Reply
Thread Tools View Mode
Old 28th Jul 2008, 23:50   #141
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Originally Posted by E.E.L. Ambiense View Post
If I may, Cheaps...
It enhances flowrate so the pump will push more water. Plus, it's just cool to do it! Why keep things stock, ya know?
It does?
Mainly I did it because the pump will be front-and-center in a transparent case, A visible impeller has to be the best flow indicator ever, and because I wanted to.
It might push more water. I opened the intake up so it matched the hole in the top of the impeller.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 28th Jul 2008, 23:58   #142
Langer
Jesse Lang
Langer's Avatar
Langer has yet to learn the way of the DremelLanger has yet to learn the way of the Dremel
Hahaha, I figured aesthetics was the purpose I just wanted to be clear about your genius. Looking goof mate, keep it up!
__________________
project:HELIOS -- project:PROMETHEUSCU
Langer is offline   Reply With Quote
Old 29th Jul 2008, 19:28   #143
Cheapskate
Cheapskate's Avatar
Thanks again, but genius? Didn't you mean madness?
'Looking goof' -I like that typo.
...It was a typo, right?
-I went out and bought another set of permanent markers for the -blue- one. I should do something with the other 30 sharpies I've got now.
...anyway, I got the guts cleaned up enough I could glue the top on. The fumes got trapped inside and wrinkled the inside of the 1/4" layer chamber. I should set up a way to vent the fumes next time.
-This is the only pic you will get of the mill and drill session. I cut the edges smooth first, then bored the extra material down so I only had 1mm of extra to mill off. I finished up with regular mill passes for the last mm.
The hole for the inlet was hand turned in the press again.
-I tapped the inlet after I finished sanding with 240grit. My tap kit includes a 6-point 1/2" socket and a pvc connector to help me keep the tap level. I kept the grease minimal this time. I didn't want to get any inside where I wouldn't be able to get it out.
-I gave the inlet a light polish job with ol' electric Q-tip. -drill, stick, felt, novus polish.
-After sanding and buffing, I have CANDY.
-front
-back -notice how the reflections are freaking the inside shapes out?
-Bottom. I may need to re-surface this. I have a wicked scratch right where the o-ring seats.
-funky angle of the front
-side. Picasso would be pleased with the way this screws up the internal perspective.
So that part is mostly done. I need to glue the barbs in with silicone before I can test it. If I do this again I will need to make a stubby spade bit so I can flatten out where the exaust barb seats. I'd like to be able to use O-ring barbs someday. I also need to bore out my holes with something smaller than 1/2". Tribal said somewhere what the best bit size was for that. I need to go re-read his log.
I never would have tried something so crazy without the support of my sponsor. Thanks again, Danger Den!
__________________
Old 29th Jul 2008, 19:58   #144
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Dude.
Thats like totally fricking sweet like.
Mankz is offline   Reply With Quote
Old 29th Jul 2008, 19:59   #145
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Schweet, man! That thing looks almost Seuss-like!
__________________
Latest Builds:
LilyPC V.2BIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 29th Jul 2008, 20:03   #146
ComputerKing
ComputerKing's Avatar
ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.ComputerKing is a hoopy frood who really knows where their towel is.
See if that is a pump that is the weirdest PUMP I ever saw in my whole life. If it is a block cover, It will be the weirdest Cover I ever saw in my whole life too. Weird!!!!!!!!!
__________________
GigaByte Triton 180|GigaByte EP45-UD3R|Intel Q9450|8GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|7TB Space
The King Of CK Appreciation Society Group
ComputerKing is offline   Reply With Quote
Old 29th Jul 2008, 20:14   #147
Cheapskate
Cheapskate's Avatar
Thanks everyone.
@EEL - Funky-plumbing-look Seuss? Yes. All it needs now is a name like 'snorzelphone'.
@CK - That was the response I was going for. -"That is the weirdest pump top I ever saw in my whole life."
__________________
Old 29th Jul 2008, 20:16   #148
E.E.L. Ambiense
Acrylic Heretic
snorzelphone FTW!
__________________
Latest Builds:
Old 29th Jul 2008, 20:46   #149
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
OK, I now officially want a pump top like that. Officially as in PM me a quote.
__________________
I don't feed the trolls...
PC: Intel i7-4830K, ASUS X79 Deluxe, 64GB GEiL Golden Dragon 1333MHz RAM, EVGA nVidia Titan Black 6GB Hydro Copper, Blu-Ray burner, 4x250GB Samsung 840 EVO in RAID 10, Corsair AX860i.
KayinBlack is offline   Reply With Quote
Old 29th Jul 2008, 20:51   #150
ComputerKing
heheheh, no problem you are welcome any time I'm here yo support you buddy don't forget that
__________________
Old 30th Jul 2008, 03:13   #151
yeknom
Multimodder
yeknom has yet to learn the way of the Dremel
Man, that top is insane. Great work.
yeknom is offline   Reply With Quote
Old 30th Jul 2008, 03:19   #152
Shadowed_fury
I Mod, Therefore I Own
Shadowed_fury's Avatar
Shadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the DremelShadowed_fury has yet to learn the way of the Dremel
Amazzzzing
Goooodddd stuffff Cheap
__________________
Steam: kev_fury http://www.youtube.com/user/furyksx
- DFI x58 t3eh6 - i7-920 - XFX 6870 1GB - 6GB Patriot -
- AstroGaming a40s - SteelSeries 7G - Razer Deathadder - 2209WA -
Shadowed_fury is offline   Reply With Quote
Old 30th Jul 2008, 03:23   #153
Langer
Jesse Lang
Langer's Avatar
What was a typo is now appropriate after the 'snorzelphone' comment.
Amazingly cool man - bravo to the 'nth with this one.
seriously though:
+1 for snorzelphone
__________________
Old 30th Jul 2008, 05:43   #154
barry99705
sudo rm -Rf /
barry99705's Avatar
barry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyan
Hey Cheapskate, you got a Micheal's near you? Their art section should have any color sharpie you would ever need, separately.
barry99705 is offline   Reply With Quote
Old 30th Jul 2008, 08:06   #155
Tec_
Supermodder
Tec_'s Avatar
Tec_ has yet to learn the way of the DremelTec_ has yet to learn the way of the DremelTec_ has yet to learn the way of the Dremel
that is mind blowing.
Tec_ is offline   Reply With Quote
Old 30th Jul 2008, 19:41   #156
Cheapskate
Cheapskate's Avatar
Thanks everyone!
@Kayinblack - PM'd ...Quote: "You sure are purty in my clothes. I gotta T-shirt I want you to try on later..." -Evil Roy Slade.
@Barry - It was less hassle to buy a new 12-pack. I have a lot of cds to label anyway. The local Micheal's drains your soul, and there's cr*p for art supplies. It's all flowers and birthday party sh*t.
__________________
Old 30th Jul 2008, 19:43   #157
bentleya
Lian Li Snail :)
bentleya's Avatar
bentleya has yet to learn the way of the Dremelbentleya has yet to learn the way of the Dremel
wooot pump top shizzle hehe that looks mazing cheapskate keep the dam hard work up
bentleya is offline   Reply With Quote
Old 30th Jul 2008, 19:43   #158
E.E.L. Ambiense
Acrylic Heretic
LOL! Too true!
__________________
Latest Builds:
Old 30th Jul 2008, 20:31   #159
Cheapskate
Cheapskate's Avatar
Thanks
woot...shizzle -More Seuss words.
@EEL - Thank God for the internet. I wouldn't find anything without it.
__________________
Old 31st Jul 2008, 20:00   #160
Cheapskate
Cheapskate's Avatar
I think I scared off Kayinblack. My prices go up when I'm stuck with too many jobs. I'm having to farm stuff out this time too.
__________________
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
