RSS
Old 17th May 2007, 15:03   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Shuttle SS21T
http://www.bit-tech.net/hardware/200...huttle_ss21t/1
Slightly larger than the XPC range, the Shuttle SS21T is an extremely cheap barebones system. However, has Shuttle cut too many corners?
Tim S is offline   Reply With Quote
Old 17th May 2007, 15:58   #2
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
Quick note: The border on the first test setup here seems to be smaller then the other borders.
Also, why is there no test to another system running an FX62 and 7600GT?
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 17th May 2007, 16:07   #3
Dr. Strangelove
Supermodder
Dr. Strangelove's Avatar
Dr. Strangelove is on a distinguished road
Am I the only one who thinks it ironic that this is a (nano)BTX standard board using an AMD CPU? is BTX not an Intel standard? or did I miss something completely?
__________________
If it isn’t broken, fix it.
If it is broken, mod it till it looks like it's meant to be broken.
Dr. Strangelove is offline   Reply With Quote
Old 17th May 2007, 16:30   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Cause the actual level of graphics horse power does nothing in 2D if they both have the same drivers and once you're passed a certain level. It's also due to the fact you can't run anything faster in the Shuttle SS21T, whereas you can run whatever you like elsewhere. It's a good point, but I was aiming more on the whole platform side rather than a 1:1 because a £130odd Asus Crossfire is an overkill compared to a SiS board
Doc: Yea totally, that's why the layout is so screwed up. Intel designed BTX to have the memory the other side of the northbridge, too far away from the CPU for AMD. In this way, DTX is designed to pwn Intel and put the memory on the wrong side of the CPU to the northbridge. Shuttle made this before DTX, but I don't know why they just didn't make a mATX board instead.
Bindibadgi is offline   Reply With Quote
Old 17th May 2007, 17:40   #5
rupbert
Hypermodder
rupbert's Avatar
rupbert is on a distinguished road
Shame because the external design is quite beautiful.
rupbert is offline   Reply With Quote
Old 17th May 2007, 17:43   #6
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
d'oh still no onboard DVI.. I don't get it. IMO the place for small and cute computers such as this are supposed to have everythin essential included so they can just be thrown into some office and they just work. After all most offices have flat monitors these days..
(ok this didn't make sense, but DVI would be damn nice. Maybe the only nice thing in the entire IGP)
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 17th May 2007, 17:48   #7
rupbert
Hypermodder
rupbert's Avatar
@ Jipa
Good, it's not as if DVI to D-SUB connectors are hard to come by...
Old 17th May 2007, 17:54   #8
Dr. Strangelove
Supermodder
Guess it would make a pretty, but slightly overpriced doorstop
-->Tim: ok, thanks for clearing that up I'm sure someone at shuttle is thinking the same thing now (or more like: "dammit why didn't we know a new AMD standard was coming"), probably more a marketing decision than an engineer one (like this:
MarketGuy: "nanoBTX sounds cool, nano is hip! put it a box with AMD cause we like those CPU's"
Engineer: "but BTX is an Intel design will not work with AMD, why not make a mATX, if you want a small AMD based system"
MarketGuy: "I don't care, just do it, no-one will buy something called mATX, it's soo yesterday"
Engineer:
__________________
Old 17th May 2007, 18:26   #9
alastor
Mod Master
alastor's Avatar
alastor will become famous soon enough
Originally Posted by Article
The first thing you notice is that there is CPU cooler included...
For example, no CPU cooler is provided, and anything...
Are you missing something there Rich?
I thought BTX had died a while ago except for in Dells.
__________________
Main Rig: C2D E6850 (3.0GHz) : Asus P5E (X38) : 4GB XMS2 PC6400 : HD4870 512MB : Enermax 620W : 2 x Samsung F1 1TB : Antec P182
Laptop: Turion64 ML-34 (1.8Ghz/1MB) : 1GiB Hyundai : Mobility Radeon X700 128MB : 100GB Seagate HDD
My Flickr : My Gamercard
alastor is offline   Reply With Quote
Old 17th May 2007, 19:00   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Ah thanks, my mistake - I was tweaking and forgot to replace a word
Old 17th May 2007, 22:13   #11
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
where are all the decent shuttles to replace my nice SN45g
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 18th May 2007, 03:22   #12
scq
Hypermodder
scq's Avatar
scq is on a distinguished road
DAMN!
I wanted to stuff a X1900XTX in there and make a mini, semi-portable power rig for gaming and other stuff.
scq is offline   Reply With Quote
Old 18th May 2007, 03:50   #13
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
I saw the BTX form factor then was shocked by the AMD bit when I started reading.
It's a shame, I used to want a Shuttle SFF. Lately though they can't seem to make what I (& quite a few others I guess) am (/are) looking for.
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
