): gathering parts, planning
Past Projects:
siscomp/High Security: thrown in an old case and given to sister.
Visit the University of Missouri-Rolla Formula SAE's website here
itsjustacompaq is offline   Reply With Quote
Old 26th Apr 2007, 04:36   #4
Warrior_Rocker
Holder of the sacred iron
Warrior_Rocker's Avatar
Warrior_Rocker is on a distinguished road
A fellow modder (me) is very impressed
Keep up the cool work with the cuts, sweet fan
Warrior_Rocker is offline   Reply With Quote
Old 28th Apr 2007, 10:58   #5
Gumbatron
Multimodder
Gumbatron's Avatar
Thanks for all the nice comments guys
Still got some more work to do on the paint before I'm satisfied with it though.
__________________
Old 28th Apr 2007, 11:10   #6
Bas van der Werff
Multimodder
Bas van der Werff's Avatar
Bas van der Werff is on a distinguished road
looking great
__________________
Radical Fusion update [9th June 07]
If you're putting more blood into you're project than sweat, double check that you're holding the tool correctly.
Bas van der Werff is offline   Reply With Quote
Old 28th Apr 2007, 18:36   #7
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
wow thats interesting but I agree it looking great.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
