#1 |
Minimodder
artifacts
i was having small artifact problems with my 6800gs AGP 256mb, so i took it out an reseated it, and now i get huge artifacts from boot, i.e lines down the screen.
This has happend before an after playing with it for a while i managed to fix it but this time i cant ive reseated it 3 times an it makes no difference. so, does anyone know what else i can try? id quite like to know what part of the card causes these if anyone knows. buying a new card is out of the question as i have no cash :-S anyone got any ideas? |
| Xavierthefirst |
| View Public Profile |
| Find More Posts by Xavierthefirst |
#2 |
Supermodder
define "playing with [the card]"
you taking physically moving the card around, or OC via software?
__________________
Current Rig: i7 D0 2.66GHz, 6GB 1066MHz Corsair "Dominator", 285 GTX. |
#3 |
Minimodder
Physicaly moving it around, dusting it off an cleaning the AGP slot and the AGP insert, ive tried it with another computer this time an its the same so its definatley the video card
| Xavierthefirst |
#4 |
H to the U to the G to the O to the B
Artifacting is caused by your graphics card's memory. From the sounds of it you haven't overclocked, so one can only assume that the card is actually dead.
__________________
TrustedReviews.com - things I write about for a job |
#5 |
Supermodder
just something to try,
take a #2 pencil and use the eraser on the contacts to the agp. (A #2 pencil eraser wont leave residue and removes most bad things, I wouldn't recommend other eraser types because I don't know if they will leave a residue on the contacts.) this should remove most/any bad stuff that could form or collect on the contacts. just make sure its clean of the eraser, wipe with a clean cloth or blow off the eraser crumblings, reinsert and test! Good luck! EVRE
__________________
(Phenom II 940)(Foxcon A7DA)(8gb OCZ DDR2 800 )(8800gt aka hair dryer)(Big yellow case, CPU, GPU)(Enermax Liberty 500w)(lite-on DVD-RW w/LightScribe)(Seagate 300gb sata)(Seagate 320gb x2)(WD 200gb)(Dell 3007WFP 30"LCD, 19" Samsung, Acer 1280x720 projector) |
#6 |
Minimodder
Ok so ive tried cleaning the AGP contacts and the problems still there, is there any way to clean my memory chips? ive removed all the arctic 5 thermal paste with the proper arcticlean solvents, anything else i can do?
| Xavierthefirst |
#7 |
I also ride trials :¬)
Does it do it from a cold boot? I.e. check if it's an overheating problem.
__________________
Carrot cake cheesecake Shuttle SN85G4V2 | A64 3200+ / Apple PowerBook 12 |
#8 |
Minimodder
yep its straight from cold, and the problem didnt occur before i reseated the RAM and GPU the first time
| Xavierthefirst |
#9 |
Multimodder
Is it still in the warranty?
One of my friend also owns an 6800GS(PCI-E) & he also had the same problem but he is too lazy & took my card.But his problem is also same.
__________________
AMD Athlon 3200+(2000 MHz) Winchester (Cooler Master Hyper 48),MSI RS482M4-ILD,Kingston KVR 512x2(1024MB)400MHZ,Gainward 6800 GS 256MB GDDR3 @ 425/1000,250GB WD Caviar 2500JS,80GB Seagate Barracuda,Lite-on DVD/RW,Cooler Master 430Watts PSU. www.sunehrepal.com http://www.technewstime.com |
| keith_j_snyder2 |
| Find More Posts by keith_j_snyder2 |
#10 |
Minimodder
Nah it aint ive taken the heatsink off, i guess il have to flog it and get an upgrade
| Xavierthefirst |
#11 |
Multimodder
Yeah good idea!
__________________
| keith_j_snyder2 |
| Thread Tools | |
