Thread Tools | View Mode |
#1 |
Solemn™
"The Purple Dragon Project" | April 29th 2007 | COMPLETED! Pics and details on Page 2
Before I start my endless blabble and picture posting, do note that this mod is already finished - it has been for quite a while now. Though, I have a new casemod in the making, and figured it would be a good idea to post my old (and first) one here, to give you an idea of what to expect. I have more than plenty of pictures from the process, and will be serving you these in a suitably paced manor, to make it feel like a "real" work log.
Anyhoot, onwards. This is my first ever casemod. It has been a few years in production, being modded in two stints. The first version wasn't quite as I wanted it, so I expanded and developed the concept, with my main goal being the "Casemod of the Year 2005" contest on Tweakup.dk. Sadly, I missed the deadline, but I ended up with something I was quite proud of. Let's start at the beginning, stint one. Do note that a few of the ideas on the following pages were scrapped in the end product, I'll notify you when I commence the second stint, the one that built up to what it is today. First up is: The Case ![]() The cellphone in the first picture might indicate how old these pictures really are, hehe. It's an Ericsson, from the time before they merged with Sony. I don't even remember what it's called. An A26...something. Now, when I picked this, it was mainly for the flashy color. At this time I wasn't planning anything specific, just wanted a new case to replace the crappy, cheap, plastic littered, 0.7 cm zink built heap of a case I was currently in possession of. A sturdy Chieftec case seemed like a good replacement. The Modding It would be months before I laid hands on the case. What set me off was a mod I saw on Metku. Someone had squeezed four 80mm fans into the front of his (smaller) Antec case. The innards are pretty much identical to that of my Chieftec, so I gave it a whirl. Before I show you how that turned out, here's a few pictures of what I did to the case before that: ![]() Installed a CoolerMaster Musketeer and a small Papst 40mm fan. ![]() The goodies for my PSU mod. A purple acrylic cover, black cable sleeving from Vantec, a very silent CoolInk 80mm fan, a Y-cable and some fan screws, and a fan grill I ended up never using. I drilled all the venting holes myself. Think there was about 90 in total. Took ages. ![]() I think that's enough info and pictures for one post. I'll post more, mainly of the 4x80mm fan mod in a minute. All comments are welcome. Last edited by azazel.; 29th Apr 2007 at 14:32. |
#2 |
Solemn™
![]() All masked up and ready for some hacksaw action. ![]() ![]() The last picture you can see how I cut out the part in the front where the four 80mm fans will be mounted. Sadly I don't have any pics of the mounting plate being cut, or the fans being mounted to it, but here's a few pics of it being painted, and after it was mounted to the case: ![]() The next step was to mount a fan controller, in this case a a simple panel with switches and LEDs, from NoiseIsolator. And then there's another gap in my stash of pictures. I'll be removing the front grill of the case, and installing a window in the door, the aftermath pics will follow in the next post. |
#3 |
Multimodder
nice color choice
i'll watch this one
__________________
Radical Fusion update [9th June 07] If you're putting more blood into you're project than sweat, double check that you're holding the tool correctly. |
#4 |
Solemn™
Before I show you the front window, some assembly pics:
![]() CoolerMaster CoolDrive 3, two Revoltec 60cm 3-pin extension cables, two blue cathodes and a Thermaltake TrueLight RAM cooler with blue animated light. ![]() And here all the above products have been installed. I also sleeved various cables. Here you can see the front with the removed grill and new window, which still has the protective film on it. ![]() I cut some small, round pieces of acryllic, painted them black, and mounted them to the center of the fans. And yes, I know the fans are a bit off center, but the motherboard tray made it impossible to move them any further to the right. ![]() Flick the switch and push the button to power on the PC. Found it in a car accessories shop. ![]() Fitted some black mesh over the fans. And that's how the case stood for a few months. End of the first stint. Now the more creative modding can commence. I'll update in a little while. Tata. Last edited by azazel.; 28th Apr 2007 at 15:49. |
#5 |
I *am* a Dremel
very nice just wondering whats it got to do with dragons.
__________________
Now an Architect
#6 | |
Solemn™
The case is called the Chieftec Dragon. And it's purple. There's your connection. :P
__________________
Dedicated Obsession "New mod, old... err, new worklog." The Purple Dragon Project "Old mod, new worklog." (FIN) |
#7 |
da ginger monkey!!!!
im guessing the name has something to do with the fact that its a purple chieftec dragon case! lol
good mod well done damn too late |
#8 |
Solemn™
The Modding - Stint Two
This is where I decide to enhance the case a bit up to the contest I mentioned earlier. It was also time for an upgrade. Parts! CPU: AMD A64 3200+ (2200 MHz) (Socket 754) Motherboard: Soltek SL-K8AN-RL PSU: NorthQ 4001-BL 400W (17 dBa) CPU Cooler: ThermalTake Pipe 101 Fan: ThermalTake Silver UV, 92mm UFO Fan Also in the picture is four black thumbscrews and a Hauppauge TV-tuner card. ![]() The heat pipe cooler in all its glory, with the UFO fan mounted. I admit, the fan isn't that pretty, but that changed. ![]() Only decent motherboard I could find that fit the theme. ![]() And here's the cooler and CPU installed. More parts! Goodies arrived from www.caseking.de: ![]() Stuffed box! Let's lay out and name the various parts. ![]()
In the next post you'll get to see how some of these items were used.
__________________
#9 |
I *am* a Dremel
oh of course shame on me.
__________________
Now an Architect
#10 |
Solemn™
I should mention that at this time I've also purchased a few sheets of 3mm thick black tinted acrylic, and a handful of M4 hex bolts.
![]() Cut a hole for the new top window. ![]() ![]() Top window cut. The big hole is for the 120mm Aerocool fan. ![]() Still need to pretty up the holes, hehe. ![]() Test fitted the top window with a few of the buttons. Now, I wasn't quite satisfied with the clear 80mm fans I used in the first go, so I replaced them with the AeroCool Silver Line II fans you saw above, and mounted them with the rubber "bolts". ![]() ![]() Snug fit. It was hell to get the last fan on. ![]() ![]() ![]() Test fitted to the case. You can also see a bit of the paint I'll be using in the background - flat black. ![]() Mounted one of the ThermalTake ducts to see how it would look. More later.
__________________
#11 |
Supermodder
Didnt like the color that much, but looks promising!
#12 |
69 Dude!!
they say that purple is the colour of unsatisfied women
![]() you're not a woman, are you? btw: i like what you're doing there, finally someone who uses a colour that not everybody has
__________________
No reward is worth this! |
#13 |
Supermodder
Hey I've been looking, at this case on tweakup. You've been very inspiring.
Nice to see how you builded it, I'll follow this one
#14 | |
Solemn™
![]() But no, I'm very much male. Let's hope that unsatisfied women will feel drawn to the case and its owner, eh? :P @jegerjon: Ah, cool. Glad you like it.
__________________
#15 |
holy *******************
man this is over control , WOWO keeeep it , I will follow this too good luck
__________________
GigaByte Triton 180|GigaByte EP45-UD3R|Intel Q9450|8GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|7TB Space The King Of CK Appreciation Society Group
#16 |
Solemn™
So, now for more cutting, sanding and painting.
![]() Flat black, yummy. Got a few more coats after this. In this picture you can also see the hole I cut for the two rear fans, which will be the same AeroCool ones used in the front. ![]() The upper and lower part of the front window and the mounting plate for the rear fans got a shot of paint, too. In the top window I mounted a key switch and a Bulgin vandal button. It's a simple setup that requires you to turn the key before you're able to boot up the PC, using either the Bulgin button, or the one behind the front door, that's what I'm soldering in the picture above. Now I could start assembling the case again. ![]() ![]() The ducts are supposed to direct some of the airflow towards the southbridge on the motherboard, but they're mostly just there for looks. After this I have very few assembly or work pictures, as I had a deadline. In the next post you'll see the finished product, so I'm saving that for tomorrow. -Az
__________________
#17 |
Supermodder
Looking good then, cant wait to see the final pics
#18 |
I *am* a Dremel
I like the ducts to they light up.
__________________
Now an Architect
#19 |
I like wood ಠ_ಠ
I don't really like the purple paint(I like black), but it's still a pretty good mod
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#20 | |
Solemn™
![]() Thanks for the comments peeps.
__________________
| Thread Tools | |
| View Mode | |
