#281 |
bit-tech sponsor
This worklog is one that I kicked myself for missing when it all transpired. I especially loved the experimentation with custom made fan blades. Thats the crazy stuff I love about modding
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#282 |
↓ Don't trust that face!
I seem to like to make stuff that doesn't work.
__________________
#283 |
Still evolving
Sorry about bumping the ancients, but...
![]() -I had to show you this kewl panda face. -No. 'Toad's reservoir has been a problem for a while now. The setup made it impossible to clean, and it was frequently springing leaks. ![]() -I've been playing around with using stainless steel tube for a while, and recently cranked out a prototype that I palmed off on Bill Owen from MNPCTech. We have discussed doing a run using one- piece end caps. Make some noise if you are interested. ![]() -Here I have freshly cut end caps in a cut-off of the tube. It took me a while to find some suitable scraps for the green. I added a third port on this one for a fill line. ![]() -My version has 2 part caps. I need to glue these little rings on the inside to hold the O-rings. ![]() -I picked up some clearance G3/8 barbs to see if I could make a large port version. -Looks doable to me. ![]() ![]() -I fixed up a ghetto tailstock for sanding the tube body. Yeah, That's a skateboard wheel. ![]() -I made a horrible mess trying to get the tube polished up. I had to stop because the bit of felt and polishing compound I used turned into a silver rock. ![]() -In keeping with tradition, I made the brackets out of an old, (friggen hard,) chunk of industrial polycarbonate a friend had given me. ![]() - Ignore the countersink failure. Here They are tapped out and ready to mount.![]() -Before I could mount a new res, there was a lot of gore... and cleaning. ![]() -The insides of the old res. have some nasty ball of plasticizer, faux bauxite, and bacteria. ![]() -Ewww! Who sneezed? ![]() -OK, I fixed that. -Wait, Something's not right... ![]() -Mounting up a new res. A handy feature of this setup is that I can fill with the lid off even when the pump is running. The version I drew up for production has a center fillport in an indent to help prevent spillage. ![]() -Capped up. The last bit of thick material I had wasn't very transparent. -Here she is 'finished' again. I need to find more junk to make a cap for the fill line, and there's still some work to do on the old pump top. I ripped the old barbs out thinking I could drop it in the mill real quick and update to bitspower barbs. ...Then I remembered this is what powers the mill.
__________________
#284 |
![]() -I still don't have the old pump top in, but the res cover is done. Have a quick pic.
__________________
#286 |
Multimodder
OHoooo whos back
#287 |
Thanks.
![]() ![]() Now let the log drift back to nostalgia land...
__________________
#289 | |
modeteer
#290 |
Car lover and Speed Junkie
HEEEEEEEEE"S BAAAAA-AAAAAAAAAAAAAAcK!
| Tags |
| scratch build |
| Thread Tools | |
| View Mode | |
