Reply
Thread Tools View Mode
Old 18th Jul 2008, 18:19   #121
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Originally Posted by Cheapskate View Post
I turned the TV off years ago. TV is like a monkey. It sits in the corner and tries to fling cr*p at you.
LOL. And all too true.
__________________
Latest Builds:
LilyPC - in progressBIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 21st Jul 2008, 23:21   #122
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
It could double as a weapon, and I still don't have the top capped.
-I went for the straight line. the exaust BARB will be sticking out at a wierd angle, but I don't care. The lines on the side were for lining up the bit. I eyeballed it. I had to tilt the press platform too.
-Here's the 1/4" intake bored out to take a 1/4" NPT barb.
-I bored out the 3/4" plate with a 1/2" round mill bit.
-MMMMMn Do-nut!
-Here I'm milling out a bowl in the top of the 1 1/4" part. I found it's easier to mill out a channel with a smaller mill bit, then round out the edges with the big bit. I'm still thinking up the design as I go along.
-The round bit pass. I had to go back and smooth out the edges. It looked too much like a nipple on the first go.
-I'm approaching serial killer status when it comes to pens. My light blue pen dried up, so I had to gut it to get any blue ink out of it. -Ghastly!
-Some of the solvent dripped into the bowls when I was gluing. It left a cloudy spot. I was hoping the blue would make little streaks inside.
-There goes my freshly vac'd floor. I was getting sick of working with 4 oddball edges. I milled them flat and square. I won't use this spiral technique again. It made a little chip at each corner of the mill passes. The other sides I did in streaks, so any chipping would be at the edges.
-I did a rough sand and polish for some reason. I'm going to chop a lot of this away in the future. You can see one of those chips right in the middle of the side.
-I'm thinking I'll cap the top with a bit of 1/2", then drill the intake in from the front. What do you think...potential disaster and internal chipping?
Cheapskate is offline   Reply With Quote
Old 21st Jul 2008, 23:53   #123
E.E.L. Ambiense
Acrylic Heretic
Wow, man. I think ya got it! I'd give her a try and see how much of a difference it made versus stock top. Like all of us, I'm curious what your results will be. Great job, bro!
__________________
Latest Builds:
Old 21st Jul 2008, 23:55   #124
yeknom
Multimodder
yeknom has yet to learn the way of the Dremel
Ooh, looking good Cheapskate!
Drilling the intake in from the front doesn't seem like too bad of an idea. Although internal chipping could happen if your not careful.
yeknom is offline   Reply With Quote
Old 22nd Jul 2008, 00:46   #125
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Well done, Cheaps! This is cool. I don't do H2O, but I watch a lot. I like the handmade VS. "I just bought this" approach.
Well met young friend and keep dry!
If you could spare some of the incoming moisture, my town hasn't had a measurable rainfall in 2 months. Brown is our new city colors.
John
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 22nd Jul 2008, 00:47   #126
Cheapskate
Cheapskate's Avatar
Thanks guys. I still have a lot to do to it.
@John - I -JUST- heard about the hurricane. Odds are we won't get a drop of rain again. I've made the joke that Moses lives in our neighborhood. Even when we were getting rain, it would part and go around us on the radar. Grass here is dead. I'm driving around today moving sprinklers. It looks like I will still have a bunch of dirt lots soon.
Old 22nd Jul 2008, 01:32   #127
jhanlon303
jhanlon303's Avatar
yep, that's here too. Only green is people who are
A.) retired with the bux
or
B.) city golf courses.
It was just a thought.
Mod on,
John
__________________
Old 22nd Jul 2008, 18:25   #128
perkins teh modder
Multimodder
perkins teh modder's Avatar
perkins teh modder has yet to learn the way of the Dremel
its not delivery, its Digiorno. lol
it looks amazing btw.
__________________
sorry for bad english, im from america
perkins teh modder is offline   Reply With Quote
Old 22nd Jul 2008, 21:05   #129
p3ri0d
Multimodder
p3ri0d has yet to learn the way of the Dremel
it looks like cool
100% cheesecake!
p3ri0d is offline   Reply With Quote
Old 22nd Jul 2008, 23:32   #130
Cheapskate
Cheapskate's Avatar
Thanks.
@Perkins - Please ignore any accidental subliminal messages. The recycle pile is directly behind me when I'm milling.
Old 23rd Jul 2008, 00:28   #131
wastedtime
Case Modder
wastedtime's Avatar
wastedtime has yet to learn the way of the Dremel
Omg .. You are one amazing artist my friend. This is simply superb
__________________
Never agrue with an idiot. They drag you down to their level and then beat you with their experience.
[Project] Azure - A Rack Server Mod
[Project] The Clone
wastedtime is offline   Reply With Quote
Old 23rd Jul 2008, 00:50   #132
praetor coda
Modder
praetor coda has yet to learn the way of the Dremel
Amazing
How is it that you don't own a cnc machine? You are "Da Mac", basically saying you're like Macguyver, the fictional character who used the best of what he had at his disposal, rudimentrily speaking. Keep up the good work.
praetor coda is offline   Reply With Quote
Old 23rd Jul 2008, 15:11   #133
perkins teh modder
Multimodder
im sure Macgyver can build a CNC machine.
__________________
Old 23rd Jul 2008, 15:32   #134
E.E.L. Ambiense
Acrylic Heretic
Out of a bendy straw, some aluminum shavings, and a rusty drillbit.
__________________
Latest Builds:
Old 23rd Jul 2008, 15:35   #135
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
damn, I want one of those now...
Seriously, I got a steampunk project brewing, and it would be perfect. I may PM you later about that.
__________________
I don't feed the trolls...
Quit chopping up the locals to make tools.-Cheapskate
KayinBlack is offline   Reply With Quote
Old 23rd Jul 2008, 18:24   #136
Cheapskate
Cheapskate's Avatar
Thanks, everyone.
I feel like Macgyver some days at work.
2 problems with a CNC machine: Where would I put it? What's my name?
@ KayInBlack - The bendy straw CNC?
Old 28th Jul 2008, 02:10   #137
KayinBlack
I Endure
KayinBlack's Avatar
The res. Amazing work.
However, I did make a chiller out of an integrated watercooling kit... MacGyver is my hero. Him and Batman.
I'll post my little monster in a while, it's nothing special but it'll do wonders for nForce Pro MCPs..
Oh snap, that was a hint...
__________________
Old 28th Jul 2008, 17:59   #138
Cheapskate
Cheapskate's Avatar
Thanks.
MacGyver shows up in the next Batman movie, With Mr. T. (Well, Marvel would do it...)
Now get out of here! You have 2 casting logs I'm drooling over, and you haven't finished either of them.
I'm currently sanding down a half day of milling. I almost have the pump top ready to test.
Old 28th Jul 2008, 19:41   #139
Langer
Jesse Lang
Langer's Avatar
Langer has yet to learn the way of the DremelLanger has yet to learn the way of the Dremel
That pump addition you made is really cool, shows a lot of skill... don't want to sound like too much of a n00b, but what exactly does it do?
__________________
project:HELIOS -- project:PROMETHEUSCU
Langer is offline   Reply With Quote
Old 28th Jul 2008, 19:49   #140
E.E.L. Ambiense
Acrylic Heretic
If I may, Cheaps...
It enhances flowrate so the pump will push more water. Plus, it's just cool to do it! Why keep things stock, ya know?
__________________
Latest Builds:
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
