Thread Tools | View Mode |
#1 |
NI NI NI !!!!!!1!
Project : GTR -X CANCELED X- sorry :'(
Hi all and wellcome to my first worklog !
I have done a lot of modding before but I have never posted any worklog or pictures of my work. INTRO It’s called GTR (from the Ford Mustang GTR) It will be constructed in 4 phases, and it will of course be water-cooled (two loops) It will be 63.8cm x 55cm x 22cm and made of MDF board and plexiglass. BUT, sadly I don’t have to much money so it will take a wail before beeing finished. FIRST PHASE This will be the upper part Where the mobo, the pumps, radiators, reservoir… will be. SECOND PHASE This will be the lower part of the case, Where the psu and the hdd will be. THIRD PHASE Will be when I paint the whole case in orange, white and black. FOURTH PHASE Get all the hardware and assemble it. For the hardware : -evga 680i mobo -intel core 2 duo quad -two evga 8800 gtx in sli -4gig corsair dominator ram -one 1T hdd for the water cooling : -three 120 mm radiators -one 2x80 mm radiator -two laing pump ddc 1+ pump -two aquacomputer aquatube current status : phase 1 : ~85% PHASE 2 : 100% overall : ~80% Picture :
__________________
PROJECT NEOPHYTE http://forums.bit-tech.net/showthread.php?t=149036 sponsorized by : www.pc-koolance.eu Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net. Last edited by Dark~3nergy; 1st Sep 2008 at 17:01. Reason: update |
| Dark~3nergy |
| View Public Profile |
| Find More Posts by Dark~3nergy |
#2 |
NI NI NI !!!!!!1!
THE DESIGN
So let’s start with some sketches : The overall look of the case ![]() Here you can see the back and where the reservoir will be situated, I will use 4 xlr connectors for the two 8800 gtx and 6 rca connectors for the buttons, the fans and two white ccfl . ![]() The tube for the reservoir will be on the outside of the case, in the front I will put a lcd display. ![]() and with a 22 inches lcd screen just for size comparision ![]() Comments and questions are wellcome !! The first update will come tomorrow. cya
__________________
PROJECT NEOPHYTE http://forums.bit-tech.net/showthread.php?t=149036 sponsorized by : www.pc-koolance.eu Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net. |
| Dark~3nergy |
#3 |
Alu*mmm*inum!
Looks really nice.
If you'll make the case as nice as the sketch, i'll be very impressed
#4 |
Licenced idiot.
I like the sloped front panel, that's the optimal location for VFD if the case is on the floor... Good luck with your project!
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#5 |
What's a Dremel?
nice sketch and nice mod
#6 |
Supermodder
Looks very promising! Like the sketches, very cool design on the case, and fine solutions aswell.
Just a question: Dvd-ROM? Good luck! |
#7 |
Multimodder
dvd drv ? totaly overrated ^^
the sketches are kickass .such a n1 clean mod. definitly what i wanna see!
__________________
my case: carbon-fever! - pure carbon madness my blog: botchjob.wordpress.com crafty & electronics stuff - english content too! |
#8 |
NI NI NI !!!!!!1!
Thanx for the comment!
@ dj ovin : I prefeer to have the dvdrom on my desk(and i didn't get it in the design ) so it will be external (in the same theme as the case).I couldn’t wait so here is the first update : Update 1 Yesterday I went down to the town and i bought some mdf board for the front. I glued them togather because the retailer didn’t have the right thickness !(ps sorry for the bad quality of the pictures,they were taken with my cellphone) ![]() It was THE perfect day for modding, a sunny saturday. ![]() when the glue dried I started to mill the ''U'' on the front . ![]() Then I started to mill the fan hole,but just when I finished my mill broke . ![]() After that I cut down the edge whit my new jigsaw, perfect ! ![]() Then it was time to eat so I toke a pause. After that I found my father’s camera and decided to use it . Back to the garage I started with the other side, every thing started good but the blade went down 3 mm !!!!!!!![]() I will have to bondo that . Then I started with the switch . I drilled a 20 mm hole on one side and a 30 mm hole on the other . PS I made a wrong measurement on the fan hole as you can see but I will fix that later ![]() Now I have two identical holes for the switches !!!! ![]() Put one of the bulgin switch to see if it fits . ![]() ![]() Yeah , it’s perfect Here you can see how it’s ends up, that’s all for today. ![]() Next update will probably be in 4 days . Cya !!
__________________
| Dark~3nergy |
#9 |
ITS OVER 8000!
Very nice design ideas and CAD work there..
Nice hole work aswell.. I think you deserve some stars
#10 |
Supermodder
oh, i see! Maybe the best, too cool design without it.
#11 |
Supermodder
Awsome! I'll bewatching this one
![]() (Subscribed)
__________________
OS-formers Less than meets the eye! Windowsbots wage their battle to destroy the evil forces of the Mac-icons. OS-formers, Both lame in diguise.OS-formers,Less than meets the eye. Tranformers-I mean OS-formers! |
#12 |
Multimodder
man, you got some serious design skils..
waiting (in impatience ) for the next update.. |
#13 |
NI NI NI !!!!!!1!
update 2
Hi all and thanx again for all the nice comments !
It's time for the next update, I said that it should be in 3 days but I had time left this lunch so I worked a little . UPDATE 2 I don't have so many pictures of the work, just the result. I started to make the bottom panel, I cut an opening for the cables and the rest with my jigsaw, it ended up realy good. ![]() Then I cut the hole for the window. ![]() I put all the part together ,it starts to take shape, and now I'm happy ! ![]() Comments are wellcome. cya !
__________________
| Dark~3nergy |
#14 |
Sierra my delta, bravo!
This is looking awesome so far dude! If you can pull this off, it'll be one of the best looking mods I've seen.
#15 |
Minimodder
really cool! what would be VERY cool would be a "made in switzerland"-logo, just like on my knife set
__________________
Tiger Army never die! |
#16 |
Multimodder
normally i hate mdf cases but this one turns out really well.
__________________
#17 |
That yellow furry animal-thingy
Good luck with this mod! The design is looking really cool. If the result looks the same, then your case is a MEGA CASE!
#18 |
Multimodder
Very nice
Only 1 thing! You should have some filters for the front fans to keep dust out of this beauty. GL & Keep posting!
#19 | |
Multimodder
filers = less airflow. depending on the filter you use. You might wanna consider not even using it unless you have carpet or pets. I have ceramic tile flooring all the house =D not as dusty as carpet |
| elbarto241 |
| Find More Posts by elbarto241 |
#20 |
Minimodder
That just looks so awesome... keep on modding !!!!!!
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
