RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 20th May 2007, 18:23   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Performance per what?
http://www.bit-tech.net/columns/2007...nce_per_what/1
Many manufacturers have started to use the term "Performance per Watt" in an effort to draw attention away from increasing power requirements. Tim Smalley thinks it's time these manufacturers started focusing on lower power consumption before this obsession gets out of hand.
Tim S is offline   Reply With Quote
Old 20th May 2007, 18:29   #2
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
I've been moaning about this for ages, it'll take a good 18months before we see a significant decrease in GPU power consumption.
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 20th May 2007, 18:35   #3
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
if you get a low power consuming computer you don't get performance, if you want performance you have to buy a power hungry monster, there is no in between
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 20th May 2007, 18:37   #4
DougEdey
DougEdey's Avatar
AMD have proven that to be wrong, remember the 35W AM2 X2 3800+ they bought out?
At the time it was top notch.
__________________
PSN ID: DougEdey
Twitter
Old 20th May 2007, 18:40   #5
LeMaltor
>^_^<
LeMaltor's Avatar
LeMaltor will become famous soon enough
I did mean to ask this the other day, just how high can PSU's go? I understand about having more than one maybe if it ever came to it, but are we ever going to see like 10K watt PSUs lol
__________________
Welcoming the riff-raff since February 2009.
LeMaltor is offline   Reply With Quote
Old 20th May 2007, 18:48   #6
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
This is why I had a massive eye-roll when you guys did the ~750w PSU roundup, with plans for a 1kw roundup shortly after. I mean, PCIE provides something like 3x the power that AGP did through the slot, and from the beginning we've been using connectors that double that. Now we've got a pair of even bigger connectors?
And I remember back when a 500w PSU was massive overkill...
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 20th May 2007, 18:53   #7
LeMaltor
>^_^<
LeMaltor's Avatar
I think we should be more worried about our electricity bills that saving the planet, if you want to save the planet, turn your computer off and dont use it at all, as Tim Westwood would say "Go hard or go home!"
__________________
Old 20th May 2007, 19:52   #8
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
I just upgraded my ATi Radeon 9800Pro. Because my watercooling setup is finely balanced at a ceiling of about 230Watts, I did not want to get anything that would contribute significantly more heat to the system. Imagine my surprise when I found that an ATi XT1650Pro runs about 2.5 times faster than the 9800Pro, but at fewer Watts: about 45W instead of 48W. Gotta love that die shrinkage...
Yet the heatsink on the XT1650Pro is decidedly meatier than on the 9800Pro. What gives?
Marketing gives. Nobody wants to buy a GPU with a weedy-looking heatsink, because they believe it won't perform. People want big-ass cards with big-ass sinks, promising power like steroid-crazed body builders, like people want big PSUs and big radiators and big bore tubing and big pumps with listed flowrates that they simply not achieve in reality.
Let's change the script, guys. Efficiency is a good modding criterion too.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 20th May 2007, 20:03   #9
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
meh more transistors = more computational power = more heat
in the long term the heat disapation will increase. In the very long term it may decrease due to new tech but for now we are stuck with it.
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 20th May 2007, 20:09   #10
Ramble
Ginger Nut
Ramble's Avatar
Ramble will become famous soon enough
In other words, manufacturers should stop using efficiency as the only performance meter and start looking at the overall picture?
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back.
Ramble is offline   Reply With Quote
Old 20th May 2007, 20:10   #11
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Not necessarily. The XT1650Pro has about 50 million more transistors than the 9800Pro, but runs cooler. It is a matter of building hardware to be more efficient, as well as more powerful. Nobody wants a PC 5 years from now that uses 5000 Watts.
__________________
Old 20th May 2007, 20:13   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Look at the Core 2 as an example - more performance than chips manufactured on the same process node with double the TDP. It's all in the design and that proves that it can be done.
Old 20th May 2007, 20:15   #13
leexgx
CPC hang out zone (i Fix pcs i do )
leexgx's Avatar
leexgx is on a distinguished road
thay need to add power states into the GPUs like CPUs do
like when not in game mode auto Downclock and use less power
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947
leexgx is offline   Reply With Quote
Old 20th May 2007, 20:30   #14
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
In respect though, the 9800pro was the fastest card of the 9xxx series. You'd have to compare it to the HD2900 XT
But then again I spose 320 Stream processors is a bit more than 8 pixel shaders
Bindibadgi is offline   Reply With Quote
Old 20th May 2007, 20:31   #15
LeMaltor
>^_^<
LeMaltor's Avatar
Dont they have that already with 2D and 3D mode?
__________________
Old 20th May 2007, 20:33   #16
Gordy
Evil Teddy
Gordy's Avatar
Gordy is on a distinguished road
I run my main machine on single 120w psu. It runs all the games I want on a 24in display yet does need to treble my electricity bill to do it.
So they can create systems that require very little power, its just they wouldn't be able to claim its the fastest ever blah blah blah.
"For what its worth its a intel core duo laptop chip with 2gb of dd2 and a sapphire x800 gto2 with full sized hard disc and a laptop dvd writer."
__________________
modding.gordyhand.co.uk
Gordy is offline   Reply With Quote
Old 20th May 2007, 20:36   #17
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
They do, but does a high-end chip really need to run at 500MHz in order to drive an Aeroglass desktop smoothly?
Old 20th May 2007, 20:38   #18
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
I have to say that I think with the 8800 SLi and Quad core we've about reaced the top of wattage requriments. I'm pretty sure by the next gereration or at the second for sure, the companies will be looking to make high performance products with low power requirements.
For example, a 2Ghz Core 2 Duo, 2Gb of RAM, 15", 160Gb and an X1600 GPU can all be powered by under 65W (all be it they are mobile)......
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 20th May 2007, 21:00   #19
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
I agree completely with the sentiment Tim - before I moved to uni (and had to start paying my own power bills), I didn't give a toss about how much power my computer used, but now it's a real concern.
Looking at the new-gen GPU's, power consumption's gone mad. Intel have managed a decent effort with C2D, because it's a powerful processor for a reasonable TDP, but the graphics boys have just gone completely mad these days.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is offline   Reply With Quote
Old 20th May 2007, 21:33   #20
atanum141
I fapped to your post!
atanum141's Avatar
atanum141 is on a distinguished road
Originally Posted by HardOCP
Performance per What?
bit-tech’s own Tim Smalley has posted an editorial on the use of Performance pet Watt as a standard on PC components. Mr. Smalley feels that maybe we need to consider making some changes to the system at hand.
Let’s start with the CPU manufacturers, because they have been responsible for a large percentage of any system’s power draw since the day the megahertz race started. Out of the two, Intel has been the biggest culprit of poor energy efficiency in the past when its 130nm to 90nm die shrink actually resulted in a 25 percent increase in thermal design power (TDP).
Kyle's Note: Anyone that has not been seriously considering PPW in their hardware evaluations for a while now should be questioned about their opinions overall. You can read here, here, and here where power consumption and performance heavily weighed on our conclusions. As for his tree hugger stance on thinking about the planet where PPW is concerned, well, that made me laugh. Market demand will shape the CPU and GPU future, and I know most tech companies are already fully embracing higher PPW usage scenarios. Think R700 for starters.
A second comment regarding what we put on this site? Whats Kyle at H trying to do? I swear he's starting a E-Beef.
Bit & H are my two faves, but taking little diggs at Bit are starting to anoy me.
__________________
Welcome to Thunderdome, B*tch
XBL: atanum141
atanum141 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
