#162 |
The Keeper of History
You want to farm out something, farm out some of the Dolly rain and the incoming rain to Colorado. We are literally burning up here. Ever seen a fire so hot it creates "fire tornadoes" We have them today in Denver. Bad day for fires.
http://www.myfoxcolorado.com/myfox/p...Y&pageId=3.1.1 John
__________________
My deepest gratitude to this community.
#163 |
↓ Don't trust that face!
Thanks Stuey.
![]() @John- I was just checking to see what all the commotion was about. It's still bone dry here too. You know the storm's going to be a wuss with a name like that. We need another tropical storm Allison here. It's been a long time since I've seen the bridges under water. If I have power tomorrow, I'm going to trim the screws for the top. The barbs are sealed and ready to test. I gotta do it now before I have a mountain of debris (from multiple yards) to take care of.
__________________
#164 |
Hypermodder
Wow, great pump top. It looks sick
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture Custom reservoirs and more: Phase 2 Casemodding |
#165 |
Thanks, brinkz0r.
-Storm was lame, not much rain either...
__________________
#166 |
Supermodder
Whow cheapskate, thats some very nice work!
#167 |
Code Monkey
nice, cheapskate. as always top class
__________________
All things are possible except skiing through a revolving door |
#168 |
Thanks guys.
@Karolis - High class + low brow. I aim to please.
__________________
#169 |
Code Monkey
hehe, and you did
more mad designs please but seriously, from your logs that i've read every idea, even the most crazy and unheard of, that you pick, turns out perfect. What's your secret?
__________________
#170 |
Thanks, but I've failed many times: Copper fangrill, Northbridge block #1, NB block #2, scrap re-casting experiment...
The BB log is a veritable screw-up-a-palooza. I was going to say the secret was being hard headed-somethin, somethin, but I couldn't come up with a way to say it that EEL wouldn't make sound dirty.
__________________
#171 |
Acrylic Heretic
__________________
Latest Builds: LilyPC - in progress • BIO-A10 - MotM Jul. '12 |
#172 |
Yeah...Like that. -only everything else I typed was worse.
__________________
#173 |
Acrylic Heretic
LOL.
__________________
#174 |
1 good, 1 not so good
ANYway...
Not much was done lately, but I did have a successful pump test last night. ![]() -First I had to do something about the nasty scratch I made on the base. It crossed perfectly over the area where the O-ring seats. A test fit showed it wouldn't seat right. I added a blob of #16 glue to the spot and re-sanded the base. ![]() -Then I moved on to the LED chaser circuit. I'm showing the pretty side first... ![]() -The underside is-Whoa! That's hideous!It doesn't quite work either. Who was just saying I was perfect? ![]() I'm going to go through everything just in case someone is looking and can be bothered to tell me where I went wrong. I used Japala's chaser circuit with some of the modifications mentioned in the forums there. The TIL198 was swapped for a 4n25. Pins: 1-hd led+ 2-hd led- 4- ground 5- 5V The 1uf capacitor was switched out with a 10uf cap. 2n3904 transistors were added to the LED power. A 120 ohm resistor was used for the ultrabright LEDs. ![]() -I kept getting called away and distracted too. Here I've soldered the lines to the LEDs to the wrong transistor lead. I had to change that. ![]() -Here I started linking the chip to the LED inputs. ![]() -Adding cap and resistors... ![]() -and finally leads and grounds. ![]() -Knowing my noobness, I saved this little jewel for a potential test victim. The Mobo turned out to be dead. Apparently the previous owner did more than burn out the power supply and collect viruses, (8 different ones, with 227 copies on a 30 gig HD! AMAZING! It also had 8 user profiles, so the drive was full with just system files. )I ended up testing it on toad's future guts. (I'm thinking of upgrading anyway. My parts must bore the hell out of you people.) Instead of a neat 123 lighting sequence, I got 2 random leds lighting, then 1, & repeat. -Sooo... If anyone can tell me what I did wrong... Hello? -Back to that other thing... ![]() -The pump top test platform here at NASA. This is a pic of pre-flight conditions. I ran lines to the radiator too, I've heard the pumps can get hot without some heat-sinkage. ![]() -I could swear I took this pic while the pump was running, but I can see the impeller blades. The air was worked out in less than a minute. watching the water jet through the top with a big air pocket in the funnel chamber was cool. This is a nice shot of my un-sanded HD bay too. -gotta work on that... ![]() I took the blue foam pads out later. The hum went away after that. I still need to drill holes for the LEDs, but IT WORKS! ![]() I have to thank Danger Den again for the opportunity to do crazy sh*t.
__________________
#175 |
Acrylic Heretic
That's bad-ass, man.
Sorry to hear about the chaser; I'm more of a case hardware person, so I can't do much more than wiring simple circuits. The pump is amazing though. Perfect idea for raising the pump off the base. I'm currently coming up with an idea for doing that as well with my two DDC's. They do in fact get kinda toasty during use, especially the higher-wattage ones. Kick-ass work, as usual, bro!
__________________
#176 |
Thanks EEL.
I'm kicking myself for having the time and not adding that green res to the loop. I totally forgot it.
__________________
#177 |
Hypermodder
hey i just finished my mod on that case (the test dell one)!
Anyway, GREAT pump top, really bootyfull.
__________________
Project Dimension 2400 |
#178 |
Thanks
![]() It IS the same case. You would probably choke if you saw how many dells I've tossed out.
__________________
#179 | |
John
__________________
#180 |
Supermodder
That pump top is just awesome. You have to be a little crazy to come up with this amazing thing
| Tags |
| scratch build |
| Thread Tools | |
| View Mode | |
