#1 |
Hypermodder
Painting a case help
Hi all, my antec p180B is a bit scratched up, and i want to fix it. i was thinking about how to paint the side panels so that it looks like the origonal brushed alu style
Also, i need to paint the top, its also scratched. its plastic, is it possible to paint it a matte black? If so, how? Thanks all.
__________________
Project Dimension 2400 Last edited by zhangmaster12; 4th May 2007 at 03:17. |
| zhangmaster12 |
| View Public Profile |
| Find More Posts by zhangmaster12 |
#2 |
Mod Master
I can't remember if any of these guides cover painting a plastic case specifically (I doubt it, frankly?), but they should give you a few ideas at least
Spray paint your PC case and give it a mirror finish Shatterstar's Painting Guide Case Painting 101 How to paint your computer case (Part 1) + How to paint your computer case (Part 2) Spooky's Computer Painting Guide
__________________
Beauty is in the eye of the beer-holder
#3 |
Hypermodder
There was a tutorial over on coolercases.co.uk in the forums where the guy painted his mouse, that is made of plastic.
#4 |
Ultramodder
You just need a primer that will adhere to plastic then pain on top of that. also sand the surface with 240grit to make a better surface.
#5 |
Disgruntled kumquat
On the side pannels, anyway, getting the black-anodized-brushed-aluminum look back will be rather tough with paint. If the scratches themselves aren't too bad, a black sharpie will get rid of the silver color and leave the grain visible.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing. |
| Techno-Dann |
| Find More Posts by Techno-Dann |
#6 |
Hypermodder
the scratches arent bad only a few, but i want to make them invisible. With a shrapie they are still faintly visible.
thanks for teh replys
__________________
Project Dimension 2400 |
| zhangmaster12 |
#7 |
I *am* a Dremel
Krylon's Fusion Paints are made for painting plastic. You need to prep the plastic surface by cleaning it first with a degreaser spray like "Simple Green" or "409"
If you wish to use an automotive touch-up spray instead, you must use Flexible Primer for your base coat first on plastics. (btw: "Self Etching" Primers are for Metal Surfaces)
__________________
mnpctech.com (web's most unique case mod parts, international orders welcome!) My Case Mods: NVIDIA ION Cube / Bio-Mechanical Khaos / AMD Corporation / HD 100 / CPU Stingray / The Wall |
#8 |
Hypermodder
ty everybody
__________________
| zhangmaster12 |
| Thread Tools | |
| View Mode | |
