#181 |
↓ Don't trust that face!
Thanks, Franklin.
Being called crazy by you is a true honor.@John - Dells are rapidly replacing the concrete block as a way for bachelors to hold up shelves. When I get one, I rip out the fans, heatsinks, wiring, screws, and drives. the rest goes in the trash. I need to read through the laptop screen mod guides someday too. I've got a few of those...
__________________
#182 |
Did I let the magic smoke out?
I may be slow, but is there any purpose to the bown and funnel shapes in that block? I didn't see anything mentioned and I have a fear of water cooling to rival my fear of plumbing (water can make such a mess). Does it server any other purpose than looking freaking sweet?
#183 |
It's mostly to look freakin' sweet. The funnel shape was to avoid turbulence near the intake. The intake on the impeller well is larger than stock too. The only choke point is the exaust.
... Keep in mind I'm no hydrodynamics engineer. I'm just playing with intuition.
__________________
#184 |
Acrylic Heretic
I'd think if it performs the same or better , and is as quiet or better than it was with the stock top, you exceeded the expectations on it. Personally, I think it's f'n kick-ass!
__________________
Latest Builds: LilyPC - in progress • BIO-A10 - MotM Jul. '12 |
#185 |
__________________
#186 |
The Keeper of History
I'll just repeat E.E.L's comments. and add I like it too.
John
__________________
My deepest gratitude to this community.
#187 |
I'll just
again, and say thanks. I got some LED wiring done. I need to work on the reservoir now.
__________________
#188 |
Updates trickle in slowly...
![]() -I'm turning the floppy bay into front loading USB. The last Gateway I gutted had a nice plug for that. ![]() -Glued some brackets on with the help of an 1/8" spacer. ![]() -I did the front LED wiring. I stopped at this point because I was so sleepy, I couldn't figure out what I was doing. It's wired up wrong too.![]() -Another day and a whole lot of splicing later, it's finished. What a mess. ![]() -I did a test run before I moved on to #2. (PART #2, EEL!) ![]() -The junction box was tricky. The normal glue wouldn't react with the stuff they make the connectors out of. I gobbed some IPS #16 behind each plug, and topped it off with hot glue. It's holding so far. It shouldn't go too far now that it's one big glob. ![]() -It's about time I backed up and showed what I had so far. Still hideous isn't it? It's starting to look a little nautical too. -One more Bioshock mod?![]() -Lights, courtesy of a Kingston data silo. I've rewired it into a real connector slut. That's 8 white LEDs in the faceplate, 4 in the pump top, and 10 in the chaser. I'm down to about 6 of the original 50 I bought from Besthongkong. I should buy several hundred next time. These didn't stay in the bag long. Go buy some stuff from my sponsor, DangerDen!
__________________
#189 |
Lian Li Snail :)
SHIZLE
we have light
__________________
#190 |
Multimodder
The res looks like a submarine
![]() Okay, that was pushing it, but whatever. |
#191 |
@Yeknom - That's what I've been thinking. Now it's spread to the whole rig.
__________________
#192 |
Pump Killer
OMG Cheap...
That is the craziest frikkin pumptop I have EVER seen in my life... ![]() I'm at a loss for words right now, so I'll just... dunno... bbbbbbbbbbbbbbbbbbbbbbbbbbbbb... <--- Sorry, my jaw just hit the keyboard... ![]() Btw, sorry I didn't respond to the PM, I'm not in here much during the summer, but I'll be up in full effect when it get's cold outside!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#193 |
Supermodder
Nice one Cheapskate,looking good
#194 |
Thanks AngelOD and Skullen.
![]() @AngelOD - It's OK. The PM was just a thank you to let you know your generous effort was put to good use. I'm looking forward to seeing some modding when you get snowed in.
__________________
#195 |
Multimodder
Hmm you have something for transparent stuffs eh? Nice
#196 |
Thanks acey.
__________________
#197 |
Tiny, uneventful updates suck...
...Cleaning out the camera...not much of an update.
![]() -I did a half-arsed job on the copper res intakes. After varnishing they looked like crayons. I will have to clean off the varnish and polish them completely. ![]() -I got the wiring box mounted. This is an underbelly shot. That's IT! I haven't had a chance to do anything this week because of the Bloo leak.
__________________
#198 |
Tinier and more uneventfuller...
![]() -I milled out some black ABS for a junction on the LED wiring. ![]() -Here it is installed. Expect another update by 2009. ![]()
__________________
#199 |
It lives! Both da thread and other stuff
I discovered the LED chaser now works. I'm thinking having it flop around in the project box for a few months has fixed whatever was wrong with it, (or maybe I had it plugged in wrong before.)
...anyway, I had to mount it in something to hide my amazing wiring snarl. ![]() -So I built a box out of smoked 1/8" plexi. I used the angle aluminum to hold straight it for fusing. ![]() -aannnnd quickly broke it by drilling into it without something behind it. I glued the crack back together and finished drilling with a diamond bit. The crack will go good with the recycled theme. ![]() ![]() -Here's the rough test fit. Someone is going to call the Boston bomb squad on me for this one. ![]() I have decided it needs an off switch. It's really bright and seizure-inducing -even imbedded in the plastic. You know the routine. Love my sponsor, even if you don't love the 'Toad. ![]()
__________________
#200 |
Ski-Ba-Bop-Ba-Dop-Bop
Do a video of the chaser. Like to see how the disk looks.
__________________
Nothing to see here ![]() I'm not going to say where I got it from, lets just say that it was not the best buy I ever made.
| Tags |
| scratch build |
| Thread Tools | |
| View Mode | |
